Question about Delta ShopMaster 8in Grinder with Light GR350
Delta 23-880 bench grinder
How do you hold the wheel while loosining the bolt to replace wheel
You should be able to hold the grinding wheel with a pair of leather gloves on your hands and lossen the bolt. Look very carefully at the threads to make sure you are trying to lossen and not tighten. Some are left handed threads on bench grinders.
Posted on Sep 11, 2008
I have a Delta 6 bench grinder model #23-680. How do I hold the shaft from turning as I loosen the nut hold the grinding wheel in place?
Hold (or lock) the grinding wheel on the other side if loose or lock because the locking direction is the same direction and don,t forget to ringing (sound-check -like a tuning fork) the stone if you replace it with a new one The risk is small but safety first
Apr 10, 2017 | Delta Grinders
Adjustsettings on Oregon 511AX bench grinder
there is a nut and bolt that holds the little shelf below the grinding wheel. Loosen it and adjust the shelf or rest to within approximate ly1/8 inch of wheel for safety.
Nov 27, 2014 | Oregon 511ax 115-volt Bench-mount Chain...
Need a delta grinding wheel Cat. No 23-583 36 grit coarse AL. OXIDE were can I find one?
It doesn't need to be Delta, all it needs is to be 8" diameter, same width (1" or 3/4" or 1/2" or whatever), and have an arbor hole (or plastic adapter) the right size - they're all pretty standard.
You can buy wheels like that locally at your hardware store, or online at Amazon or eBay or Sears or any number of other places. They're nearly as common as dirt, and really inexpensive.
May 05, 2014 | Delta 23 883 8 Inch Bench Grinder Wheel,...
How to remove wheel on delta 10' grinder
Unplug it first, if you like your skin.
Use a wrench on the nut, and hang onto the wheel with one bare hand while you turn the nut in the same direction as the wheel normally spins. If you have a lot of difficulty doing that, jam the wheel with a piece of wood.
Feb 01, 2014 | Delta Grinders
I own a Delta 23 680 bench grinder. The mounting bolts came loose and went into the casing. I have taken the grinder apart so that I can pull off the caps on the ends to gain access to the bolts but I...
first mark the caps so that when you reassemble they will align properly, Next get a small screwdriver and GENTLY pry the cap apart. One end probably has a rotating switch with wires coming from it so be careful. When reassembling you can use a small piece of wood to tap the end bells back into place.
Apr 03, 2011 | Delta Grinders
I need an owners manual for delta gr450 8
Here's a link to download the pdf.
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Delta/A15786.pdf
If it doesn't work, start here:
http://www.deltaportercable.com
Mar 02, 2010 | Delta Shopmaster 8" Bench Grinder
Grinding wheel for Delta bench Grinder where to get one.
It should take a standard grinding wheel, available at almost any hardware store.
Oct 13, 2009 | Delta Grinders
Grinder starts and runs then peters out and gets pretty warm. Is capaciter bad?
Most probably. the motor will overamp, get hot and go out on internal overload.
Oct 12, 2009 | Delta 23 684 6 Inch Bench Grinder Wheel,...
Grinder wheel wobbling
check bearing for play and or race for wear on wheel
Oct 06, 2009 | Grinders
Grinder won't stay running
The capacitor is easy to change and can be matched once you remove it by any electronics parts house.
Nov 24, 2008 | Delta 23 884 8 Inch Bench Grinder Wheel,...
Delta ShopMaster 8in Grinder with Light GR350 Logo
462 people viewed this question
Top Delta Grinders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Delta Grinder Expert? Answer questions, earn points and help others
