Question about Toshiba Satellite A45-S250 Notebook
A45 hard drive problem
Thank you for your very prompt response. i do appreciate any help.
initially, the machine would begin to boot up, go to the windows xp screen, run for a few seconds then shut down. it would then start again on it's own and run through the same process. even with the lid shut it would continue this unless i shut the machine off manually.
the error message when i tried to run the recovery disk did refer to some sort of a sector problem on the hard drive and said something along the lines of 'if problem persists contact the manufacturer'.
i have another a45 which i am using right now; if i try to trade this drive into the non-working machine will this help isolate the issue? or will this put the usable drive at risk?
doug
    President:
  • 2,961 Answers
No if you change harddrives the drive wont boot as all the drivers are different and windows looks for hardware already installed
Posted on Sep 01, 2008
Toshiba Qosimo stopped on startup logo, unresponsive to commands
I used this same response in a previous solution....It mostly looks like your installation of Windows has been corrupted....some system files may have been affected. See if you can find the recovery disk for your machine. One of the things you can try is use the CD as your boot disk (you may need to enter the BIOS or SETUP to change the boot order...there will be a key to hit when you see the Toshiba splash screen when you first boot the machine...it will say press "<some key here>" to enter setup.)
Once you boot from the disk I would try getting to a command prompt and running the following command: chkdsk c: /f /r
This will scan and repair any bad sectors on your hard drive and if they can be repaired it may make your machine bootable again. If they cannot be repaired, it may be that your hard drive is dying. ither way...if you get into the machine (even from the boot disk) if you can see the drive, I'd recommend backing up whatever files you can, because if the drive dies, you will lose your data. You may also use a Linux LIVE CD ... this basically boots a version of linux from a disk rather than your hard drive, it may allow you to test hardware and back up files as necessary before thinking about reinstalling Windows.
Feb 28, 2013 | Toshiba Computers & Internet
Compaq Presario pops up a system boot menu everytime at startup.
This comes up mostly when it requires a BIOS save. Try that. If that does not help, sometimes setting the default settings and saving will help.
Dec 04, 2012 | Computers & Internet
Windows xp is not starting
Windows XP is a fairly stable and secure operating system, but errors and other problems will occur from time to time. Unfortunately, some of these errors can damage or corrupt important system files and can lead to Windows XP not booting up correctly. You can repair your Windows XP installation using a process known as a "repair install," overwriting the damaged system files with new versions from your Windows XP installation disc. The repair install process takes approximately one hour, though a large portion of this time will not require any input from you.
1,Start your computer and place the Windows XP installation disc in the drive. If the computer is crashing upon attempting to boot, allow it to restart; otherwise, reboot the computer manually.
2.Press a key to boot from the Windows XP CD if prompted to do so when the computer attempts to boot again. If you are not prompted to boot from the CD, restart the computer again and press the indicated key on the initial BIOS screen to access the "Boot Order" or "Boot Sequence" menu. Select the CD or DVD drive containing the Windows XP installation CD, then press a key when prompted to boot from the disc.
3.Press the "Enter" key on the initial Windows XP welcome screen and press "Enter" again to begin setting up Windows XP. Do not press the key indicated to launch the "Recovery Console," as the Windows XP recovery console is not used to repair corrupted XP installations.
4.Accept the user agreement and wait while the setup program scans your hard drive.
5.Press the "R" key when the Windows XP setup program lists the installed version of XP that it detected to begin the repair installation. If you have more than one version of Windows XP installed, make sure that the proper version is listed before pressing "R."
6.Wait while the Windows XP setup program copies files to your hard drive and begins the installation process. The installation will take 45 minutes or longer, depending on the speed of your computer, during which time all of the Windows XP system files will be overwritten.
7.Confirm your user information as well as the date and time settings on your computer, and enter your Windows XP product key when prompted. Allow the operating system to connect to the Microsoft authentication servers to activate itself.
8.Reinstall any hardware drivers and XP Service Packs that you had previously installed, as your copy of Windows XP will have reverted to the basic installation you had when it was first installed.
I hope you find it very helpful.
Aug 25, 2011 | Gateway Computers & Internet
I have a toshiba satellite A45-S250 that i am replacing a bad hard drive on. I do not have a working dvd-rw drive at the moment. I was wondering how i can install windows xp on the new hard drive if ...
I am not sure what BIOS that system has, but if it does not support USB booting, then you could try borrowing an external disk drive from a friend, the BIOS should at least recognize that and allow you to boot from it.
You could also see if you can upgrade the BIOS to get the functionality you want.
When was this laptop made? I can think of any system made in the last 10 years what wont boot from USB.
Jul 21, 2011 | Computers & Internet
How do I replace a Toshiba Satellite A45-S120/40 (PSA40U-06FV3V) Hard Drive? I just need the instructions. Thank you very much, Eladio
There should be a panel or two on the bottom... one will cover the memory, the other should cover the hard drive. Open them up to find the hard drive. Remember to unplug and pull the battery out before you begin.
Apr 03, 2011 | Toshiba Satellite A45-S120 Notebook
Disk read error
kindly chek the drive connection make sure the cable is properly connected if possible then change the power connector of the hard disk.and boot the system in safe mode and go to command prompt and type chkdsk /r /f and restart the system.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 22, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
I have a laptop Toshiba satellite A30. I have a black screen and some text on it like: PXE-E61 MediaTest Failure PXE-M0F Exiting PXE ROM and it goes continiously, I can't go any further. When I was loaded...
media test failure means that your boot drive has failed ie your hard drive has failed to boot....could be one of a number of reasons
1 hard drive connection could be loose - try taking out the hard drive and reinstalling it
2 the boot sector on the hard drive is corrupt or damaged - try booting off a windows disk and running chkdsk or fixboot command
3 partition table is corrupt - try booting off windows cd and running chkdsk /p from command prompt
4 Hard drive has failed - if machine is still under warranty return for repair if not install new hard drive and reload op system from recovery disks
Dec 05, 2008 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
Toshiba a45 restore problem
Did the drive fail to boot initially and thats why you did a recovery unfortunately the hard drive has either failed and must have a damaged sector,or the recovery partition on the drive is stopping the format, which will more than likely be the problem.
The recovery disc you have won't be a full windows copy only a restore disc for your notebook, and it will look for a backup folder residing on another partition on your drive.
The only way to get a full format is to use a freinds copy of windows to format it and then install windows using your product key code on the underside of your notebook, unless you buy a copy in which case use the code provided
Aug 29, 2008 | Toshiba Satellite A45-S250 Notebook
Toshiba Satellite A45-S250 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
