No wireless pressed reset button now i can't use wireless
  • Anonymous Oct 01, 2008
    How to reset Intermec 2102?
  • Carl Navarro
    Carl Navarro May 11, 2010
    That wasn't very smart was it? Time to get out the manual.
You will need to reconfigure your wireless access point to work with your home network. You will need to plug an ethernet cable from your computer into the wireless access point and open a web browser. Depending on your wireless access point, point your browser to http://192.168.0.1 and see if it connects. You should be able to configure it from there. If you have more questions, you might want to refer to the hardware manual you received with the unit or from the manufacturer's website. Good Luck!
Posted on Jan 02, 2009
Linksys wireless EA3500
Press and hold red reset button on back of unit for 30 seconds
Jul 11, 2014 | Linksys Wireless-G Broadband Router
Wireless LAN button won't switch off.
Most Netgear routers have a recessed button on the back or bottom panel, marked "Reset" or "Restore Factory Settings". Because the button is recessed, you will require a thin tool to press it. Most people use a straightened paperclip.
  1. Power up the router, and wait for it to complete booting up, typically about one minute.
  2. Press the Reset or Restore Factory Settings button until the test or power led starts blinking. This takes about 20 seconds. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password. If the reset was not successful, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the Reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
Apr 17, 2013 | NetGear N600 Wireless Dual Band Router
I can't get my Macbook setup to use the Lexmark x6650. I used the install disc and the wifi light on the printer is green, but I still cannot figure out how to setup my Macbook to print to is...
Print the network settings page to identify if your printer is connected to your wireless network:
1. Press Setup on the printer operator panel.
2. Press the right or left arrow button until Network Setup is displayed, press OK.
3. Press OK at Print Setup Page.
4. Press OK when prompted to Load Paper.
5. Press OK. The network settings page will now print.
Check the Network Card Status, SSID, Trouble Code, TCP/IP Address. SSID should be the name of your wireless network. Otherwise, you may need to reset the printer's wireless network settings.
How to reset network settings:
1. Press Setup.
3. Press the right or left arrow button until Reset Network Adapter Defaults is displayed, press OK.
4. Press the right or left arrow button to display Yes, pressOK.
Once the Wi-Fi light turns on to solid orange, run the Lexmark Wireless Setup Assistant on your Mac.
Sep 21, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
I set up my own wireless network and now my printer will not communicate with my laptop.WIFI light flashes red. Have tried everything to reconnect. Lexmark Z2420.
I suggest you reset the Lexmark Z2420 wireless network adapter. To reset, do the following: With the printer on, press and release the power button. The printer will enter power save mode. Now, press and hold the paper feed button. While holding down the paper feed button, press and release the power button. Continue holding the paper feed button for 30 seconds. Release the paper feed button. This will reset the internal network adapter (INA). When the printer has been reset, a solid orange Wi-Fi indicator light should appear. If Wi-Fi light goes back to flashing red, you have not successfully reset the printer. Start the procedure again. Once you have a solid orange Wi-Fi light, reconfigure the printer for wireless connection. Thanks.
Jul 29, 2010 | Lexmark Z2420 Printer
Ale can i reset my lexmark printer. x4550
To reset to Factory Default settings, turn off the printer by pressing and holding down power button. Then release the button. Press and hold down Color Start and Cancel buttons while pressing and releasing the power button. Continue holding down the Cancel and Start buttons for at least 20 seconds then release it. You will then be prompted to go through the setup again. To reset the printer's wireless network adapter, press Settings on the operator panel > Network Setup > Wireless Setup > Reset Network Adapter > hit check to confirm. Hope this helps.
Jul 21, 2010 | Lexmark X4550 Multifunction Wireless Color...
I can't reset my cwr-854 router by pressing the RESET button for more than 1 minute and nthing happens , either in Power ON and OFF
You can reset this Wireless Access Point by clicking on Reset button, and then press OK button to confirm your decision.
Note: you can also hold down the reset button for more than 10 seconds to reset its default settings back to factory default.
If the reset doesnt work turn off router then on again first, but if the reset doesnt work, the router may need to be replaced.
Oct 20, 2009 | Cnet (CWR-854) Wireless Router (cwr854)
Problem in setup wireless router,need default security key/phrase
If there reset the router to the factory settings:
Default Username: admin (lowercase)
Default Password: none (none, leave blank)
If this doesn't work, try pressing the reset button for 10 seconds with it powered ON. Then try it off. I can't remember which one will work.
After this is complete, username: admin and password: (nothing, blank, nada) will work.
Good Luck!
Apr 07, 2009 | Hawking 54M WIRELESS G ROUTER AP 4PORT...
Reset password for linksys wireless-g router
Press and hold the reset button for 60 seconds, after you release the reset button wait until the power light stops blinking. If it does not stop blinking, then unplug it for 30 seconds and plug it back in. After that type in at the address bar, 192.168.1.1
Feb 08, 2009 | Arris SURFboard SB5101 Cable Modem
Hawking wireless router to reset password
If you press the reset button you only make a reboot.
To reset all the value to the factory setting you have to:
- Power off the device
- Hold the reset button pressed
- While you press the reset button put the power back on
Now your gateway address is again 192.168.1.254, login is admin and password is not present (leave it blank).
Mar 01, 2008 | Hawking Wireless-G HWR54G (603992506064)...
Rx1950 freeze on soft reset
You can do a hard reset by doing the following...
01) Press and hold down the "Calendar" and "iPAQ Wireless" buttons.
02) While holding down these buttons, use the stylus to lightly press the "Reset" button/hole on the back of the iPAQ until the screen goes blank.
03) Release the "Calendar" and "iPAQ Wireless" buttons.
04) Press the "Reset" button/hole again (so that it resets/powers on.)
Nov 01, 2007 | HP iPAQ rx1950 Pocket PC
Computers & Internet Logo
384 people viewed this question
David Payne
David Payne
