Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA HDTV WILL NOT COME ON LIGHT BLINKS 3X
WHEN I TRY TO TURN ON THE TV GREEN INDICATOR LIGHT BLINKS 3X AND IT USED TO COME ON AFTER ABOUT 20 TRIES, BUT NOW WILL NOT COME ON AT ALL. WHAT IS THE PROBLEM?
    Problem Solver:
  • 11 Answers
Look for a buldg cap. in power supply, (on board) behind heat sink.
Posted on Aug 29, 2008
  • RCA Master
  • 8,617 Answers
Thats the error could for a bad flyback. You can get a replacement flyback at the following link with free tech support to take you through the steps to replace it. You need flyback number 259296.
Heres the link
http://servicemanuals.vstore.ca/
When turning television on the power light flashes green 3x then red 3x the television does not come on lamp is still good
Thats indicating that either the lamp door isnt contacting its safety interlock switch, or the lamp isnt seated correctly. They will both throw a 3 blink error code.
Aug 09, 2011 | Sony KDF-50E2000 50" HDTV
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
TV does not power up
I have mits 35" CS 3505 will not turn on... just turned off and thats all she wrote,,, what is the estimate cost of the deflection circuit board
thanks
artie
Jul 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52 in. Rear Projection HDTV power light blinking
Liz, yes it is a power supply problem, better question is; low voltage or high voltage power supply ? count the blink code, it should repeat the code, once you have the code call your local tv shops and give them the model number of your tv and the blink amount and they`ll tell you price to fix, gl, video-tek
Jun 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA TV Will Not Power On - Powered Off Suddenly
Theses sets had 2 problems pip mod or most of the time Flyback Transfomer bad.
Jul 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have the same problem. Just Monday it started, Green light blinks but nothing comes on. Any suggestions?
May 31, 2008 | RCA HD52W59 HDTV Projection Television
Dont have a remote
A green blinking light usually indicates an internal problem. The service person can use the pattern of the blinks to determine the problem.
Jan 08, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
54 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
