Question about Toshiba e740 Pocket PC
Water in the touchscreen
Some water got into the touchscreen. I wanted to set it up again but the touchscreen doesn't seem to be responsive any more. Is there any way to fix this?
    Master:
  • 903 Answers
The only thing I can think of is to remove the battery, then use a blowdryer on low heat to help evaporate any water still remaining in it before it causes any more damage. Once you think it's completely dry, pop the battery back (after drying it off) in and try to turn it on. (Note: Don't risk plugging it in for a charge for a while, as electricity and water don't usually mix.) If it turns on but the screen doesn't work, you can still recover any data on it, followed by the option of having the screen repaired or replace the PDA. If it doesn't turn on at all, pray you have a backup of the data.
Posted on Sep 11, 2005
SOURCE:
Dropped my Huawei Ascend at work in a mixture of water and hydraulic oil.
take the phone apart again clean the inside of the phone with denatured alcohol to get rid of the corrosion. If that does not work then try to replace the screen and digitizer
Feb 02, 2013 | Huawei Ascend
Whirlpool dishwasher wont wash
if the bottom tub is filling with water but not washing the issues is with the wash motor, some of this model use a start capacitor that can fail, if it has a capacitor on the side of the motor it may have failed but are difficult to diagnose but are cheap to replace so worth trying, if this doesn't help or if it doesn't have a capacitor then the fault is with the wash motor.
Mar 08, 2012 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dropped my phone in water and now the touchscreen doesn't work at all
Hello there,
You will have to disassemble the phone, then try to dry it with a hand dryer. Do not place it too close to the phone so you will not damage any part inside the phone. Then reassemble the phone back together and the touch screen will work perfectly fine once again.
All the best. Elect_Comp
Sep 13, 2011 | Pantech Cell Phones
Water doesn't seems to get into the dishwasher
HI,
Is it no water or little water? You could have a clogged inlet valve and this could be the cause. Check your water source coming into the unit, clean the screen and try again. Look for kinked water supply line as this can cause the same problem.
If this is not the case, get back to me with what you find out.
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Sep 09, 2011 | Asko 1385 Dishwasher
When I put a new 4 gallon bottle of water onto the dispenser there always seems to be a problem dispensing the water. The water doesn't seem to be flowing into the machine.. I have tried draining the...
hi lorna. i suspect that there is a partial blockage in the water's pathway. When it is convenient for that pathway to be checked, use a flashlight, and some pipe cleaners, and perhaps a pair of needle nosed tweezers or pliers to remove that blockage. Joe
May 18, 2011 | Refrigerators
My flapper was leaking, so I replaced it. Now, when I flush, the water leaves the toilet bowl, fills the bowl, and wants to flush again. All the water wants to leave the tank, but the toilet doesn't...
Reset the fill valve so that it does not fill the tank so full....this will be easier then trying to find a different flapper that will drop down faster, which is the only other thing you can do...
heatman101
May 15, 2011 | Plumbing
My touchscreen doesn't work,
Usually when touch screen doesn't work, it's a sign of water damage. It's also possible that you dropped it at some point and ruined the sensors inside. But it's PROBABLY water damage. What you can do is bring it to your phone carrier's closest store and ask them to check if your phone suffered water damage. They'll open the phone up and look. If it is water damage, you'll probably have to pay for a new one...If you're insured, it probably won't be that expensive.
The good news is, if you bring it there and it ISN'T water damage, you probably won't have to pay anything at all for them to replace it. Hope this helps!
Please rate my solution!
- Frankie
May 06, 2011 | Samsung Star GT-S5233 Cell Phone
Toshiba e740 Pocket PC Logo
42 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
