Question about Gateway FPD 1730 17" Flat Panel LCD Monitor
Snapping monitor into stand
For some reason, the person who I bought this monitor from disassembled the stand. It appears to slide in with 2 bent "legs" and then just snap in with 3 prongs on the back of the monitor sliding into the stand.
But I cannot snap it in there for the life of me. Any suggestions?
  • thecolfax Aug 29, 2008
    (it's a 1730 if that's not obvious from the forum.)
    Scholar:
  • 45 Answers
You slide in the 2 bent legs, then it doesnt snap. there are supposed to be 2 screws that hold it into place on the top portion of the stand. Find the correct screw size and your stand should keep your monitor up.
Posted on Sep 14, 2008
I bought a new Vizzio M22OVA and have been trying literally for days to attach the base stand. I even called Vizio customer service and they were no help. I'm at a total loss. I really love the design of...
The stand has 8 small tabs that protrude from the top of the stand. There is also a larger clip that sticks up a little in the center. Purpose of large tab is to snap into place to keep stand from coming off. Just place stand on bottom of tv so the tabs on the stand go into the holes in bottom of tv.
Then just slide stand forward or backward till it snaps into place. I think 2 screws go into the bottom of stand after it is snapped in place to hold it. Just be careful and don't put any undue pressure on the screen. Actually works better with one person holding the tv upside down while another snaps base in place.
Jul 04, 2017 | Televison & Video
How do i remove stand from samsung syncmaster 2333 to mount on wall
its a snap-type plug-in stand, just hold the stand firmly and pull the monitor equally upward, then it will snap quickly....... but a proffessional reminder! Before mounting your SyncMaster on a wall, be sure to plug the two (2) stand holes located at the buttom of the monitor. My Samsung SyncMaster 2333HD LCD TV was twice intruded by adult-size lizard, both incident resulted to main power board damaged!!!!
Feb 13, 2011 | Samsung SyncMaster 2333HD 23 in. LCD TV
How to disassemble the agitator after removing from the tub. The cam and dawgs need replaced. Agitator top and bottom appear pressed together.
After you remove the cap on top there will be a 7/16 nut. Remove that nut. The whole thing should slide up and off. If you put the agitator on the ground and stand on two sides of the base and give a quick ****, It will seperate. Slide the sleeve away from the dogs and replace them. The top snaps back together, slde back on spindle and replace the 7/16 bolt. Replace cap.
Sep 06, 2010 | Whirlpool LSQ9610L Top Load Washer
Acer Monitor Stand removal
On the rear of the monitor stand, just 1/2" above the word "Acer", is a rectangular button. push it in and pull the stand off . If you need to remove the rectangular tube, there are two snap on covers, one on each side of the tube. Pop them off and remove the screws underneath. That's it.
Feb 22, 2009 | Acer X193W LCD Monitor
Acer Monitor, Model No. X223W -- I can't get the arm of the back of the monitor (the thing you stick the base into) in order to mount on a multiple monitor stand (quad)... Spoke with Acer Tech Suppoort and...
i have the same problem with the AL1717. After hours figuring it out, i found the solution.. if you slide off the cover holding the back arm, you will expose the screws holding the arm which you can screw off to take off the back arm....
the cover can easily slide off as it is only 'clicked' into place.... gently put your fingers on the cover apply some pressure to slide it out...
Dec 19, 2008 | Acer AL1717 17" LCD Monitor
How to disassemble 900w
The proview trims have to be slid upwards to remove them once the 4 screws are out of the bottom.
You'll need to lift the top part slighty away from the lcd to allow the sides to slide up.
If you don't slide it , then yes, you'll break tabs.
ebays bammbammfran
Aug 25, 2008 | Gateway FPD2275W LCD Monitor
I want to remove stand 'holder' so I can mount on an Atdec V-AT-DB Dual Focus LCD Desk Mount
I have the same problem and I hate to admit it but I'm on the verge of putting a blade in my hand held router and cutting the plastic away. I don't want to do that since maybe I may need the mount someday, but...
Jun 06, 2008 | Gateway FPD2275W LCD Monitor
Need to know how to Disassemble AL1912 19" LCD Monitor
The ones I take apart have a snap on front bezel.
gently pry at the lcd edge with fingers in center left or right to get it to bow , dont damage the lcd with too much pressure.
it will start to separate ,put a plastic knife or such in the outside crack and work your way around once you have one side the rest will be easier. you have to bow the inside edge out(away from the lcd) because of the plastic clips.
luck.
Apr 17, 2008 | Acer AL1912 19" LCD Monitor
Opening the monitor
These are a snap to open.
Put a towel on a flat surface like the dining table.
Remove the 2 screws that hold the stand in and slide the stand out of the hole.
Remove the screw in each of the 2 bottom corners.
Remove the screw in the middle at the bottom (it was under the stand to begin with but some do not have it for some reason.)
Now comes the easy part.
Put a few fingers onto the section the power plug goes into.
Tuck your thumbs into the hole left by the stand.
Push into the power plug section downwards with your fingers at the same time pull upwards with your thumbs. The rear panel should pop up. Gently pop it all around the edges.
Hope that helps =)
Apr 10, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
How do i turn my tv into a pc monitor?
if you bought the cable and you have a pc then all you have to do is plug ur tv into ur computer then go to the control panel then appearance and personalization then personalization tehn display settings then you will see two boxes a 1 AND A 2 THE ONE SHOULD BE LARGE AND THE 2 SHOULD BE SMALL CLICK ON THE 2 YOU ARE THEN GONNA WANT TO BRING THE RESOLUTION DOWN BECAUSE TV TEND TO HAVE LOWER RESOLUTION THEN COMPUTER MONITORS
Jan 10, 2008 | Televison & Video
Gateway FPD 1730 17" Flat Panel LCD Monitor Logo
179 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
