Question about Maxell T-160 PLUS
SOUND 'WEAVE' IN AND OUT
ONE CASSETTE TAPE (SOUND WEAVES IN AND OUT), BUT OTHER CASSETTES SOUND O.K. THIS IS JUST A GENERIC CASSETTE. I COULD NOT FIND A PRODUCT MATCH.
  • 88 Answers
KINDLY Check that cassette with another player unit
if the problem still
Chek your cassette"s spangestand inside of cassette was properly placed.
ok all the best.
Posted on Nov 13, 2008
Will it record on most cassette types
The difference between cassette types is the length of the tape and the quality of the tape. Your recorder will work on all types of cassettes.
Dec 17, 2015 | Panasonic RX-D55GC-K Boombox - High Power...
Cassette replacement
Well....first of all....you shouldn't need to erase cassettes....this is done automatically when they are recorded over when reusing them. As far as finding replacement cassettes you should find them online with a search. You could try Ebay, or just a general search should turn up some suppliers, or used ones.
Mar 17, 2014 | AT&T MC-60 Microcassette Tape Micro...
My heads on the xm1 seem to be dirty, ive used a sony cleaning tape, it only makes a difference for an hr or two taping, any sugestions
Firstly, I must explain how the MiniDV system works:
Although this may sound illogical, MiniDV camcorder heads do actually use a type of lubrication cassette system and there are 2 types:
- DRY lubrication (Canon, Panasonic, JVC etc)
- WET lubrication (Sony)
Now, if you haven't noticed already from the above 2 types, you are in fact using the WRONG type of cassette on your camcorder.
Although Sony cassettes are often readily available (and often perceived to be the best quality), by using Sony cassettes on a Canon camcorder (or Pana, JVC for that matter), you are in fact causing premature wear on the heads. So, the condition you are describing as 'dirty' heads, is in fact caused by the use of the wrong (wet type) cassettes on your DRY type camcorder.
Using "WET" type cassettes on a DRY system camcorder, can often leave residue on your heads, or worse....cause wear. The same principle applies to Sony camcorders - use only Sony 'WET' type cassettes, not Dry cassettes.
This also applies when using HEAD CLEANER cassettes - as indicated, you have used a Sony Head Cleaner cassette (this is a WET type cassette), when in fact, you should be using a DRY HEAD CLEANER cassette (Pana, Canon etc).
CAUTION: when using a head cleaner cassette, only playback the cassette for no more than 6 sec's at a time (anymore will damage the heads).
Summary:
For your Canon camcorder, use only DRY MiniDV cassettes (Pana offer cassettes from Studio, Professional to Master Quality), including DRY Head Cleaner cassette. This should improve the playback quality from your camcorder.
Mar 25, 2010 | Canon XM1 Mini DV Digital Camcorder
What tape cassette fits a Panasonic TRC3500?
This recorder takes MINI cassettes, not MICRO cassettes
Aug 09, 2009 | Sanyo TRC-3680 Handheld Cassette Voice...
I think the actual tape cassette is the problem not the player. olde tapes play very slowly, dragging, distorted sound. New tapes are fine. What can I do to re-vitalise the old draggy cassettes?
Actually the tape player itself is likely to be causing the problem. Cleaning the pinch roller and tape heads with a qtip and a small amount of rubbing alcohol should do the trick
Feb 26, 2009 | Audio Players & Recorders
Sound Issues on Audio Book Cassette Tape
This might explain things...
WHAT HAPPENS TO CASSETTES THAT WON'T PLAY
By Margie Crawford
Cassettes can be damaged in a
number of ways. Besides just wearing
out, they can be broken, twisted,
stretched, stuck, demagnetized or
missing the pressure pad. Most of these
problems can be repaired except for
demagnetization which causes the
audio to fade in and out.
Cassettes can be demagnetized at the
self-check out terminals so do not
place them on the machine while
checking out other items. At home
do not place them on speakers or near
magnets. If the audio sounds backwards
or like a foreign language, it is twisted
and can be repaired.
Oct 25, 2008 | Audio Players & Recorders
Denon DRW-585 dual-cassette deck makes clicking sound
There is an outside chance your tape cassett has a static charge. Tape in plastic case of cassette can build up significant electrical static which can partially discharge as tape is run. It can sound like random thumps, ticks, pops ect. Wrap cassette in a damp (not dripping wet) cloth, for several hours, then try again. This can also happen to the reels and drive rollers of the deck
Apr 04, 2008 | Audio Players & Recorders
Pioneer multi cassette changer info
Place tape to be recorded from in deck w/out button. Place tape to be recorded in other. Make sure anti record taps are intact on both cassettes. Press "record".
Jan 31, 2008 | Audio Players & Recorders
RCA cassette recorder/player keeps shutting off. argggg
fast forward, reverse the cassette and fast forward again. if the tape is too tight the current sensor will always trip out the motor.
Dec 03, 2007 | Audio Players & Recorders
Maxell T-160 PLUS Logo
124 people viewed this question
Top Maxell Electronics - Others Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Maxell Electronics - Other Expert? Answer questions, earn points and help others
