Question about Toshiba PDR-3310 Digital Camera
Better Focus How can I get a better focus?
    Novelist:
    Scholar:
  • 104 Answers
There are several factors that can contribute to getting better focus and improved results. 1. Auto Focus / Auto Exposure lock. Press the shutter button down HALF WAY. The camera will attempt to adjust exposure to the current lighting environment for maximum benefit. Then the camera will automatically correct the focus based on objects in the center of the display. This process usually takes about two to three seconds. 2. Be sure not to cover the sensor on the front of the camera with your finger. This will disable the automatic focus and exposure controls. 3. Only us the MACRO MODE for CLOSE-UP photography. Be sure to use MACRO MODE if you are taking pictures of an object at less than six inches away. Be sure not to use Macro Mode for Normal Photography. Using MACRO MODE improperly will result in poor focus (also known as 'fuzzy pictures'). 4. Rely on the LCD Monitor, especially for Telephoto and Macro photography. Due to differences in depth perception, the Viewfinder is not as accurate at the LCD Monitor. When in doubt, trust the LCD. The LCD will display the subject more accurately than the viewfinder. This will help with "framing" the subject, or determining if you have enough light for proper exposure. 5. Motion can cause a "blur" effect. Either motion of the subject, or motion by the photographer. This phenomenon is just like traditional photography. Moving objects may appear to blur, and this will be even more evident in lower lighting situations as the shutter speed slows down to allow for more light. The shutter will react faster in bright light, and motion will not be as apparent.
Posted on Sep 11, 2005
SOURCE:
How do I focus (camera) manually?
Look through the viewfinder of your camera and turn the focus ring until the image appears sharp. you could use a split screen focusing screen to acjieve better focus!
Dec 04, 2015 | Cameras
What is aif on the canon 9g one shot camer
It is one of the autofocus schemes Canon uses. If you did get the manual, P121 discusses how to set the size.
They do not officially define it other than as one of the auto focus modes between "face detect" and "Center" focus. Center focus is just that- a single focus beam down the center of the lens. The AiAF is a larger target area, and essntially each of the 9 blocks you see when you set your camera is a location where a focus beam will be.
It is a part of the fuzzy logic of the camera that uses the light metering strategies as the framework for the focusing strategies for lack of a better description. So maybe a better pnemonic would be "Activity in Auto Focus."
Dec 27, 2011 | Canon Cameras
How to stop camera from focusing during videos? Every time I make a video the camera keeps focusing making the screen blurry!
There are a number of tips on how to make the camera focus better:
http://www.kb.sony.com/selfservice/microsites/searchEntry.do?locale=LA_eng_US&usemicrosite=true&region=UMRE_UNITEDSTATES_2_5&sonyregion=US&searchString=focus&product=SG_DSCW80_5_16411&sonytemplate=1&sonymodel=DSCW80
Input 'focus' in the search term to get it.
It seems like you can change the shutter speed to a faster speed to focus better. Or, you can change it to manual focus. I think.
This should be int he manual.
Jul 24, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
What Bosch super 4 spark plug fits a Ford Focus 1.6 zetec.
my advise don't get those, they don't work as well as you think they do.
if you think about it if they are so much better why don't drag racers use them?
because they actually block the ignition point.
just get the factory style plugs and you will be better off.
May 16, 2009 | 2001 Ford Focus
My nikor lence is not focusing . its made crazy just serch for focusing but it cant so what can i do for it ?
The 18-70 is a rather slow lens and needs quite a bit of light before it will focus. Also, the lens needs contrasting between subject and background. For instance, if you try to take a picture of just the blue sky with nothing else in the frame, it will probably not focus at all. Put a plane in there as the subject and you should get the shot.
See if you experience a better focus outside during the day with some good contrast between subject and background. If it works better, then it's just the limitation of the lens. If it's still not focusing, there might be a problem with the lens. You do have the lens on M/A (auto focus) right?
Mar 27, 2009 | Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX...
Better Focus
There are several factors that can contribute to getting better focus and improved results. 1. Auto Focus / Auto Exposure lock. Press the shutter button down HALF WAY. The camera will attempt to adjust exposure to the current lighting environment for maximum benefit. Then the camera will automatically correct the focus based on objects in the center of the display. This process usually takes about two to three seconds. 2. Be sure not to cover the sensor on the front of the camera with your finger. This will disable the automatic focus and exposure controls. 3. Only us the MACRO MODE for CLOSE-UP photography. Be sure to use MACRO MODE if you are taking pictures of an object at less than six inches away. Be sure not to use Macro Mode for Normal Photography. Using MACRO MODE improperly will result in poor focus (also known as 'fuzzy pictures'). 4. Motion can cause a "blur" effect. Either motion of the subject, or motion by the photographer. This phenomenon is just like traditional photography. Moving objects may appear to blur, and this will be even more evident in lower lighting situations as the shutter speed slows down to allow for more light. The shutter will react faster in bright light, and motion will not be as apparent.
Sep 11, 2005 | Toshiba Sora PDR-T20 Digital Camera
Better Focus
Sep 11, 2005 | Toshiba PDR-3330 Digital Camera
Switching from auto to manual focus
AF/MF (Auto Focus/Manual Focus) * The AF/MF function works in CAMERA, M.REC mode only. * In most situations, it is better to use the automatic focus feature, as it enables you to concentrate on the creative side of your recording. * Manual focusing may be necessary under certain conditions that make automatic focusing difficult and/or unreliable. Auto Focusing * If you are inexperienced in the use of camcorders, we recommend that you make use of Auto Focus. Manual Focusing In the following situations, you may obtain better results by adjusting the focus manually: * A picture containing several objects, some close to the camcorder, others further away. * A person enveloped in fog or surrounded by snow. * Very shiny or glossy surfaces like a car. * People or objects moving constantly or quickly like an athlete or a crowd. Follow These Simple Steps To Set The Manual Focus 1. Set the power switch to CAMERA mode. 2. Turn the MENU DIAL up or down until the FOCUS is highlighted and then press the ENTER button. M. FOCUS(MF) will display. 3. Turn the MENU DIAL up or down until the object is in focus. Zoom out a little if focusing is difficult. 4. To return to AF (Auto Focus: ), press the ENTER button again.
Sep 07, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Toshiba PDR-3310 Digital Camera Logo
132 people viewed this question
Top Toshiba Cameras Experts
Damen Wong
Damen Wong
Lawrence Oravetz
Harrie
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
