Question about HP 920 Plain Paper Fax
Life of a 920?
Hello! Just curious as to what a normal life span of a HP 920 fax machine that receives anywhere from 5 to 10 "normal" (1 or 2 page faxes) a day five days a week would be. Thanks for your time.
Shelley
    Genius:
  • 2,120 Answers
As long as they still make the ink for them.
Posted on Aug 30, 2008
Lense hours
Hello muhammad
Projector's lamp life is said to be, not with the lens life. Lens is made up of glass. But lamp will go weak. the life of lame will depend on how much time the projectior have used. Normal life of Panasonic projector bulb spans between [1800 to 2000] continous use. It means, if we take the low life span of the bulb as 1800 Hours [1800/24=75 Continous days]. If we use it for 4 hours a day, the bulb may last for [1800/4=450 days ie 1 Year and 85 days] OK.
Dec 12, 2011 | Panasonic Videoprojector PT-LM1E...
Tip
How to get the page count for a Sharp FO-5700 fax machine
Sharp makes a line of fax machines, one of which is the FO-5700. The FO-5700 is easy to maintain and to use, and it can run well for years. If you want to view the life counter (page count) for your FO-5700, just follow the steps below.
With the fax machine on and ready, flip up the bar that displays the information for half of the quick dial buttons (#17-32). This bar has a tab that you can use to flip it, which sits right by the panel release lever (where you would put your hand to raise the operation panel if you had to remove a paper jam there). Just flip this bar up so that it covers the first half of the numbers instead of the second.
Once the bar is flipped up, you'll see that the V button is labeled "Life." Press that button to bring up the counter menu. Then press 1 on the fax machine's number pad. The screen will display "1: Life Counter" and below that, "LIFE=xxxxxx" where "xxxxxx" is the page count of the machine, in six-digit format.
You can view this life counter at any time, without having to print out a configuration page or usage page. To exit out of the life counter screen and return to the main screen, press the red Stop button. Be sure to flip the contacts bar back to its original position; there is a sensor that detects which way the bar is laying, and if it's still in the up position, pressing a button will have a different effect than it would if the bar were in its original position (such as bringing up the life counter instead of dialing a number).
on Jun 12, 2011 | Sharp FO 5700 Plain Paper Laser Fax
There is nowhere I can find whether I should switch on the Machine 24hr a day x 7 days a week. Or shall I swtich it off after-office-hours? Any effect on the life-span of the machine?
In a business environment most fax machines are left on 24/7......who wants to miss an order coming in because your fax was OFF. However, many fax machines can be programmed to go into a "sleep mode"...this would be in the evening when the office is closed...you still want to be able to recieve fax's if any come in..but you don't need the machine ON "fully" ready to print. Another-words, the machine is in a sleep/half power mode( because no-one is in the office to use it )..BUT if a fax comes in then the machine can still recieve it, then it "wakes-up" fully..prints out the recieved pages, and then goes back to sleep again. The details on how to program this function will be in your operators manual IF the feature is available on your model.
The benifits of programming a machine this way are pretty obvious...savings on Hydro, extended machine life ( due to machine going to sleep.) and yet you still dont miss any calls.
Pretty good hey.!!
Nov 07, 2010 | Brother IntelliFax-2820 Laser Fax
The orange light keeps flickering. I checked to see if any paper is stuck but couldn't see anything. There's something preventing the printing process. What could it be? Need help. Thanks
hello
which one of these HP p/n's is your fax ? C4647A or C4649A
is this your fax ?
InkJet FAX-910/920 (C4647A) C4647A InkJet FAX-920 (C4649A) C4649AR, C4649A
InkJet FAX-910/920 (C4647A) C4647A InkJet FAX-920 (C4649A) C4649AR, C4649Apic00602.gif
go to this link , follow instructions, -- HW TO CLEAR PAPER JAM
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu50320&tmp_task=solveCategory&lc=en&dlc=en&cc=ca&lang=en&product=60718
please rate my service
Nov 05, 2010 | HP 920 Plain Paper Fax
Fax sends certain pages in duplicate
If it only happens with that one vendor, the problem is almost certainly either on their end or somewhere in the interaction between the two fax machines.
The most likely answer is that their fax machine has a problem receiving some pages (either because the line is noisy or for another reason) so it has to reprint them. You could tell your vendor to try turning off error correction on their fax machine and see if that makes a difference.
Hope that helps.
Jul 05, 2010 | HP 920 Plain Paper Fax
HP 920 Fax Machine - HELP
The manual is available from HP here. Hope this gets you going. Thanks for using Fixya!
Feb 12, 2010 | HP 920 Plain Paper Fax
Faxes received locally from India, but cannot get faxes from USA
Because either they have the wrong phone number or they are not putting in the correct Country Code when dialing.
Nov 25, 2009 | HP 920 Plain Paper Fax
My hp printer fax does print when recieving a fax but doew print normally when coming off computer. Fax machine sya low on ink should I check both cartridges and get new ones
Yes , if the fax machine says low ink or toner , then it needs it alos check the drum corona wire, It may need cleaning, and you can clean it using a #2 lead pencil eraser, Gently in the wire, then replace wire and try receiving a fax.
Jul 10, 2009 | HP 920 Plain Paper Fax
Printing problems - splits received pages into multiple pages
Unplug the machine for 10 seconds.
Your machine must be set for AUTO REDUCTION
Oct 30, 2008 | HP 920 Plain Paper Fax
FAX, MODEL 920 NOT RECEIVING
Try calling your fax machine from a cell phone. If the fax doesen't answer, or if the line is busy, the phone line may be bad. Also check that the phone line to the fax is plugged into the receptical marked LINE, not PHONE. The PHONE receptical is to connect a telephone to the fax machine. If it still does not answer, try going into the fax menu and go to RECEIVE settngs. Try changing each setting, then call the fax with the cell to see if it answers. Write down each setting before you change it, so you can set it back if changing it does not solve the problem.
Jul 10, 2008 | HP 920 Plain Paper Fax
HP 920 Plain Paper Fax Logo
87 people viewed this question
Ben Johnson
