Question about Apple iMac G4 Desktop
IMAC snaps off during operation Console says cause - 122
My IMAC G4 (five years old) just snaps off sometimes after 10 minutes operation, sometimes a half hour or hour. If left off for a while you can always start it again but it will shut off again after a while.. The last line of console when it does this is " PMU forced shutdown, cause = - 122
What is that and how can it be fixed?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 199 Answers
Sounds like a power supply issue. You will need to take this to an apple dealer and ask them about it. This one is not an easy fix as it is a hardware fault.
Posted on Sep 08, 2008
Imac G4 0s 10,4.11 need a flash to watch hulu free tv
You can't watch Hulu on a PowerPC iMac G4. You need an Intel processor based Mac to watch Hulu and Netflix.
Dec 19, 2012 | Apple A1106 Powerbook G4 15", 1.67 Ghz,...
Safari doesn't work on this used Imac G4 I just bought, but Camino does work? How do I get Safari working on this old thing?
On the left Top of your monitor is a apple Logo.Tip on it and select "About that Mac" A Window pops up and you select "More Info" it shows you the OSX on it. OSX 10.3 or OSX 10.4 Google "Safari Browser for OSX 10.? " Download it and it will work. You may have the latest Version.
Oct 04, 2010 | Apple iMac G4 Desktop
Imac g4 won't start but shuts down when apple logo appears on screen
Are you sure the iMac is really shutting down or just turning off the backlight? The tell-tale sing would be to let the unit fully boot-up (wait 3 minutes) and the press the button the apple keyboard that ejects the CD-ROM. If the CD-ROM door opens, you iMac is running with disabled or broken backlight.
The inverter circuit on the iMac G4 is known to be weak.
There could be another problem, though. The iMac G4 is also known to have weak internal power supplies. Here's how you can tell:
Hold down the CMD OPT "O" and "F" keys at the same time while pressing the power button. This will tell the iMac that you want to boot into the Open Firmware shell, bypassing the Mac OS X startup. If this works, your power supply is good, the inverter is good and you have a problem with your Open Firmware boot string. To fix the boot string, Power on the unit while holding down the keys CMD-OPT-P-R to zap the parameter RAM (PRAM) and reset everything to defaults.
If you were not able to boot into the Open Firmware shell, your problem is either a failed power supply or a failed screen backlight. The last possible culprit is your iMac could suffer from "Bulging Capacitor Syndrome", where a batch of iMac G4s, iMac G5s another electronics were fitted with a bad batch of capacitors. Eventually, the caps will rupture and cause irreparable damage to the logic board. Only way to verify this is to pull the unit apart and visually inspect. If you see little green or blue cylinders that seem to be bulging or oozing a thick oily goo, that's your problem. Only recourse is to shop around on eBay and look for a replacement logic board.
May 30, 2010 | Apple iMac G4 Desktop
Unable to turn on the computer and power supply is OK because other devices are plugged into it. Tried procedure in apple manual which says to hold down power button and at same time hold down 4 buttons on...
The iMac G4 will refuse to turn on if the logic board battery is dead. Since this model Macintosh is now about eight years old, it's quite reasonable to suspect your battery is dead. Battery replacement is a relatively simple task for a certified technician, but unfortunately the battery in this model is not a user-replaceable part.
Mar 12, 2010 | Apple iMac G4 Desktop
Can I connect my apollo 2250 to my old imac?
OS X drivers for the Apollo 2250 apparently exist only in 10.5 and 10.6, both of which your iMac G4 is too old to run.
If you have this printer attached to another computer on your home network, you could activate printer sharing and allow your G4 to print to it that way.
Mar 11, 2010 | Apple iMac G4 Desktop
Imac g4 lcd black screen replaced pram battery
If you can find an older SVGA monitor, try hooking it up to the port on the back of your mac. If you get video then chances are the LCD display is shot.
Sep 01, 2009 | Apple iMac G4 Desktop
DVD player skips audio and/or frames
PowerBook G4 is at least a five-year-old machine at this point. A DVD drive can **** in lots of dust in five years. Try hooking up to an external DVD drive. If it plays the same discs with no problem, you need a cleaning or replacement. Frankly, an external DVD drive is cheaper than replacing your internal drive.
Mar 07, 2009 | Apple PowerBook G4 Mac Notebook
The screen on my Apple Powerbook G4 goes dim and sometimes out.
How long before it goes dim?
Does it start strong, then dims right away?
Feb 27, 2009 | Apple iMac G4 Desktop
Problem with Apple imac Power Supply
The most common problem with imac G4/800's are failing logic-boards. This will cause the mac to not power up at all giving the impression that the PSU is broken.
If however, you are indeed certain that the fault is with the power supply, they are available from many stores online
Power Supply for iMac G4 15" LCD (700 & 800 Mhz) 661-3184 614-0147
Dec 09, 2008 | Apple iMac G4 Desktop
Apple iMac G4 Desktop Logo
70 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
MarkMAlford
MarkMAlford
Level 1 Expert
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
