Question about Mitsubishi Televison & Video
Timer light is flashing but tv wont turn on!
The timer light will flash steady but the tv won't turn on with the remote or the power button on front of te tv. I have unpluged the tv over night and now it will flash for a while and then it goes off for awhile. I have also pushed the reset button but that didn't make any difference except when i was holding the reset button in.
When the timer light stoped flashing the remote control would not turn on the TV. The next time the light quit flashing I held the power button in on the TV for about 5 seconds and it came on and has had no problems since then with the remote or the local TV power button.
Greg Allen
Posted on Sep 02, 2008
  • Robert Holmes
    Robert Holmes Oct 10, 2013
    ok did you solve the problem or get a new tV
I have a JVC AV 32432 and the on timer light is flashing and tv won't turn on.
Flashing of timer is fault indications. Check this site for more details. It has more than 1400 posts to different brands of electronic entertainment and other equipments. All posts referrers with the repair and fault finding to electronic entertainment equipments. It will be best to view it either in Flipcard or Timeslide option, can be selected by the sidebar tag at the top left of the display screen. Timeslide view will be the best to select. If you are using Google Chrome as browser, Flipcard option will be the best.
Dec 02, 2012 | JVC AV-32432 32" TV
Mitsubishi tv won't turn on
did you try new batteries in the remote? if the tv has buttons on the side and one of them being power di you try to push that? did you push tv power or cable power holding the buttons longer? those things might work.
Jun 05, 2012 | Mitsubishi WS-55909 55" Rear Projection...
My samsung M8 tv remote Tv button keeps flashing. the remote is usless and wont work regardless of what button is pushed. the TV power light flashes also as though it searching for the remote. have...
there are basically two reasons why this is happening; 1. it's either the TV's timer is on accidentally or 2. your TV is having a power problem.
Check the timer settings on your TV and make sure it's set to off.
But if you've confirmed that problem is not from the timer, then it means the TV is having a power problem. The power board of the TV is dying gradually due to defectiveness of some of its component.
Have the timer checked first, then give me a feed back, so that I can give you some diagnoses on the power issue.
Yours sincerely.
Elect_Comp.
May 16, 2011 | Televison & Video
The power went out today. Once the power was restored, the green (Timer) light simply keeps flashing and the TV wont turn back on. None of the buttons on the front of the TV work nor does the remote. I...
There are 7 capacitors that need replacing in you digital module, it is located on the left hand side facing the back of the set. After opening the module there is a small power board inside, replace all 1000uf 16volt capaictors with 680uf 16volt capaictors. After replacing them there will be a small green led on the board that lights inside the digital unit. it will flash then go steady if all is ok with the set after replacing these capacitors. After this is done the power light up front will blink about 30 secs then go off. Turn on the television and happy viewing...
Please leave comment...
Oct 08, 2009 | Televison & Video
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Av-32d302 tv
The set is shutting down because a problem has been detected. Replacing the remote will not help. Count the flashes and call a JVC servicer to get an idea about what the specific problem may be.
Dan
Jul 29, 2008 | JVC AV-32D302 TV
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
Open Questions:
Televison & Video Logo
611 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
