Question about Maytag Atlantis MAV6451 Top Load Washer
Maytag atlantis washer not spinning
It sounds like it spins but I opened the door and pushed the switch with a wire and it does not spin at all, therefore leaving the clothes wet.
Do you know what I need to do?
thank you
maggi
  • 2 more comments
  • Anonymous Oct 11, 2008
    machine
  • pupoluv808 Oct 11, 2008
    machine sounds like its spinning but is not. is there an easy way to fix without calling a repair person?
  • spinnot Dec 19, 2008
    sounds like it is spinning but is not
  • Anonymous Dec 31, 2008
    my maytag atlantis is 8 years old, and it sounds like it spins, and only the motor runs. i need a new transmission!!! the repair man said this happens on this model. therefore,i need a new washer, and i won;t be buying a maytag.
I had the same problem.  Try this:  The top of the washing machine has a rear cover that protects the rotary switch, should be 6 screws holding the panel on.  Directly behind the switch that allows you to set the spin cycle is of course the the switch.  The very top of the switch has a clip on/snap on wiring harness.  Make sure the machine is unplug while you are performing any of this.  Make sure the wiring harness is completely snapped in to the switch.  Over time your machine causes the harness to get loose.  Specifically when you overload the machine and is unbalanced during the Spin Cycle. If you are not comfortable with this process see professional help.
I hope this helps you.
Andy
Posted on Dec 28, 2008
My Maytag washer agitates, and will pump during the spin cycle but will not spin
Check the lid switch is operating. It will not spin for safety reasons if it thinks the door is open.
If the switch is good test for power at the wigwag (spin) solenoid when in spin cycle. Since it agitates the solenoid itself could be bad.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Aug 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Machine Stoped at the begining of spin cycle
The door switch or its actuator is not making contact. This is assuming that the other cycles work properly. Basically it thinks the door is open and it will not spin.
Jul 08, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Need to replace Lid Switch for Maytag Atlantis 2002 Washer
Hello, I can help you.
Let me explain to you how the Maytag washer lid switch works.
The lid switch is located on the controls panel, and is activated by opening and closing the washer door. The purpose of the lid switch is to prevent the washer from working with the door open.
It is a safety device to prevent the user from sticking their hands inside of the washer while the washer is agitating or spinning.
When the washer lid switch stops working, the result could be that the washer won't wash, drain, spin and in some cases the washer will not work at all.
You will need a multimeter to check the internal contacts on the washer lid switch.
You will also need to use the wiring schematic to see what contact should be close when the lid switch supposed to be on.
You will need to remember that the Maytag washer lid switch is one of the first parts that you will need to check, when the washer don't want to start filling, agitating, draining or spinning.
Jun 13, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Hi...mt maytag washer topload was working fine........but when it came to spin mode it just stops.........so i rearrange everything and took out all my clothes so now it has only water in it but still...
I would bet your door switch is broken or not making contact try to use somthing to push switch down and see if it works when you do that or it may just be broke off
Feb 23, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag atlantis mav6000
sounds like the carbon brushes need replacing in the motor, they can cause a screeching sound as they wear down.
Oct 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Will not spin Maytag PAV2300AWW top loader
check your door switch. Many times a faulty door switch can prevent the spin cycle. When you locate the door switch, take a jumper wire across the connection and advance the timer to spin. If it spins with the jumper wire, you will need a new door switch.
Jul 04, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Water in clothes
Check the door switch for damage. Use a small jumper wire across the switch, if it spins the water out, you need to get a new door switch
Jun 24, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag washer spin cycle
check the door switch for broken or damaged wires. A jumper wire across the switch ends will give you either a spinning or non-spinning washer.
Jun 20, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis 7600 spin cycle (top load)
the maytag runs in one direction for wash. it reverses to drain and spin - check for a broken or loose belt. maytags I have run into circa 1989 have two belts. as for the softener dispense, there may be a solenoid valve that is supposed to open. may be just a flapper type of valve. softener goes in by gravity feed.
Sep 04, 2007 | Maytag MAV7600 Top Load Washer
Maytag Atlantis MAV6451 Top Load Washer Logo
245 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
