Question about Olympus Camedia C-2100 Ultra Zoom Digital Camera
Can I use my old (non- FL40) flash with my C2100??
Is it possible to use a general (non FL40) flash light with my UZI? I am still the owner of an old good flash light I used with my analog camera bit there is no correct connection for the cable on my new digital camera. Is it possible by using a special cable or connector?
    Master:
  • 852 Answers
When you use a vivitar or sunpak with your UZI do you use the CB-04 cable and do the units disable the pre-flash - I'm not referring to the redeye setting. I want to use a couple of slave units but the preflash of the Oly C2100UZ makes it not synch with the flashes. Also does the CB-04 have a female connector at each end? What are the other cables available from Oly to use off camera flashes without a female connector? Some seem to have a pin type connector. I'm not so interested in lighting up the world as I am in defeating the pre-flash so I can use the slaves.
Posted on Sep 11, 2005
    Master:
  • 852 Answers
Of course there are some who claim that trigger voltage is unimportant. I tend to believe them ,as there is no documented evidence from anyone that their camera has been harmed by using non proprietary flashes. Some posters are using older flashes with success and no harmful results. Do you have the nerve to try it? if so let us know.
2003 ford mustang gt anti theft light flashing engine will turn over but will not start
From my experience...
A non PATS coded key SHOULD not turn the STARTER...!
If ANTI-THEFT were invoked... you can attain a not start condition which the Owners Manual says must be cleared by the dealer.
A working PATS key should disable the anti theft... by turning the ignition on... ELSE try your other key.
The SecuriLock [PATS]
passive anti-theft system is not compatible with
non-Ford aftermarket remote start systems. Use of these systems may
result in vehicle starting problems and a loss of security protection.
Owners Guide (post-2002-fmt)
USA English (fus)
OWNERS MANUAL
Ford 2003 Mustang Owner Manual
SHOP MANUAL
Ford 2003 Mustang Workshop Manual
May 17, 2017 | Ford Cars & Trucks
Code C2100 2008 chrysler sebring what that means my car giving that code
C2100 Engine Fault Code Check Solution For C2100 OBD Code : C2100 engine code seems a kind of chassis problem, we try to show one by one the meaning and the solution.
Brief explanation of the C2100 code and definition of C2100 is the bottom side.
C2100 Meaning :
c Chassis Code
Problem is controller area network wiring bus and modules. 2 MFG - Manufacturer Specific 1 BBV Sensor Circuit Low Voltage 0 Low Coolant Circuit 0 Park/Neutral Postion (PNP) Switch Circuit Engine Torque Signal Circuit MFG - Manufacturer Specific codes, which have a '1' as their second digit to indicate they are unique to a particular vehicle make or model. These special codes were deemed necessary by the vehicle manufacturers so they could provide additional diagnostic information beyond the basic list of generic OBD II codes for all kinds of faults, not just emissions-related faults.
How To Fix C2100 ?
There are currently two main types of cylinder deactivation used today, depending on the type of engine. C2100 code for the pushrod design which uses solenoids to alter the oil pressure delivered to the lifters. In their collapsed state, the lifters are unable to elevate their companion pushrods under the valve rocker arms, resulting in valves that cannot be actuated and remain closed. C2100 Code Description: The oxygen (02) sensors on your car measure the oxygen in the exhaust to determine how rich or lean the ratio of fuel and air are in the cylinders. Optimizing this mixture means better fuel economy and fewer exhaust emissions. When you see C2100 engine fault code on your engine code reader this description will help you.
C Codes List of all Chassis codes. Final Step: In the definitions listed below, there is a test drive recommended after you've completed any repairs to see if the condition is fixed. Before you take a test drive after a repair, always erase the C Code(s) first. This will turn the check engine light off and then you will know if the check engine light returns, you've got further diagnostics to complete.
Nov 29, 2016 | 2008 Chrysler Sebring
KithenAid model KUDSo1DL wont operate, clean green light flashes non stop
This is a issue with the way the water is moving & or heating in the unit. There should be a tech mini manual behind the motor kick panel. The manual describs the failure and it's correction. Depending the the model year & run / revision code, this error could be caused by low water level, a bad thermistor, the control board not sensing inputs, bad heater or door interlock switch issues. attached is a couple of help sheets. They are general in scope.
Mar 27, 2012 | KitchenAid Microwave Ovens
I have just upgraded my PC to iCore 7 with Windows 7 64bit OS, however when printing to Fuji Xerox Docuprint C2100, the gradiation on the photo is pixelated and not smooth. What printer settings do you...
Did you use plug and play or did you follow the install programs' directions? If you use plug and play, many features do not work.
If you did plug and play, uninstall the printer, download the current install program from Xerox (free), presuming they make one... Some printers and lots more scanners do not work with newer OS...
THEN, use the interfact that Xerox (likely) provides, to run the printer.
Newer printeres and scanners are now NETWORK based, meaning non hosted by a computer. You have to run installs on the printer AND every machine, but then anyone can scan, for example, as if they hosted the scanner.....
Feb 23, 2011 | Xerox DocuPrint C2100 Laser Printer
Turn signals not flashing on a 1998 Old Intrigue,
Do the lights come on but, just don't flash? It could be the turn signal flasher. The owners manual should show the location.
Feb 20, 2010 | 1998 Oldsmobile Intrigue
Check engine light, flashing cruise control light
if you put a scanner on it you'll prob get a code telling you what prob is.if you have a autozone or,pepboys they could put scanner on it and tell you what prob is the only way
Feb 08, 2010 | 2007 Subaru Impreza WRX Sport Wagon
Need user manual and/or service manual for Canon imageCLASS C2100
here you go...this printer model is known as cp660 on other regions (based on their Web site).
http://printer1.blogspot.com/2008/03/canon-cp660-service-manual.html
hope this helps.
Mar 05, 2009 | Canon imageCLASS C2100 Laser Printer
Lights flashing on guitar and usb
If you are using the Fender Stratocaster Rock Band Guitar:
1) Ensure you have fresh batteries in the Wireless Guitar
2) Insert receiver into USB hub
3) Turn on Guitar via switch on back.
4) If both the guitar and the USB receiver is flashing blue, then press the guitar logo button until flashing blue light on the receiver stops flashing.
Note that on Rock Band 1, non-Rock Band guitars (ie: Guitar Hero and Wiimote based guitars) generally don't work.
Jan 19, 2009 | Nintendo Rock Band for Wii
Olympus Camedia C-2100 Ultra Zoom Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
