Question about NAD Audio Players & Recorders
I have a NAD320BEE that doesn't work. The speakers cut out after about 1 to 2 seconds. Any suggestions where I could get it fixed
  • yyyyyyyyyyyy Aug 30, 2008
    In Maidstone - Thanks
  • 4,234 Answers
It would help us to give you recommendations if we knew where you were located. Please update this with a city/state.
Thanks,
Dan
Posted on Aug 29, 2008
The sound on my Samsung 32 in. LED TV keeps cutting out. It cuts out for 1-2 seconds. It does this approx. every 30 seconds. I have changed cables and cable box....no change. Any suggestions?
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Nov 26, 2015 | Samsung Televison & Video
I cant get any sound even with the volume all the way up, any suggestions?
there are 2 possibilities of your problem.
1. the speaker of your phone is faulty
2. the wires connecting the speaker to the mother board is cut.
you can simply have it checked by a technician. this is just a minor hitch and doesn't need highly trained expertise.
Nov 10, 2011 | Samsung Solstice SGHa887
I have a Technics SU-G70 Amplifier with a problem. Overall, it works fine except for a speaker issue. When turned on, the Left speaker output on the monitor is lit up from 0 to 120. Just below, the...
Sir the problem of your unit is the power IC the other channel of this IC is already faulty. unplug the unit to the main AC outlet then remove the cover of your unit you will see a large aluminum plate the power IC is attach to that heat sink in order to fix this you should replace the IC. Or can you give me the part number of the IC so I can determine the pin configuration. Good day and best regards.
Sep 15, 2011 | Technics Audio Players & Recorders
When i power it on it shuts off i got a kenwood kdc-mp825
Disconnect all of your speaker leads at the head unit, make sure none are touching, then power it back on. If it still cuts out, check your ground, if it doesn't, re-connect speakers one by one and test power again. It will either cut out when you get to a speaker or wire that's shorted, or work just fine. it's protecting itself from damage by cutting off when speakers are either bad or have shorted wiring. Most common shorted wiring happens on door speakers at the hinge. If it continues to cut off without speakers connected and you have a good ground, the unit needs service. If it still plays and you find the speaker or wire that's causing the problem, disconnect the wire at the speaker and test again, if it works, replace the speaker, if it doesn't, replace the wire. Hope this helps
Jul 07, 2011 | Kenwood Sirius KDC-MP825 CD Player
Speakers had been working fine for about a month. But recently they have started crackling when I increase the volume above about 1/3 and cut out every couple of seconds if i increase the volume to 1/2.
uninstall and reinstall the sound driver and see if it works if that does not work try the same speakers to different sys. and check if it works the port of the sound card might have gone bad and if the same problem with other sys. speakers had gone bad.
Oct 27, 2009 | Creative Labs I-Trigue 2.1 3300 Computer...
Speaker cut out
The problem sounds like either the connectors from the radio to the speakers disconnecting.
To fix this I suggest you work out which speaker is getting is cutting in and out. Then you take the speaker out and check the connectors are attached to the speaker correctly. If the connectors are loose or don't have dirt or something stopping the from making a clean connection the speaker this can cause a problem.
If after checking the speaker connectors the problem persists you need to take the radio out can check the connectors on the radio have not come loose or anything.
If it still doesn't work after that I would then look to replace the radio, as if the speakers are working some of the time that would mean that the problem is probably with the radio not the speakers.
Hope that helps
Feb 05, 2009 | 1998 Ford Contour
Additional Speakers
hello my frien let me tell you that the system wont accept more speakers or diferent loads per ohm if the total load says 16 ohms by channel thats the total can handle so if you ad more speakers the system turns off before it burns or or have a severe damage........saludos
Nov 17, 2008 | Sony MHC-GX250 CD Shelf System
Bose Acoustimass power
I have the same problem TOO!#$#@% Anyone out there?
Nov 08, 2007 | Bose Acoustimass 5 III System
the amp is overheating. Disconnect one speaker at a time to see if problem persists. If so, the amp needs serviced.
Nov 08, 2007 | Onkyo TX-DS575 Receiver
Sd-at1000h surround system
I have the same problem. Powers on for 1 sec displaying "hello" and powers off.
Oct 25, 2007 | Sharp SD-AT1000H System
55 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
