Question about Frigidaire Affinity ATF7000E Front Load Washer
Error codes where can i find the error codes and the troubleshooting manuel? Nicole
    Novelist:
  • 166 Answers
Online at Frigidaire .com you can find the manual.
With an error code the only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!
Posted on Sep 08, 2008
Unplugging the washer for a few minutes does NOTHING to fix this problem. In addition, no special diagnostics equipment is needed to read error codes. All you need is the ability to READ. Most error codes are available on a tech sheet that come swith the appliance. It is usually located inside the cabinet somewhere and also has troubleshooting tips and directions. Why buy a new appliance when you may able to repair your own for FREE?
Streaking after to water carpet cleaning
Hey Nicole! Streaking can occur when overlapping is not done.
Here's a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=22810&cid=ccsocial
Feb 18, 2013 | Bissell 9200P ProHeat 2X Pet Upright Deep...
I have a frigidaire wall oven which was on bake accidently hit clean and immediately hit cancel. Sounds like fan running and started beeping and F8 appeared. Turned off breaker and turned back on same
Hello - Typically error code F8 indicates that there is a communication error between the user interface and the control board. Try resetting the range by unplugging it or flipping the breaker off. Wait approximately ten minutes. If it proves to be ineffective, contact a professional to move forward accurately.
Nov 23, 2012 | Ovens
1985 ford f250 6.9 liter manuel
You can buy a used one here. and here for electrical troubleshooting. We however do not have repair manuals
Nov 04, 2012 | 1985 Ford F 250
My 7kg LG front loader WD-80134T showed a UE error. Please can you tell me what this means and where can I get the manuel?
This is an imbalance error code. Too small of a load will cause this error code.
-Check and rebalance the load
-Make sure Washing Machine is level
-Redistribute the load evenly
May 15, 2012 | Washing Machines
We have a Bosh GWH2400ENG Tankless Water Heater. I cannot seem to get the unit to produce any hot water at all or if I can get it to start to produce hot water it does for mabey a minute and then shuts...
Look for the error code on heater. Go to: http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ETechSupport/Troubleshooting/tabid/1131/Default.aspx
For technical support on your heater.
Apr 23, 2011 | Bosch AquaStar 2400ES-NG
DL F code keeps flashing
"Fdl" is a door latch error code. This is an indication of either a defective door latch, defective Central Control Unit (CCU), or an interconnecting cable problem between the two. The following link explains how to troubleshoot the problem:
http://www.fixya.com/support/r4490349-fdl_error_code
I have included parts resources, if required, and the steps required to replace any defective parts. Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
In some cases, the error occurs when the washer is in the middle of the wash cycle. If the door remains locked and will not open, the following link explains how you can use the manual release to get the door to open:
http://www.fixya.com/support/r3576511-door_jam_on_kenmore_elite_and_whirlpool_
You may want to try using a wet/dry shop vac to pull a vacuum on the drain hose to try to pull as much of the water (if any) ot of the wash tub BEFORE opening the door.
NOTE: The error codes are NOT listed in the Owner's Manual. For a complete explanation of all the error codes, each one of these appliances comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to accurately troubleshoot this problem.
Read through the information provided and let me know if you have any further questions. I hope you find this information helpful.
Jun 07, 2010 | Kenmore HE2 Plus Front Load Washer
E10 code
I believe E10 means there is a draining problem. Check your drain hose and see if that is where it should be and not clogged. If that is okay, most likely your pump is clogged.
Aug 28, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF7000E Front Load Washer Logo
237 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
