Question about Black & Decker String Trimmer Cordless 12" 18V
Automatic line feed melts together -will not feed- second trimmer to do this
Line feed on trimmer does not feed line. line is actually melted together
    Problem Solver:
  • 18 Answers
The talcum powder fix that I gave for line feed problems works for this problem too. The powder lubricates the line, eliminating the friction that melts the line. They are essentially just two parts of the same problem.
Posted on Sep 02, 2008
  • sonofbeach Sep 03, 2008
    Put a couple of teaspoons full of talcum powder (baby powder, but NOT the kind with corn starch) in the bulk spool container. Shake it up in a zipper bag to thoroughly coat the line. Coat the inside of your spools with a light coat of talc.Then, load your spools with it. The talc lubricates the line, eliminating the friction that is melting the line.
How do i remove the spool head? I have line caught in it and cant pull it out as per usual.
Usually you unscrew the end knob anticlockwise to remove the line carrier,or spool
Mar 04, 2015 | Garden
Why is the trimmer head smoking/melting?
I think the melting is in your the head the feed that hods the line. That's the plastic bit. I have had this happen not just with one brand either. The problem is vibration. if things are not properly balanced the head vibrates, the resulting friction causes heat, that causes more wear and more heat. End of strimmer head! I not buy them two at a time on ebay!
Jul 22, 2012 | Garden
I just got a grass hog trimmer that used to belong to my sister. The line is not feeding and I don't know how to restring.
The cap on the bottom pops off, and there is a spool in there. Sometimes the line melts to itself in spots and you just have to free it and if you feel you need to then you can cut some off.
I hope this helps you out.
Jul 27, 2011 | Black & Decker 14" Grass Hog Xp...
Replacing the dual-line on the 15" Electric trimmer - Do you run the line through the slot on the casing before the outlet hole?
The slots on the string spool are there just to hold the line in place so it doesn't unwind while you are putting the string head back together. You have the strings sticking up, you lower the casing with the eyelet holes down, feed the ends of the strings sticking up through the eyes and then yank them free of the slots so they can automatically feed. So yes, line goes from spool hub to spool slots to casing outlet holes and don't forget to pull it free of the slots.
Oct 11, 2010 | Craftsman Garden
String breaks in a few seconds. Change spool no help. New 0.80 green string no help. What else?
The hole where the line comes through the plastic spool should have a metal grommet in it. If the hole is just plastic, then the line rubs against it and the heat cannot dissipate, so the line gets hot and melts.
Aug 13, 2010 | Black & Decker Garden
Engine is running but the line no longer moves - it like it's out of gear
Sorry I can't solve it yet but same thing happened to me...I took out all the screws holding the case together and could see that the drive belt from the motor to the shaft had worn away or melted...at any rate I could see it was in shreds...Have to see if there is any way to replace that belt
Jun 22, 2010 | Black & Decker 14" Grass Hog Xp...
How do I open the spool to restring a Troy Bult line trimmer
They come with a rig pin to lock the spool in place, then turn the large platic ball on the bottom of the trimmer head COUNTER CLOCKWISE. do not try to fill up the spool with line it will only get stuck and melt together. You should also sprinkle the line with baby powder as you wind it up as it reduces sticking too.
May 25, 2010 | Troy Bilt Tb70ss Gas Trimmer
First use of GH1000 for 2010- Beginning of 3 rd year of use)--From stop to rapid head & Line rotation of Trimmer.(It has always been this way) After 10 Min. of use-engine seemed fine but no rotation of...
I agree with you there. I have read a few dozen complaints about the same problem, and none have been answered to my knowledge. I have not been able to find the parts to self repair either.
Apr 11, 2010 | Black & Decker 14" Grass Hog Xp...
Trimmer line on spool of Challenge 250 Watt Grass Trimmer.will not automatically feed as it is supposed to do when tapped on firm surface - can you let me see by diagram how the line is feed onto spool and...
I did a lot of searching for a manual but I guess Argos does not want their customers to know how to use their product. When you are use the trimmer, most rotate clockwise. You may find on the spool an arrow showing direction to wind line. Otherwise you will have to take it apart the trimmer and remember with direction the spool turns. Wind the string on the same direction turns. plus try a little wd40 on the line to keep it from sticking together.
Cheers.
Oct 12, 2009 | Garden
Black & Decker String Trimmer Cordless 12" 18V Logo
601 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
