Question about Jensen JMC-800 CD Shelf System
JMC-800 My JMC-800's CD Lid won't stay closed. Any idea why???
    Sergeant:
    Champion:
  • 310 Answers
Just turn off and turn on then try it...
Posted on Aug 29, 2008
  • 1 more comment
  • khader ibrahim Aug 29, 2008
    If its not work means check the motor..
    If u have warranty means u can claim it.
    1. Make sure the drawer-loading belt is still tight and elastic. If
    not, it can be replaced with a belt obtained from an electronic-parts
    supplier. The replacement should be of equal or slightly greater
    thickness and should fit snugly but not so tightly that it strains the
    motor.
    2. Check for broken or loose gears and have them replaced.
    3.
    Check for obvious sources of contamination such as pet hair or foreign
    objects that are preventing smooth operation of moving parts. Small
    children have a habit of inserting items into CD players.
    4. Use electronics-grade contact cleaner to clean the door-position contacts.
2 Suggested Answers
SOURCE: Lid Closure
OK - There is nothing that drives the door to close and stay closed. There is a little plastic gismo the locks onto a little protruding tongue in the lid keeping it closed. To release the lid, you must press the lid foreward so that it releases the lock in the little plastic gismo. I found this out only after removing the board above the main deck of the player and which, fumble-fingers me, I managed to damage the board and will have to replace it along with the little plastic gismo that holds the door closed. I am not sure if either of these parts are available as I have had the unit for quite a while. This leaves me in a quandry as I really did like the little player. It was a dandy. So, if you ever get an inquiry on how to keep the lid closed on a JMC_800, tell them to replace the little plastic gismo and that will do it.
Posted on Aug 31, 2008
Hitachi ax-m71 cd door won't stay closed. Unable
if it opens back up when you close it the drawer mechanism is probably out of alignment. Most players have a slot on the bottom of the drawer that a pin must slide in. Look under the drawer and see if there is a pin sticking up that maybe should be in that slot.
Jul 09, 2013 | Audio Players & Recorders
The cd drawer won't stay closed
the cd drawer will probably use infra-red to sense when the drawer is open or closed or maybe just a gear mechanism, either way these must be clean, I'd take it apart and lean it all with cotton buds and isopropyl alcohol
Feb 07, 2013 | Audio Players & Recorders
LID WON'T CLOSE ON CD PLAYER
The CD loading mechanism have the fault. Check its loading belt. If loading belt has broken, the try wont close of open. If loading belt is OK. replace the loading motor.
Aug 12, 2012 | GPX Audio Players & Recorders
Not work CD Player
HelloCheck the CD spins inside it, when we close the lid. if not, check the lid. There is a small swelling like formation at its edge that will get into the CD player, when we close it. This will hit on a micro switch inside the set, which in turn send a CD in signal to its system control IC. If this signal does not reach the main system control IC, it won't sense that CD is in. If this switching process is OK, when you close the CD lid, make sure that the CD mechanism has the trouble, and need service. OK.
Dec 18, 2011 | Aiwa CSD-TD49 Cassette/CD Boombox
Kenmore washer 80 series stopped draining
So it will agitate and fill but the motor won't run during drain and spin?
If so, the likely cause is a bad lid switch. The paddle that the probe hits when the lid is down moves a small switch. That switch can do two things
1. fail internally. It will look fine outside but it won't close the circuit
2. the screw holes snap and it hangs off the wires, the probe no longer hits the paddle and the switch stays open.
The lid switch is cheap and very easy to repair.
Nov 10, 2011 | Kenmore Washing Machines
JMC-600, CD won't spin, "Err"
if speakers are connected sorrectly and you have no sound from the radio your build in power supply is prob bad. call the manufacturer for warrenty or just buy a stereo
Jan 29, 2011 | Jensen JMC-600 CD Shelf System
Lost manual for jensen jmc-326
http://www.spectraintl.com/jn/pdf/JMC-326%20EIB.pdf
Nov 29, 2010 | Audiovox JMC326 2Disc CD Player
Lid Closure
Aug 29, 2008 | Jensen JMC-800 CD Shelf System
Jensen JMC-800 CD Shelf System Logo
83 people viewed this question
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Shehu Pro
Shehu Pro
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
