Question about Jensen JMC-800 CD Shelf System
Lid Closure My JMC-800 Lid won't stay closed. Any idea what might be causing this???
    Problem Solver:
OK - There is nothing that drives the door to close and stay closed. There is a little plastic gismo the locks onto a little protruding tongue in the lid keeping it closed. To release the lid, you must press the lid foreward so that it releases the lock in the little plastic gismo. I found this out only after removing the board above the main deck of the player and which, fumble-fingers me, I managed to damage the board and will have to replace it along with the little plastic gismo that holds the door closed. I am not sure if either of these parts are available as I have had the unit for quite a while. This leaves me in a quandry as I really did like the little player. It was a dandy. So, if you ever get an inquiry on how to keep the lid closed on a JMC_800, tell them to replace the little plastic gismo and that will do it.
Posted on Aug 31, 2008
JMC-800
Just turn off and turn on then try it...
Aug 29, 2008 | Jensen JMC-800 CD Shelf System
Sub zero refrigerators 632 door won't stay closed
This model doesn't have a standard closure system for the doors, It contains a bar and string system under the doors, some parts may not be available currently but parts could be swapped from one side to the other, I have done it and it works. So you will need to inspect all parts to the door including bushing, gaskets and make sure the unit is square to the floor cause this will cause to door to pop open after closing it. Call Subzero for parts directly to fix this issue at 1-800-350-2676. They can and will point you in the correct dealer for you to get the correct parts you seek. Good luck.
Sep 01, 2014 | Sub-Zero 632 / S
IMac G5 17" won't shut down
I have minor shutdown problem with mail, won't close or shut down. My ans top left APPLE drop down, force closure, turn of each programme listed. For me works a treat.
Jan 19, 2013 | Apple Computers & Internet
Maytag A7800 washer wont start agitation with lid closure
you need a new lid switch assembly, which will run you about 30 - 40 bucks
Jun 05, 2012 | Maytag Washing Machines
Trunk won't open
can you access it from the back seat.? you might have to remove the bench seat and then the back rest to shine flashlight to see if indeed something is jammed in the latch.
Aug 12, 2017 | 2007 Chevrolet Corvette Convertible
Kenmore washer 80 series stopped draining
So it will agitate and fill but the motor won't run during drain and spin?
If so, the likely cause is a bad lid switch. The paddle that the probe hits when the lid is down moves a small switch. That switch can do two things
1. fail internally. It will look fine outside but it won't close the circuit
2. the screw holes snap and it hangs off the wires, the probe no longer hits the paddle and the switch stays open.
The lid switch is cheap and very easy to repair.
Nov 10, 2011 | Kenmore Washing Machines
When I close the lid on the portable DVD player it says that it is open and wont read the disk, can you help
The lid closure interlock is not satisfied; it's located to the left of the open button (a tab on the top lid should hit the switch when closed)
Feb 21, 2009 | Coby TF-DVD7100 Portable DVD Player
Chest freezer lid
Vacuum is caused by contraction of air. If your temperatures are being maintained the difference in how easily the lid opens and closes is not a point to worry about. If the lid wont shut after it is opened you do have a problem. If the lid is staying open at one corner try, with the lid open give it a slight twist pulling on the corner that is not closing fully. This action should spring the lid back to its original sealing position.
Jun 12, 2008 | Freezers
Jensen JMC-800 CD Shelf System Logo
98 people viewed this question
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
