Question about Lexmark Office Equipment & Supplies
CPU Motherboard changed and Lexmark LZ705 won't install
  • Lexmark Master
  • 13,433 Answers
Hey,
Check http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:0:0:0 for up to date software.
Thanks,
Ekse
Posted on Aug 29, 2008
How to restore when laptop won't boot up
try changing boot divice at start up you hard drive may have falled
Jun 26, 2012 | Acer Mb.rjy02.001 Aspire 5250 Laptop...
Motherboard won't boot up cpu fan comes on hdd
Just after that there was NO correct answer to fix this problem causes the problem not solved even if it is marked as solved. Me too I have this problem, I was fix it by setting jumpers to default 60 Hz AC power because I won`t have 50Hz AC power or some AC power converter before PSU, I mean this is voltage errors, it`s need to be set to default +5V(60Hz) PSU not +5VSB(50Hz) PSU, (Step1) like might be set to USBPW12 to pin 3 both USB to right side inserted jumper it`s in left side of, near ATX 12v advanced CPU power cable connection socket. Next (step 2) is set up front USB jumpers to +5V or system won`t start up, it`s on motherboard about between PCI1 and PCI2 on right side it must be set to USBPW56 and don`t set it to USBPW78(5+VBS) because system won`t start up, the jumper must be set to right side I mean it`s last jumpers to right side need to be set up, because it`s +5V(60Hz) PSU supply. The USB wake-up feature requires a power supply that can provide at least 500mA on the +5VSB lead when these jumpers are set to +5VSB otherwise the system won`t power up. Next step if it still not starts up its BIOS fault, it`s easy to repair, just (Step3) turn off PC remove BIOS battery (it`s down to IDE cables), start it up wait a bit, then turn it off and turn it again on wait a bit again, turn it off place BIOS battery in to socket to be able save BIOS settings i mean battery is need to save them otherwise settings won`t be saved and Chassis will be broken. (Step 4) Turn PC on press del key after BIOS is load in open Power\Hardware monitoring\Chassis Intruder set to Disable, save settings exit. (Step5) If BIOS (PC won`t power up) it`s Chassis1 jumper fault, it`s need set to Default (Chassis signal, and GND(Ground)), it`s between SATA 2 and SATA1(Serial ATA connectors 7-pin it`s near and down to BIOS battery, the jumpers might be set to right side, after it`s completed repeat Step3 and Step4. CMOS is BIOS battery. If that all doesn't works Take BIOS clearing jumper in it`s clear state, near BIOS chip. Turn on PC with CMOS clear jumper turned on its work. Take beck jumper in its default state after that take bios chip out and CMOS battery out both them an two times restart PC after insert all beck if PC will be working all keyboard flashes once, after its in AC power.
May 07, 2010 | ASUS P4P800-VM Motherboard
Motherboard dont see all installed ram after changing cpu's.
You might want to update the bios. Flash the bios on your new motherboard.
Aug 11, 2009 | ASUS Computers & Internet
P4 M920 motherboard toat
try to use another CPU that is compatible... maybe it's the cpu that wrong... if nothing change.. then you really need to change a motherboard..
Jul 20, 2009 | VIA P4MA Motherboard
P25g motherboard, monitor wont turn over
i think you need to try replace you're ATX power Supply or you need to try remove the other 1 of you`re memory...Thanks
Apr 23, 2009 | PC Chips P25G Motherboard
I have an intel celeron 1.79 GHZ on my dimension 2350,what is the better processor for upgrade? and is there something else that i should change inside for the new processor?
you said that you want to upgrade ur 1.79ghz celeron cpu.
to upgrade a cpu just check that the packaging of the new cpu matches with the motherboard.
and also check that the motherboard supports the new cpu that you are installing. check this in the manufactures site.
Apr 14, 2009 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
PC not even booting...
you might have fried your PSU
Apr 11, 2009 | XFX GeForce FX 5500 Graphic Card
ABIT TH7II -change CPU
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
  1. Intel MotherBoard
  2. Mercury Motherboard
  3. Gigabyte Motherboard
  4. MSI Motherboard
  5. P5GC-MX/1333 Motherboard
  6. ASUS Motherboard
  7. IBM
  8. Packard Bell
  9. via
fardinkh2
Apr 09, 2009 | Abit TH7-RAID Motherboard
Changing processor results in windows xp pro failing to install
I'd try upgrading the bios with the working cpu and then try again.
Let me know what happens. I like the weird ones like this.
Feb 26, 2009 | Abit KT7A Motherboard
I am trying to install a X5070 and it says under system requirements that I don't have enough processor speed. Help
Unfortunately, if you cpu/processor is not fast enough you will need to upgrade the cpu to the minimum requirements.
NOTE: Your motherboard also needs to support the minimum cpu required. You can refer to the manual to see if it will. If not, you may need to replace the motherboard also.
Hope this helps. Please remember to rate this information.
Thanks
Nov 18, 2008 | Lexmark Office Equipment & Supplies
19 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
