Question about Saeco Incanto Classic Espresso Machine
Saeco Incanto "grinder blocked" - Saeco Incanto Classic Espresso Machine
  • dssimion Aug 29, 2008
    Saeco Incanto (Starbucks Barista version).
    After thorough cleaning and power-up got this message on the display "grinder blocked". The problem started a bit earlier and could be fixed with a power-up reset. Other than that, the machine works (using pre-ground coffee through the chute). Is there a sensor I should bypass?
    Good links to cleaning instructions and technical manuals. Other than that ...
    Master:
  • 521 Answers
There is nothing like sensors.but for sure there are gears which helps the grinder motor to rotate and the gears are been stucked by something so the motor is nor able to run the grinder.and this problem occurs.try cleaning that internal gears.it will solve your problem.
  1. How to remove a jammed Brew Group?
  2. How to clean out grinder on Saeco Vienna Line or Trevi?
  3. How to clean out grinder on Saeco Charisma?
  4. How to clean out grinder on Saeco Magic Line and Royal Lines?
  5. How to clean out grinder on Saeco Italia?
  • Click here to Download Saeco User Manuals
  • Click here if you need a parts diagram to order parts
  • Click here to browse our online selection of espresso machine parts
pls do rate the solution
thanks.
regards.
fixya expert team
Posted on Aug 29, 2008
    Sergeant:
  • 241 Answers
Directions on how to remove a jammed brew group: http://cerinicoffee.com/Saeco_technical_documents.asp
Shop for Saeco parts and cleaning supplies: www.cerinicoffee.com
This should help
(please let me know
  • 2 more comments
  • Jayson Brollini
    Jayson Brollini Aug 29, 2008
    is it the far right lamp that blinking? Then you have to descale your machine.
    Is it the lamp in the middle in the bottom row, then you have to open
    the door and take out the driptray and dregsbox for 5 to 10 sec.
    if the water drop flashing then you have to open the steam knob and make a cup of water(tea).
  • Jayson Brollini
    Please go to http://www.cerinicoffee.com/Saeco_User_m... This should give the details on the bypass I not sure about that model and if bypassing is an option
    I have searched for that and no luck
  • Jayson Brollini
    Please make sure to unplugged the machine from the wall before you attempt to clear the gears of the BEANS. And see if there are and broken teeth missing on the gears or even chips.
  • Jayson Brollini
    Jayson Brollini Aug 30, 2008
    Don't Forget to rate user -->>Kindofcheap
    Master:
  • 848 Answers
Provide in detail about your problem ..........
mirran
  • 515 Answers
SOURCE: SAECO Incanto Rondo espresso machine
I think you have to take it to a Saeco service center, they have to upgrade your power board in the machine.
Posted on Jul 22, 2008
mirran
  • 515 Answers
SOURCE: Sirius Incanto loud noise
When you power on the machine, can you hear the machine do the self test?
is there a crack sound when the brewing unit is in work?
Posted on Aug 08, 2008
AlmostBob
  • 550 Answers
SOURCE: saeco Incanto
how tight is the coffee packed in the dripper, the flow rate is determine by how tight the coffee is, thats why you always see the barista press the coffee against the disk of the grinder dispenser in a coffee store
Posted on Jul 06, 2008
  • 81 Answers
SOURCE: incanto sirius states grinder blocked. Took apart
2 things can send this message.
either the motor is gone or the sensor in the grinder is not registering.
Posted on Jan 17, 2010
SOURCE: Grinder Blocked said on screen. Any Quick fixes?
This has happened to me twice. Usually caused by a trapped bean in the grinder. Here is how I fixed it. It is easy.
Inside the plastic bean hopper is a screw located in the bottom. Remove it and lift off the hopper. Have someone help you as you turn the machine upside down to remove all the beans. Use a tooth pick or a wooden skewer to pick out any beans lodged inside the grinder housing. Once completed, return the unit to its upright position.
Look inside the hopper and locate the grinder stem which is gold colored. On top of the stem is a hex bolt. Take a hex wrench with a 7/16 hex socket, connect it to the grinder hex bolt and turn it "counter clockwise" about half way which is the same direction the grinder turns. Add some beans and see if it works. If not, turn the hex bot "clockwise" a half to a full turn. Add beans and check.
This helps move the grinder out of its "stuck" position.
Posted on Jan 19, 2010
Saeco incanto says brew unit blocked
The message is likely generated because your grinder burr disk is ether stuck or turning too slow.. If you're a handy person, you can open up the casing, access the grinder assembly and clean it. If your grinder is clean and you still the message, may be the rotation pick connector got loose (it's the one with the 2 small black wires) or iss defective.
Mar 17, 2013 | Saeco Coffee Makers & Espresso Machines
Removing finger guard and cleaning ceramic grinder in Saeco product
Before starting, find the parts diagram for the Incanto Deluxe (google search: "incanto deluxe" "parts diagram").
To remove the finger guard, first remove the silicon plug (part number 90 in parts diagram) in the center of the grind adjustment knob by poking an unbent paperclip with a small hook along the silicon plug's edge, twisting 90 degrees and pulling the plug out. Next unscrew the phillips head screw (part number 15) way down in the center of the adjustment knob and remove the knob. Then remove the phillips head screw (part number 120) holding the finger guard to the bean hopper.
I'm not sure how to work on the grinder, but from here at least you should be able to get to it. I suspect that simply removing the finger guard may make things a lot better.
Mar 14, 2012 | Saeco INCANTO DELUXE Espresso Machine
Grinder is blocked and have tried screwing the grinder stem but no change is there anything else i can try
Hi hope I'm not too late. But I vaccumed the bean grinder. Unscrew the grinder stem fully open/large grind, place vaccum hose over grinder, turn on vaccum it sucks out any loose 'hard' beans/rocks/stems. Srew down to desired grind and refill - worked for me.
Jan 11, 2011 | Saeco Incanto Sirius Fully Automatic...
Ave an SAECO INCANTO RONDA with milling problems.
You can turn the grinder (mill) so the plates open for a more gross coffee this will help the grinder motor to rotate more free you can use a vacume cleaner to **** all the remainig coffee inside the grinder. If still not any reaction you have to desasemble complete clean the grinding plates. If you still not have any reaction then the grinder motor burn out and need to bee replaced.
Remeber to vote for this answer.
Feb 25, 2010 | Saeco Incanto Rondo Fully Automatic Coffee...
Incanto sirius states grinder blocked. Took apart
I own a Saeco Incanto Deluxe. It employs the ceramic grinder that has worked flawlessly for 3-4 years. One day it stopped and "Grinder Blocked" appeared. I removed the entire grinder unit, cleaned it thoroughly and calibrated the grinder. This did not fix the problem. After many similar attempts, I found the entire grinder assembly (motor, grinder etc.) online for $149.00. Install of the new assembly took me five minutes and it works perfectly. Please note that the ceramic grinding blades (there are two round ones that must be aligned corrrectly) cost $40 a piece (same site where I found the entire assembly for $149). My suggestion--save yourself the agony and replace the assembly if cleaning and calibration fails.
Jan 16, 2010 | Saeco 00034 Incanto Sirius Super Automatic...
Nov 03, 2009 | Saeco Incanto Sirius Fully Automatic...
Grinder blocked on coffee machine
Make sure you not get any damp into the grinder.
Can you hear the grinder grind or is it dead?
/Mirran
Sep 03, 2008 | Saeco Incanto Classic Espresso Machine
Stuck grinder
make sure you not get any damp into the grinder. If you have damp in the grinder then it do not grind the beans.
/Mirran
Aug 30, 2008 | Saeco Incanto Classic Espresso Machine
Jul 22, 2008 | Saeco Incanto Rondo RS SBS Espresso...
Saeco grinder
What kind of Saeco machine do you have, and how old is it?
Jun 27, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
2,723 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
