Question about Olympus Camedia E-100RS Digital Camera
E-100 generic AC Adapter?
I'm wondering if I can use an el-cheapo AC adapter to power this camera (or any other digital camera, for that matter). I own a £5.99 Universal AC-DC Adaptor that I use for my CD player, practice amp, etc., and I'm wondering if it's safe to use it on the E-100RS. -It has 4 connector types, one which fits the E-100RS perfectly! -It has a polarity switch that I can set to conform to the the E-100RS. -It has a switch for 3, 4.5, 6, 7.5, 9, and 12V voltages On it, it lists the following specs: Input: 230V~50Hz 8.7W Output: 3,4.5,6,7.5,9,12V 300mA 3.6VA(max) So my question is: would this work? if so, which voltage setting should I use? what would the drawbacks be if I use this instead of the ridiculously overpriced Olympus chargers?
    Master:
  • 852 Answers
I doubt you can use 300 mA adapter,because Oly C2100 needs 2000 mA at 6,5V. E100RS construction seems to be very similar.
Posted on Sep 11, 2005
Battery usage?
Duracell are the equivalent of several cheapo batteries and
they dont leak! Cheapo batteries if they leak can damage your
camera really badly..dont ever leave them in the camera.
has the camera got a socket for an AC adaptor
May 31, 2014 | Nikon L28 CoolPix 20.1 MegaPixel Digital...
Lost my ac dc adapter need new one for rca small wonder camcorder
You can try www.ebay.com. I found the following AC adapter for the RCA Small Wonder camcorder:
http://cgi.ebay.com/RCA-EZ209HD-Small-Wonder-camera-CHARGER-AC-ADAPTER-/140516900106?pt=Batteries_Chargers&hash=item20b775bd0a#ht_1469wt_723
Mar 01, 2011 | Cameras
What size ac/dc adaptor do the dsc-s500 use lost mine christina@
You need this one:
Product Description
: Sony AC LS5K - power adapter
Product Type: Power adapter
Dimensions (WxDxH): 4.8 cm x 8.1 cm x 2.9 cm
Weight: 0.1 kg
Voltage Required: AC 100-240 V ( 50/60 Hz )
Voltage Provided: 4.2 V
Feb 02, 2010 | Sony Cyber-Shot DSC-S500 Digital Camera
My Kodak Easyshare V1233 will only power up when plugged into the wall charger. Even after staying on the charger it will not power on unless plugged in.
Kodak has 3 types of charger that can be connected to a wall socket
USB AC Adapter - is especially useful when traveling, away from your computer, or just plain on-the-go. Connect your camera's USB cable to the adapter and plug it into a wall outlet to conveniently charge your camera.
5V AC Adapter - Provides in-camera charging for all KODAK EASYSHARE M and V Series Digital Cameras
Input: AC 100-240 V 50/60 Hz Output : DC 5.0 V
3V AC Adapter - Provides direct power to your camera but it will not charge the camera battery
Input: AC 100-240 V 50/60 Hz Output : DC 3.0 V
* You need to check the type of adapter your using. If your using the 5V AC adapter or USB adapter and the camera won't charge the battery contact kodak support line 1 800 235 6325 (23KODAK) for possible repair.
Nov 16, 2009 | Kodak Easyshare V1233 12.1MP Digital...
Lost ac power adapter ac cord panasonic sdr-s7 camcorder
Go to Radio Shack, bring your camera, and they will sell you an AC adapter part number: 273-1696 for $30.
May 05, 2009 | Panasonic SDR-S7K Flash Media Camcorder
Power supply for Olympus fe-130
(In addition to the batteries provided with the camera, the following types of battery can be used. Choose the power source best suited to the situation.
AA alkaline batteries/ Oxyride batteries
The number of pictures that you can take may vary considerably depending on the
battery manufacturer and shooting conditions.
AA NiMH batteries (rechargeable batteries)
Olympus NiMH batteries are rechargeable and economical. For details, refer to the instruction manual for your charger.
(Lithium battery packs (CR-V3) and AA manganese (zinc-carbon) batteries
cannot be used.
(Power consumption by the camera varies depending on which functions are used.
(Power is consumed continuously during the conditions described below causing
batteries to become exhausted quickly.
• The zoom is used repeatedly.
• The shutter button is pressed halfway repeatedly in shooting mode, activating the auto focus.
• The monitor is left on for an extended period of time.
• The camera is connected to a computer or printer.
(The battery life varies greatly depending on the type of battery, manufacturer,
shooting conditions, etc. Because of this, there may be cases where the camera
turns itself off without displaying the battery level warning, or displays the battery
level warning sooner than usual.
The camera also has an optional accessory of an AC adapter that can be used as an alternative power source. It is model number E-7AU.
An AC adapter is useful for time-consuming tasks such as image downloads to
a computer or when running a slideshow for a long period of time.
To use the AC adapter with this camera, the optional multi-adapter (CB-MA1) is
necessary. Do not use any other AC adapter with this camera.
Note
• Do not remove or load the battery or connect or disconnect the AC adapter or
multi-adapter while the camera is on or the camera is connected to the other
equipment. Doing so could affect the camera’s internal settings or functions.
• The AC adapter can be used within the range of AC 100 V to AC 240 V (50/60
Hz). When using the shape of abroad, you may need a plug adapter to convert
the plug to match the AC wall outlet. For details, ask at your local electrical shop
or travel agent.
• Do not use travel voltage converters as they could damage the AC adapter.
Apr 16, 2009 | Olympus FE-130 Digital Camera
AC Adapter?
yes it runs on batteries (no eats batteries like a whale eats plankton)
see this:
http://www.amazon.com/Nikon-Adapter-Coolpix-Digital-Cameras/dp/B0001IVB0Y
Feb 27, 2007 | Nikon Coolpix 7600 Digital Camera
Won't turn on
Ouch! You can't use an AC adapter with any battery-operated equipment you choose to just because the plug fits physically. The A70 requires 5-6 volts, and a Pavilion adapter typically puts out 18 volts. You most probably blew out your Canon's power supply within a few seconds, unless it's fused somehow. Next stop: tech support/repair shop/camera cemetery. Sorry.
Aug 23, 2006 | Canon PowerShot A70 Digital Camera
AC-Adapter
The AC Adapter that is used with the S-HD-100 is the A-511 AC Adapter part number 200370,and can be purchased from the Olympus Emporium at http://www.olympusamerica.com/store, or by calling 1(800) 201-7766.
Sep 01, 2005 | Olympus i:robe IR-500 Digital Camera
Overseas Use
Yes. The power supplies and battery chargers supplied with all Powershot Digital Cameras are designed to work on input voltages from 100-240 volts (50/60 Hz). The only item that you may need is a plug adapter that allows you to plug the U.S. type power supply or battery charger into the foreign type wall outlet. Plug adapters should be easily available at a local electronics store.
Aug 31, 2005 | Canon PowerShot S10 Digital Camera
Olympus Camedia E-100RS Digital Camera Logo
51 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
