Question about Mitsubishi WS-65809 65" Rear Projection Television
Mits 55908 Convergence problem
I have a 6 year old 55" Mits Diamond RPTV (WS-55908)that has worked flawlessly since I bought it. However, a few weeks ago it started doing something that concerns me: about half the times that I turn it on, within about 30 seconds the converged picture breaks into 3 pictures; red, green and blue, more at the edges than in the center. Usually it will re-converge within a minute or less and be fine after that, but once I waited a couple of minutes and it didn't re-converge so I turned it off and then back on and it was ok. Is something in the convergence circuit starting to go that I can repair or have repaired at a reasonable price? Or is this something that I can/should live with long term? I'd hate to lose this trusted family member. Any help greatly appreciated. Thanks.
  • jpnrc Sep 01, 2008
    Thanks Big Irish. Seems like this is not an uncommon problem with RPTVs.
  • lricaud Sep 09, 2008
    I have the same problem, I fix it by banking the top of the cabinet a couple of times. From this I assume that there is nothing wrong with an IC unless it is loose, how can i find out which one it is?
  • 927 Answers
Good Day, John;
It sounds like the Convergence IC's have poor solder connections, by re-soldering the convergence output IC's should solve your problem. The IC's are large and mounted to large silver "heat sink" with STK 392 # on them. Good Luck, big IRISH.
Posted on Aug 31, 2008
  • MICHAEL MULLINS Sep 01, 2008
    Good Day, John;
    Yes it very common for PJTV's that use those type of devices. They normally fail within five years unless your TV has good air circulation. Good Luck on your repair, big IRISH.
I replaced my Mitsubishi 55 diamond and don't know how to get the back top portion off to get it out of the house. it's too wide and no screws found? Please help
Oct 12, 2011 | Mitsubishi WS-55908 55" Rear Projection...
The Color On My Mitsubishi Rear Projection Tv model- WS-55908 looks to be off, picture looks blue and Yellow.
its sounds like the convergence on your TV needs to be adjusted. (this adjusts all of the color guns in the back of the tv to line them up again, when they get off, you start to get yellow blue or red halos around objects in the picture. In the setup menu on your TV under picture or Display there will be an item that says "convergence" follow the instructions in there so all the crosses on the screen no longer have colored halos anymore.
Mar 10, 2011 | Mitsubishi WS-55908 55" Rear Projection...
My poor mitsubishi 55908 just lost it's picture after working flawlessly for 10 years. The sound is still there, but the screen just went dark. Is this something that is repairable? Thanks!
This is a high voltage problem, but first try turning up the screen voltage located on the focus block. This requires opening the back of the TV, be careful of dangerous high voltage. See if there's a picture after turning up the red, green, blue, voltage adjustments, if not then vertical sweep, Flyback, or convergence need servicing. This repair shouldn't cost more than $300.00 dollars, maybe less. Contact me at my link below so I can help you further. If this helps please rate :-)
Oct 22, 2010 | Mitsubishi WS-55908 55" Rear Projection...
My tv is haveing is a problem, i keep getting color seperataion and it beows on top n bottom , how do i get this fixed????
The tv have a problems known as a convergence problems,it dead.The tv convergence board have 2 dead STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 12, 2010 | Mitsubishi WS-55908 55" Rear Projection...
TV is approx. 10 years old. Picture has started
This is a model first made in 2001--when it does it go into the customer menu and select CONVERGENCE--what you are looking for is is red or blue skewed and will not adjust?
If this is the case I can tell you what is needed based on the model number you provided.
If you have any questions let me know--I am here to help people.
if this helps you rate this information as I do this here for FREE.
Nov 11, 2009 | Mitsubishi WS-55908 55" Rear Projection...
Picture warped and distorted on Mitsubishi WS 55907
sounds like a convergence failure. Is it possible to post a picture? If not does the image appear as if its 3D?
Jul 12, 2009 | Mitsubishi WS-55908 55" Rear Projection...
Cannot adjust convergence on Mitsubishi RPTV
as long as there is no bowing in the picture and the color does not want to move then there is probably just a bad resistor on the convergence IC that controls the color alignment , thus the resistors would have to be tested to find the low valued resistor on the IC
Nov 28, 2008 | Mitsubishi WS-55809 55" Rear Projection...
HDTV Mitsubishi WS-55819 55 Inch Diamond Shield
You will need to contact a Mitsubishi Authorized repair facility. The entire electronics package must be removed and sent back in to Mitsubishi. The problem is the Formatter circuit board which is no longer available as a replacement part. The repair cost is very expensive and must be quoted by the facility you contact not me. Expect 4-6 weeks turnaround.
Nov 28, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS-55908 Convergence Issue; need IC 7A00, Panasonic MN12857k MA2
Sorry, but when the coolant leaks down onto the small signal board, that board will never work right again. The fluid penetrates the board itself since the board is double sided and has many feed-throughs. The fluid gets under the surface mount parts and just eats through the copper traces, part leads and board itself. After trying many times to clean and restore those boards, not one has ever worked right again. The boards are NLA from Mitsubishi, so the set is done.
Aug 30, 2007 | Mitsubishi WS-55908 55" Rear Projection...
Distorted picture and multi-color words
ive got the same problem on mine ita a 2001 model and also mine when you turn it on it goes off by itself and wont stay on.also mine has multiple pictures one green and one red almost as if 3d im not sure what it cost to fix it but tvs have come down so much i might just buy a new one. good luck with yours
Aug 12, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
128 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
