Question about Kenmore 43142 Front Load Washer
Sd error when laundry done
Not all the time, but about 1/2 of the time...I will go to unload the front loader and the code Sd is on the screen...what does this mean? Did you experience this and how did you fix it? HELP!
I only use HE and we use no more than the max...actually much less....machine is three months old too.
Posted on Sep 01, 2008
Sd represents too much soap in the cycle. Try using HE detergent and in less quantities. Worked for us.
Posted on Aug 31, 2008
Why do Whirlpool Duet washers have such a problem with "over sudsing"? And how to prevent it?
The "oversudsing" problem is usually due to operator error. These new front loaders require the use of HE laundry detergents. These greatly reduce the sudsing issue. They also require VERY LITTLE detergent. For example, a normal-size laundry load only requires 1-2 TEASPOONS of HE laundry detergent. Most folks use much more than that, causing a possibility of oversudsing.
See this link for more info.
What Is HE Laundry Detergent And Do You Need It
Aug 08, 2016 | Whirlpool Duet GHW9150P Front Load Washer
Tip
We purchased our Kenmore front loader when they first came out. Shortly after,...
This advice is for preventing or getting rid off that awful mildew smell associated with front loader style washing machines.
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
on Apr 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I have a Kenmore HE2Plus - it is 6 years old. All of a sudden two days ago I got up to a load of laundry not done, full of water and the code F21. We have gone through most all of your suggestions. At...
The Sd code appears when sud is detected but it may also indicate draining problem such as blocked drain filter or broken drain pump as signified by the long drain error code F21. The drain pump impeller may be broken or restricted resulting in poor draining or no draining at all or the drain pump motor is faulty. Since the drain hose and filter have been cleaned but the error code still persists, the drain pump likely needs to be replaced. Click on the link below for the detailed troubleshooting instructions.
Troubleshooting Error Code F02/F21 on Kenmore Elite and Whirlpool Duet Front Load Washing
Jun 18, 2011 | Washing Machines
Maytag laundry neptune front loader washer MAH6700AWW. It is showing a E3 code error. what can we do for that
Hi, the E3 error means that the control board is detecting current going to the motor, but the motor won't turn properly. If the error code comes up all the time as soon as you press the power on button, then it means your control board is bad and reading incorrectly. If it only happens during a cycle, then you need a new motor unfortunately.
Jun 16, 2011 | Maytag MAH6700AWW Neptune Front-Load...
LE code is flashing when I try to run the machine
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Jun 25, 2010 | LG WM2277H Front Load Washer
I have a whirlpool duet 2 1/2 years old I t has started to make a loud buzzing hum sound (that sounds like old top loader mixing valve malfunction?) and has error code 5d what is this ?
Actually, your error code is "Sd" and indicates that the washer thinks that there are too many suds in the basket / drum.
Your buzzing sound is also likely to be the water inlet valves, common to top loaders as well, as the washer is adding additional water to rinse excessive suds out. Check your supply hoses for kinks, connections for scale buildup inside, as well as the screens on the inlet ports of the washer itself.
A kinked or restricted drain hose can also throw an Sd error code as well.
Jun 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I've been having this issue with my washing machine (front loader-energy efficient),Frigidaire, ATF7000ES1, every time I do a load of laundry it "errors" out every 7 minutes and stops and I have to go down...
this code is general fault code.the first thing to replace would be the door lock mechanism.i have replaced a control board before when there was a similar problem with another machine.
Mar 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
Sd code: Washer sounds like it is straining during the
This is a suds error. Too much detergent,wrong kind of detergent or a blocked drain pump filter.
Remove the bottom front panel. Unscrew the filter and clean it out. Run a couple cycles with no detergent to clean out the tub. Use only HE soap and the correct amount.
More soap causes problems and does not get the laundry any cleaner.
Nov 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
SUDS error on Neptune washer
It means that there is too much soap in the machine most of the time. Give it time for the suds to go down then try to run it through again. Try using a little less soap later on. Front loaders need less soap than top loaders.
Nov 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
HE2 front loader error code
According to the HE2 Tech Service manual, it means "Suds Lock (Overdose of detergent detected during the wash cycle).
Aug 29, 2008 | Kenmore 43142 Front Load Washer
Kenmore 43142 Front Load Washer Logo
65 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
