Question about HP PSC 1610 All-In-One InkJet Printer
  • 111 Answers
You don't say so in your post, but I'm assuming you ran out of paper and you added more paper to the printer. You could try unplugging the printer's power cord, waiting about 30 seconds or so, and then plugging it back in to see if that will clear the error message.
The HP web site also has a page that offers more solutions:
Out of Paper Error
Hope this helps. Good luck.
Posted on Oct 07, 2008
5 Suggested Answers
  • 3 Answers
SOURCE: will not print and keep getting paper thickness error
Did you try moving the paper thickness lever (blue lever on top of the print cartridge holder)? It should be all the way to the left when you start--if it needs to be adjusted the printer message will let you know.
Posted on Aug 02, 2009
  • 51 Answers
SOURCE: paper jams??
click here to download yor required drivers
Posted on May 12, 2010
  • 2973 Answers
SOURCE: Following a recent paper jam my Epson RX510 will
Please un and re install the device as per the link below:-
Posted on Aug 21, 2010
  • 5 Answers
The fuser sensor may look ok, but if you pull off the back cover and study closer, you may find that the lower half of the right toggle sensor is broken, leading the sensor to "think" that is is stuck in the open postition. As a temporary fix, unplug that sensor from the fuser board. Ultimately you will have to replace that switch, and that is a hard part to find unless you replace the fuser unit.
Posted on Nov 12, 2011
Jam in duplex area
Its is trick..If its more then two pages print, printer grabs second page even first page in duplex unit., here its confusion. Check with simplex single print, see any paper mismatch error? or printer throwing paper in output bin after successful print?. No.. check fuser out sensor or paper out roller.
Print only two pages matter in duplex, check where paper struck? if paper our roller not grabbing paper back properly in time (slipping while grabbing back) gets jam error.
Always ensure that select proper paper size in printer.Other than this it may major issue, need technical knowledge..& possibilities are less to judge the exact problem..
Keep update us to resolve the issue.
Aug 22, 2014 | HP Color LaserJet Professional CP5225dn...
Printer error 3533 CJX-1050W
too much paper being put into slot. paper it static so fan it beofre putting in
Feb 11, 2013 | Office Equipment & Supplies
Keeps showing 900.57 firmware error and the paper gets stuck
Power the printer OFF and ON. Send the same file to the printer, if file has not been released from the print queue then delete all pending print jobs out of print queue.
Disconnect all data cables and power the printer OFF and ON. If the printer returns to READY, Reconnect the data cable and try printing again. If you are getting a paper jam error, please take not the error code and locate the jam. For further assistance, please contact Lexmark Technical Support.
Apr 06, 2011 | Lexmark T652DN MONO LASER PRINTER...
Pixma MX700.Error code 5100 . Paper from rear printing stuck in printer. Please advise.
Hi You can Try
Error Code 5100 You need to get ant bits paper from it first, no easy way just go to get in to it and get it out try turning the rollers by hand.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Jan 29, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Not printing properly
if its printing junk prints please reinstall the printer driver and check
if its printer unclear print please replace the ink and check
Dec 28, 2009 | HP DeskJet 1120cse InkJet Printer
Deskjet 932C. Won't feed paper.
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Sep 24, 2009 | HP DeskJet 932c InkJet Printer
Phaser 8400 won't print.
pull out the paper drawer and look on the ceiling of the compartment. you will see a little orange rubber roller that should be clicked inplace. it feeds the paper up into the roller. also, the drawer itself contains two sensors. if you go to the xerox page you can download the pdf that lists all the parts and the errors and how to disassemble the whole thing. i have the same printer and got a print head error and a paper jam that required complete disassembly. feel free to email me for additional help.
Jun 19, 2009 | Xerox Phaser 8400 Laser Printer
Printer Canon Pixma MP830 will not print
You can try
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Mar 08, 2009 | HP LaserJet 1012 Printer
Hp psc 1219
dear szaszy
as per your information your printer paper jam sensor is having problem.Please get it serviced
Apr 04, 2008 | Office Equipment & Supplies
HP PSC 1610 All-In-One InkJet Printer Logo
69 people viewed this question
Ben Johnson
