LG intello 7kg no power. no red light nothing
No power, no red light. Checked fuse OK. took off back no loose cables ect. Finished full wash and switched itself off as normal now nothing
  • 3,230 Answers
You need to check the main power cable and also check the power board.
Good Luck!!
Posted on May 19, 2009
LG intello washer 7kg
check all the pipes comming from the drum to the pump take the back off they will be at the bottom of the m/c being held in place by thick plastic what look like cable tyies socks have a habbit of getting in there and blocking up the drainer pipes hope this helps
Sep 27, 2012 | Washing Machines
LG intello front load washing machine not starting Select cycle as always and press start nothing then it beeps and flashes all lights
check filter and drain pomp...if ok check motor brushes .. bsc appliances 07779933829 postal service too.
Feb 26, 2011 | Washing Machines
My LG 7kg frontloader intellowasher WD8013F is leaking from underneath and no water is going into the washing machine. Please help?
i removed the filter off the front of my lg intello washer to clean and now it keeps leaking water from the filter what have i done ?
Jul 12, 2010 | LG Washing Machines
LG-INTELLO WASHER 7kg WD-8074FHB
"de" means door is open you have to close the door titly then press the start bottom or check door switch if its out of order or not with digital multi meter.
Apr 10, 2010 | LG WM1812C Front Load Washer
Tv will not power on!!!
most likely will need a new power supply, google it
Jan 01, 2010 | LG 32LG30 32 in. LCD HDTV
It showing cl on the screen
Hi
Thanks for using FixYa. CL means child lock, it might have got locked. Try pressing "dry" & "spin" together for a 10 seconds or until the CL disappears. Also try pressing "end of cycle" for over 5 seconds.
If this doesn't work then try pressing "options & select" till the light goes off.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 12, 2009 | LG Washing Machines
Lg intello washer error code cl
fault code "cl".you have your child lock function on.push the two child lock buttons together on the control panel,hold them for a few seconds till the "cl" icon dissapears
Jan 29, 2009 | LG WM-2277HW Front Load Washer
LG Intello 7KG Washing Machine
You may have some articles that made their way into the pump housing. Alot of times I see dimes get stuck in the ports of the pump, remove and check out thoroly and also check hoses coming to pump for little son of a gun articles that like to hide.
Apr 01, 2008 | Washing Machines
Washing Machines Logo
94 people viewed this question
Top Washing Machines Experts
