Question about Zebra Office Equipment & Supplies
Part needed Zebra PAX 170 print engine
Need the Rear PCB serial board part number 49720 REV. 2
Wow i love it, i place a post in the "forum" and hours later im asked to join a Preimum service for a fee, that im expected to feel good that for the feel my search can be solved............ oh but wait in the same breath im asked if i solved my own problem to post what i did to solve it............. for FREE,
yeah guess i came to the wrong web site, thanks but no thanks
Posted on Aug 30, 2008
I want when printing out the tag a serial number be attached to it. and also be printed out. how can i do that
This is not a function of the printer, it is a function of the softweare driving the printer. ie Zebra Designer, this can be obtained as a free download, contact www.lancerlabels.co.uk for advice on how to do this. Experts in Zebra printer problem solving.
Feb 24, 2016 | Zebra TLP 2844-Z Thermal Label Printer
Error code E000350-0001 in ir3300
Its the serial number board. Someone swapped the main controller out and didn't change the small serial number pcb with it. That board HAS to be returned to the machine or it will not function. Only way to get a new board is through Canon engineering.
Feb 11, 2015 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
Zebra 170 xi manual
You can download one direct from Zebra at
http://www.zebra.com/content/dam/zebra/manuals/en-us/printer/xiiiiplus-ug-en.pdf
Mar 14, 2013 | Office Equipment & Supplies
Zebra S600 - Printer pauses after each printed numbered label, if I don't number them it works fine?
It sounds like your labelling software is re-sending the entire print job each time. Do some research with your software and see if you can change the defaults so that everything BUT the serial number is stored inside the printer, and only the new serial number is sent.
It's difficult to be more specific because every software package is different...
Feb 10, 2012 | Zebra Stripe S600 Thermal Label Printer
I need to add network to 2844 printer currently USB/Serial
You need to buy the zebranet PS2 print server
P/N G46692 External PrintServer II. It will plug into the parallel port. they just stoped making them but they are still for sale at zebra resellers. here is one at random from google
resize?sq=80&uid=1127727233 ZEBRA G46692 EXTERNAL PARALLEL PRINT SERVER II
more at ZDTronic.com
ZDTronic.com $160.50
  • product
ZEBRA G46692 EXTERNAL PARALLEL PRINT SERVER II ZEBRA G46692 EXTERNAL PARALLEL PRINT SERVER II $160.50 at ZDTronic.com
May 12, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Zebra 105SL Prints fine through Zebra Setup Utility, but prints plain text when file copied to port. Win XP. The setup utility can never get Version Info from the printer, but Windows shows the printer...
possible fonts issue. try to change the font from the text, check setings from the driver.
try to print from the driver (test print)
Try to print from Word (need to ajust the page) with diferents text fonts.
you can check the correct firmware ( be ware with the information about the serial number) ATENTION!!! wrong firmware can cause PRINTER DEAD!!!
Install lates firmware to the printer.
Oct 12, 2009 | Zebra 105SL Thermal Label Printer
Samsung HD 42inch TV Model No. PS42S5H Y Board
Your board numbers should start with LJ92. They will cross to both Samsung and LG. Oh, your model number goes nowhere, double check it.
Aug 25, 2009 | Televison & Video
Zebra 170 xi labela are printing on top of each other
Don't forget to rate this.
You can download Zebra manulas from here. https://www.zebra.com/id/zebra/na/en/index/service_support.html here is a section of the calibration you require. Sorry it will not allow me to attach. i think issue with site usage.
Anyway press PAUSE to pause printer. Then find & press CALIBRATION, it will ask when you want to calibrate either at power up or after the print head is open & closed. I would select Power up since when you change lables out you should do so with printer off.
Good luck, post any questions to this & also rate it.
Feb 04, 2009 | Zebra 170Xi II Thermal Printer
We have printing serial number and found duplicated in sometime
Serial numbers are often printed by custom database applications.
If you've got duplicates, you will need to adjust the counter in the database. Talk to the database programmer.
Nov 18, 2008 | Zebra Office Equipment & Supplies
187 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
