Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
Error: Initlializing.........
After power up the machine, lcd displays POST tests, but stuck in the "Initializing...." state. HDD in other machine -ie. laptop- is good. The electronic module fan not start.
  • tcordes Jan 30, 2009
    "Me too". You can leave it for hours and it never gets past the "initializing". No error code. I do not know if the fan is on or not, or what fan is supposed to come on at that time. I reseated all cables. No help.
    The Xerox phone help says it is the top scanner/panel part, $650 quote. Out of warranty.
    President:
  • 2,072 Answers
If the fan is not running you most likely have lost either the 24 or 40 volt source which would require replacing the electronic module itself.
The machine never faults out with a XX,XXX,XXX,XXXXX style code.
Like 004,010,045,2333 ??
That is very odd that a code like that does not show up. It can take 15 or 20 minutes to pop up.
But if the fan is not running, there is a missing source voltage.There is no separate low voltage power supply on that machine, and Xerox is horribly expensive on that module. With my discount as a dealer service rep, that module is over $1100 wholesale. It should not be anything related to peripherals
Posted on Aug 30, 2008
8560 printer shut itself down and will not true back on
The following lists the chain of events that occur when you turn on a printer. You can follow this list as one means of determining if the printer is operating correctly. The exact chain of events depends upon the last power down condition and where the printer has last determined the printhead is positioned, this is stored in non-volatile RAM. The Checklist is the primary reference for troubleshooting power-up problems.
1. Power cord is plugged in and the power switch is turned on:
2. Power supply senses AC line voltage conditions (110 VAC or 220 VAC)
and enables DC voltages. If an overload occurs, the printer turns off the high voltage DC supplies, causing a "blink" effect on the Control Panel LEDs.
3. BIST test flashes the PE LED very briefly at a fast rate until the end of the
next test.
4. The Boot loader performs CPU initialization and RAM test. It then sends
the boot loader version to the serial port.
5. Power-On Self Test (POST) initializes the Control Panel. The Control
Panel LED turns red, green, orange, and then off. The Control Panel LCD then goes black and then clear. The POST version displays on the LCD
and waits two seconds. During this time the operator can press the Back
button to bypass the remaining POST test.
6. Low level Power-On Self Test (POST) diagnostics are performed. The
Control Panel displays status messages as each sub-test is performed.
This test takes about 8 seconds. All LEDs are off during the test.
If POST diagnostics pass, the Control Panel displays the Xerox logo and turns on the green LED.
If the test detects an error, the error message displays on the LCD and the printer flashes the LEDs with a repeating error code pattern.
7. The VxWorks operating system is initialized and engine code is started.
This takes about 15 seconds. The Xerox logo is displayed.
8. Print Engine Self Test (PEST) diagnostics are then performed. These test
the heaters, clutches, motors and solenoids. As each clutch is tested, you hear clicking with four high tones as each motor is tested. This test takes about 30 seconds.
9. The printer now runs the mechanical initialization. The exact sequence
depends on the initial position of the printhead and wiper assembly.
Feb 28, 2014 | Xerox Phaser 8560MFP Laser Printer
8560 shut down and will not turn back on
next test.
Panel LED turns red, green, orange, and then off. The Control Panel LCD then goes black and then clear. The POST version displays on the LCD and waits two seconds.
During this time the operator can press the Back button to bypass the remaining POST test.
Control Panel displays status messages as each sub-test is performed. This test takes about 8 seconds. All LEDs are off during the test. If POST diagnostics pass, the Control Panel displays the Xerox logo and turns on the green LED.
I have a problem Taskalfa 250ci eror code c0640 I think at Hdd problem. But I don't know how to hdd format
Maintenance
item No.
U021
Memory initializing
Description
Initializes all settings, except those pertinent to the type of machine, namely each counter, service call history
and mode setting. Also initializes backup RAM according to region specification selected in maintenance item
U252 Setting the destination.
Refer to *1 of the maintenance mode item list about the item initialized.
Purpose
To return the machine settings to their factory default.
Method
1. Press the start key.
2. Press [EXECUTE] on the touch panel.
3. Press the start key. All data other than that for adjustments due to variations between machines is initial-
ized based on the destination setting.
4. Turn the main power switch off and on.
For errors occurred, turn main power switch off then on, and execute initialization.
Error codes
U024
HDD formatting
Description
Initializes the hard disk.
In addition, the following settings are also initialized by initializing the hard disk.
System menu (user login administration, job accounting, address book, one-touch keys and document box
etc.), shortcuts and panel programs
Purpose
To initialize the hard disk when replacing the hard disk after shipping.
Method
3. Press the start key to initialize the hard disk.
Description
Codes Description
01 Configuration initialization error
02 Counter initialization error
20 Engine initialization error
40 Scanner initialization error
2JZ/2JX/2JV/2H7-5
1-3-23
Apr 15, 2013 | Kyocera Taskalfa 250ci Color Copier...
MPC 2550. What is error code sc 865 01?
SC865 (HDD access error) is displayed when the power is turned ON, and SC819 (kernel stopped) is displayed when the power is turned OFF and ON.
Some broken files may be left in the HDD image disk space.
Repair by initializing the HDD image disk space (SP5-832-002).
Dec 17, 2012 | Ricoh Office Equipment & Supplies
I have dv2840ee laptop. no display, power on. i remove coms battry, i put the lcd monitor. display came. but i go to bios appear only hdd test and rem test . system Bios shadowed & video bios shadowed...
This model has a common issue where the video chipset solder joints break and cause graphics issues.It requires fe flowing of the graphics chipset or a replacement motherboard.
Mar 12, 2012 | Computers & Internet
Thinkpad r40 wont boot - has no post beeps- lights come on- then go out except for 2 .Was told it could be a graphics card problem or a screen issue- by someone on a geek squad. They apparently don't know...
During the boot at the THINKPAD SCREEN press the Thinkvantage key ( Blue button ) it will launch rescue and recovery and allow you to reboot factory. This only works if you did not corrupted/deleted the rescue and recovery hidden partition on the HDD. Otherwise you will need the rescue and recovery CD to proceed. IBM/Lenovo support should be able to provide you the CD.
Might be a defective hdd aswell, in this case to make sure you can run a DFT test, www.google.com -> Look up for " Test DFT " ( Drive fitness tool from hitachi, will make an hardware diag if hdd failure - error code 0x00 = everything fine, other code = Issue - You can look up for accurate code explanation on hitachi website )
As well might be a LCD/Motherboard/Graphic card issue in this case might be related to 3 part, Inverter card, LCD cable or LCD Panel ( Or systemboard, just to make sure try with an external display if the issue reproduce it's systemboard/graphic card related, if not LCD related ).
If you are still entitled to warranty then all theses hardware failures are covered by the terms. You should have the parts stated below replaced as it s a common issue with Thinkpads.
In case you are out of warranty cover you still can try to subscribe to a warranty extension, you can check on www.lenovo.com , otherwise you might want to order theses parts on a website such as ebay.
To swap the pieces requires quiet advanced skills as you might have to take down the whole computer, obviously LCD Panel included ( Unless it's hdd related )
Unfortunalty this is hardware related, not much you can do...
thanks and have a nice day J-
Feb 19, 2010 | IBM ThinkPad R40 2722 Notebook
XEROX Phaser 8560MFP won't go past "initializing?"
Disconnect the data cable between the Electronics Module and the Printhead to see if Power On Self Test (POST) gets further, to the point where it displays a system failure code relating to the Printhead being disconnected. If so, replace defective printhead.
Dec 12, 2009 | Xerox Phaser 8560MFP Laser Printer
Lexmark T642 When printing, LCD displays
this error is a scanner lost lock error and can be caused by the scanner or the logic board. if this error comes up immediately on power up the scanner motor is not initializing by percentages of failure the scanner is approximately 85% the logic board 15% i would change the scanner
Nov 23, 2009 | Lexmark T642 Laser Printer
After Power On Self Test (POST) my Dell Optiplex GX110 displayed the a error? Now it does not start up at all even if I used a new power supply. Please help...
try running a test on the hdd.generally it comes up with the error code,in case not try disconnecting all the peripherals & try doing the FLEA POWER(After disconnecting the power source try pressing the power button for about 20 seconds,then try to restart the computer).
Apr 02, 2009 | Dell OptiPlex GX110 PC Desktop
Canon ir 2016 is not initializing
there is a problem on software.if you know how to update the firmware, thats the solution
Dec 02, 2008 | Canon imageRUNNER 2200
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
278 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
