Question about Hoover Vacuums
My Hoover Turbo power 4900 does not have enough power to pick up lint off the floor - when I hold my hand up to the attachment, I could say there is not suction - any suggestions?
  • BoscoBrownie Mar 14, 2009
    Not enough suction & it smells from the dog hair..... I have cleaned the filter & everything, any suggestions?
reddevil6
  • 1673 Answers
SOURCE: Hoover z400 clogged
There should be a bottom plate covering the brush roll that you can remove, if you can't dig out the what is in there, try using your hose and suck it out from the bottom, maybe you will be able to get it out.
Posted on Mar 06, 2008
Agent Don
  • 310 Answers
SOURCE: Hoover wind tunnel self propelled U6617-960
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=40485&thid=557365
Hoover Windtunnel self propelled U6617-960
Posted by srkelly on Apr 29, 2008
The vacuum has no suction at the floor. I have checked the hose, and no blockage. When I try to use the attachments, still no suction. What could be the problem.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Hoover U6437-900 / U6439-900 Windtunnel upright Vacuum
You definitely have a clod between the tube by the brushroll area and the attachment hose and the best way is to take a wire hanger and make a little hook on the end to see if there is a clog, the clog is closer to the fan area and anything big would clog up the area sideways and
-- you may have to remove the top cover to see if there is a clog and to better get @ it from the top. Another suggestion is to do a belt change whether you have one or 2 belts on the vacuum and to change the belts @ the same time every 4 to 6 months. Also, check you owner’s manual under trouble shooting to see if there is something else, other wise that is what I think is the problem. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Posted on Apr 29, 2008
SOURCE: Hoover SteamVac Model F5887-920 - hand attachment won't spray
I have a model I got in 2001. I found that the water sprayer on the hand tool is driven by a little turbine that relies on suction from the main vacuum motor. I eventually found that the spindle inside the turbine had separated and hence the hand-tool wouldn't spray. I glued it together but that only fixed the problem until it broke again. I am going to buy another (about $23).
Posted on Aug 04, 2008
SOURCE: No Problems with suction on hoses, however brush area it seems to lose powe, and has little suction r
We had a similar problem with ours and had to finally take it to the repair shop. They informed us that we needed to replace our clutch and that you needed to do that every 2-3 years. It cost less than $100 and has been well worth it.
Posted on Jun 24, 2009
  • 294 Answers
SOURCE: No Suction
The water channel hose could be torn. you can check by removing the lower tank and tilting it backwards, it is located in the lower section. could also be the filter cover. it is needed for full suction control.
Posted on Oct 28, 2009
Need replacement gasket, what holds it in place
Vacuum Parts And Accessories ' Parts For Vacuums - Sears
www.sears.com/appliances-vacuums-floor-care-parts.../b-1020290
SearsSears has replacement parts for all of the top vacuum brands, so you'll be .... Hoover Canister Vacuum Cleaner Replacement Crevice Tool Attachment 38617017 .....vacuum bags and numerous attachments, your vacuum will have your floors ...
Amazon.com: Vacuum Parts & Accessories: Home & Kitchen ...
www.amazon.com > ... > Vacuums & Floor Care
Amazon.com, Inc.Results 1 - 24 of 219043 - Online shopping for Home & Kitchen from a great selection ofReplacement Batteries & Parts, Bags, Filters, Attachments & Brushes, ...
Vacuum Cleaner Parts & Accessories: Hoses ... - Hoover
Nov 29, 2015 | Vacuums
My Hoover windtunnel brush is spinning but not picking up. I cleaned everything out, but still not picking up. There is another small set of 2 wheels that is not spinning. Could that be the problem?
If it's been over 6 months replace the belt or belts. stretch belts lose elasticity soon after being installed which is why they should be replaced frequently. Your belt may still spin the brushroll but not fast enough to clean carpets properly. After a few months it will pick up some of the sandy gritty soils but will force some of it down into the carpet fibers. Eventually it will become so stretched. It will not pick up hair and lint.
Jan 03, 2015 | Hoover Vacuums
Hoover hu 4207/1 pet hair removal turbo brush wont revolve
Try Larryclare1's solution for a Kenmore and see if it helps. Worked wonders for both my turbo brush attachments. http://www.fixya.com/support/t1095798-kenmore_model_116_powermate_jr_stopped
Feb 27, 2010 | Vacuums
My Hoover U5491900 Anniversary Windtunnel will not pick up very well, there is good suction when I use the attachments, but when I use it on the floor it won't pick up much, what is wrong with it and how...
The reason why it is not picking up well is because the belt is worn or stretched and it can't turn the brush (which picks up debris) against the resistance of the carpet. Here is the belt you need:
Hoover U5491900 Belt
Jan 20, 2010 | Hoover U5491-900 Bagged Upright Vacuum
Need Hoover cannister vacuum floor brush & filter bags
Hello, if you GOOgle Hoover you will be able to find your nearest Hoover center, they will then be able to help you with parts and bags. We did this last year and it was emensely helpful. Hope this helps.
Nov 04, 2009 | Vacuums
Hoover Power Drive Supreme - Locked Up!!
Q: Are you talking about the turbine powered hand tool that attaches to the hose? If so, just squeeze the two round pins on the sides, and the housings will separate.
Oct 03, 2009 | Hoover U6311-930 Power Drive Bagged...
Doesnt pick up water
Possible Causes Remedies
ReadyTools Dial may be at the wrong setting for the cleaning job <> Set ReadyTools <> Dial to either Tools / PreTreat or Floor Cleaning.
Nozzle Window may not be properly attached. <> Press down firmly on the black oval gasket at the top
Window to make sure the two tabs on the back of the Nozzle Window are snapped into the mating slots in the main housing.
Tank-in-Tank lid is not installed <> Re-install lid;
Tank lint filter is blocked <> remove all lint and debris from Tank lint screen.
Tank-in-Tank is not properly seated. <> Tank-In-Tank must be firmly seated to function; remove
and reseat Tank-in-Tank.
Poor tool position (Hand held attachments only). <> Adjust angle; apply more downward pressure.
Tank-in-Tank has picked up maximum dirty water <> Empty Tank-in-Tank
Front Clear Floor Nozzle Window ids blocked <> Remove window and clean all fibres and debris then replace.
Insufficient suction <> Clean Pre and Post Motor Filters.
Sep 28, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
My hoover steamvac turbopower 5000ls will not spray for hand tool
my turbo 5200 will not pick up the moister into container to dry does anyone know what the problem may be
Sep 12, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
My Hoover upright vacuum runs but isn't picking up
Either it's clogged, has a broken belt, or the bag needs to be replaced.
Hope this helps.
Aug 19, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Detergent Container spring and plug
won't spray out water to wash neither with the hand attachment, nor with the floor shampooer! This was a lemon since I got it. They made me send it to Madison Wi which was costly enough but then they kept it for months, then they sent it to one of their offspring stores and I had to drive an hour and back to pick it up! This is all at my expense. I used it 2-3 times and I have the same problems again! They said is was a pump, but how many pumps can a person go through being I use this machine like 1-2 times per year??? I need to use it in my motorhome and thought the hand attachment would work, but it won't spray either! HELP.
Aug 02, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Vacuums Logo
377 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
