Question about Freezers
Beko fidge/freezer (model cg975ff) overheating
My families fridge/freezer is flashing a fridge temp.of 9 oc.I have cleaned the seal on the door and vacuumed behind the appliance.I have also checked the drain tray which was ok but noticed the black thing at the back (low)was extremely hot.Could this be part of the problem and is the plastic drain tray that sits on top of this in any danger or burning? We would be greatful of any help or advice you could offer.Thanks.Greg.
  • Anonymous Apr 01, 2014
    the smell seems to come from a plastic tray behind, is it possible to remove tray for cleaning?
My general maintenance seems to binging the temp down slowly.thanks
Posted on Aug 30, 2008
The indicator light (that usually reads temp) is flashing, food not frozen
check door seals
check power at plug
check thermostat setting in fridge the lower the number the colder the temperature
call a fridge technician
Apr 09, 2015 | Freezers
Freezer has moisture dropping from bottom of door. Just started Saturday 8/9/14. What could be the problem? Also, where do you fine the model number?
You might have a torn seal around the door. CHeck that carefully and clean it with a damp sponge.
The model number is on a tag somewhere inside the fridge, usually easily readable so check by the filter or the light.
You might also have frozen coils, and might need to defrost it (turn it off for a day with the doors open) so get some freezer boxes and some dry ice to store your food and keep a towel on the floor in front of the freezer to absorb the melted ice.
Aug 10, 2014 | Kenmore Freezers
Beko fridge freezer not working
The first thing I would do is to check the compressor and the condenser fan. Remove the cover on the back of the fridge and check how hot is the compressor? Is the condenser fan turning well? Also check the condenser coil under the fridge, it is very possible it needs cleaning.
If the condenser fan is not working properly then it has to be replaced.
If the condenser fan motor is fine and the cleaning did not help then the sealed system is low on Freon and in such case you need a certified technician to fix a leak and to charge the system.
Good luck in solving the problem of the freezer...
May 06, 2011 | Freezers
My hotpoint ff187 fridge/freezer is making a beeping sound and has flashing lights. We have tried everything from turning off this button and that, then trying the power off and backwards again. There is...
clean the door rubbers and sides this sometimes fixes the problem as the seals are not closing properly and the fridge freezer thinks you have left the door open.
Feb 09, 2018 | Hotpoint Freezers
Hi My beko frost free freezer has been building up ice in the little grid thing at the top of the freezer. The temperature was also driopping ( to 8) and so I have put it on fast freeze to raise temp. What...
check the door seal on the top of the door if not sitting flat to the frame it will encourage frost to build up (inside the little grid thing)which will stop the rest of the freezer from cooling enough.
Jun 14, 2010 | Freezers
Kenmore upright freezer only 3 years old running ,no clicking noise, no ice build up but won't completely freeze although set to 7 (lowest temp)
check door seals, also check vent direction, a dial or lever in fridge, it adjust how much air goes to fridge and freezer
May 07, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
I have a Beko frost free fridge freezer but the freezer part has stopped freezing, the fan is working although it is not on all the time and the freezer is getting cold but no cold enough to freeze, have...
have you checked the door seals, if it has split it won`t freeze 100% as warm air will get in and keep the temperature up, bit like leaving the door slowly open hth
Oct 12, 2009 | Freezers
Freezer door of electrlux freezer keeps coming
Try cleaning along seal and seal itself. If it does not work get new seal. The seal do go bad after a while.. If under warranty call dealer you purchased from for them to replace.
Jul 06, 2009 | Freezers
FRIGIDAIRE FREEZER MODEL # LFFU1465DW3 WON'T FREEZE
Make sure freezer door seal is completely sealed. No gaps, Also, if you are up to the challange, you will need to remove the freezer panel, test thermometer, thermostat, for voltage and resistance. Also check that the flapper that seprates freezer from fridge air.; Is not frozen.
Jun 11, 2009 | Frigidaire Freezer Refrigeration White...
BEKO FRIDGE FREEZER
The best way is open freezer door wait 30 seconds then shut if the door pulls shut further then machine is working if not not working.
Thanks J
Dec 23, 2007 | Freezers
Freezers Logo
151 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
