Question about HP Computers & Internet
Machine won't boot and reports a memory fault
    Brigadier General:
  • 5,158 Answers
Shut off the power. remove the cover... remove the memory enough to unplug it from the socket then push it back firmly but gently into the socket. put the case back on and restart the computer.
If that does not work it may actually be a memory stick that has gone bad... if it has two memory sticks you will need to uplug one and try to boot.... if it doesn't work you have probably found the fault.... if it does work take it out and put in the other memory stick to test it.
Robert
Posted on Aug 29, 2008
Black screen Faulting module path: C:\Windows\WinSxS\amd64_microsoft.vc80
If Explorer is corrupt then most of its support will not load, hence the long list of errors. Can you press F8 just before boot and choose "repair" from the options menu? That may repair the main kernel.
Dec 04, 2013 | Computers & Internet
Power outage now my e machines el 1200 01h won't boot saying no boot file name revevied?
Try to enter your boot screen, usually by pressing F8 when booting up. Then go to your boot priority list and make sure it is booting from your hard drive. I'm not a fan of e machines, it is very possible that the power surge caused some memory or physical errors.
Apr 11, 2013 | E-Machines eMachines Desktop PC
I recently purchased Two PNY 1Gb ram to upgrade from original 512mb. When I put both 1Gb ram in the slots, the computer will not boot up. When I take one out and put the original 512 back in with the other...
I don't know your specific model, but some of the Emachines had some memory directly on the motherboard. With the 1Gb and 512Mb sticks installed, boot the machine and report how much memory the system sees. Perhaps the onboard memory is causing you to exceed the 2Gb limit.
Please post the memory size you get here with the above sticks.
Thanks,
Dan
May 12, 2011 | E-Machines W6409 (7234) PC Desktop
Lost driver & installer
hello
due to the fact that this memory card is no longer available, Kingston does not have drivers fo this card . As a matter of fact SD cards normally do come with drivers , as they are conformed in a way that operating systems recognise them once you plug them into the SD slot
i hope this inofrmation helps you make a decsion
some background on this particular SD memory card you have
SDCZ2-512-A10-KT (Discontinued) Description: 512MB USB 2.0 DataTraveler I write up to 3MBps Discontinued Additional Info: DataTraveler I USB 2.0 Flash Drive Write up to 1.5MBps Read up to 6MBps Mfgr's System P/N's: SDCZ2-512-A10 (Kingston) Form Factor: USB Flash Memory Warranty: 5 Yrs†
here are some solutions .
When the problem occurs is a clue as to the cause.
For example, your response to a memory error message depends on whether:
  1. You have just bought a new computer.
  2. You have just installed new memory.
  3. You have just installed new software or a new operating system.
  4. You have just installed or removed hardware.
  5. Your computer has been running fine and you've made no other recent changes.
UNEXPECTED PROBLEMS
If your system has been running fine, but suddenly starts to produce memory errors, and crash or lock up frequently, the chance of a hardware failure is more likely, since configuration and installation problems show up as soon as the computer turns on. Sometimes you can get memory problems if your computer is overheating, if you are having a problem with your power supply, or if corrosion has developed between the memory module and the socket, weakening the connection.
HANDLING SPECIFIC PROBLEMS
Here is a list of the most common ways the computer informs you of a memory problem.
  1. The computer won't boot, merely beeps.
  2. Computer boots but doesn't recognize all the installed memory.
  3. The computer boots but the screen is blank.
  4. The computer reports a memory error.
    1. Memory mismatch error
    2. Memory parity interrupt at xxxxx
    3. Memory address error at xxxxx
    4. Memory failure at xxxxx, read xxxxx, expecting xxxxx
    5. Memory verify error at xxxxx
  5. The computer has other problems caused by memory.
    1. The computer intermittently reports errors, crashes frequently, or spontaneously reboots.
    2. Registry Errors
    3. General-protection faults, page faults, and exception errors
Nov 07, 2010 | Kingston (SDCZ2-512-A10-KT)...
My sony vgn bx41 has developed a fault that only occurs when the memory is installed. It won't start. If I take the memory out the machine boots up as normal, I have tried memory from an identical machine...
Either one of the memory chips is bad / that will prevent device from booting. OR a memory slot is no good and when you plug something into it, the unit will not function.
Sep 17, 2017 | Sony VAIO VGN-BX660P Notebook
How do you turn off the in use/memory light?
This of course depends on why the light is on! If you had a fax come in and it is in memory, you will need to print the fax and clear the memory before the light will go out. The LCD Display should be telling you why that light is on.
1. There is a fax or print job in memory waiting to be printed.--> See steps below
2. There is a paper jam --> Open printer - Remove all paper - Close printer - press OK button
3. You are out of ink or the cartridges are low. - Change Cartridges
Solution: Printing reports and lists MX310
The table below shows the reports and lists that can be printed from your machine.
Report or List Description ACTIVITY REPORT Shows recent facsimile transactions performed by your machine. You can enable or disable automatic printing of this report after every 20 transactions. You can also manually set the machine to print it. CODED SPEED DIAL
LIST
Lists the destination numbers and names registered for coded dial speed dialing. USER'S DATA LIST Lists the current settings of your machine and the registered sender information. MEMORY LIST Lists the documents currently stored in the machine's memory. TX (Transmission)
REPORT
Prints after transmission of a document.
You can enable or disable this feature, or set the machine to print a report only when an error occurs.
You can also set the machine to print the first page of the document under the transmission report to remind you of the contents of the document.
RX (Reception)
REPORT
Prints after reception of a document.
To print the Activity Report, Coded Speed Dial List, User's Data List or Memory List: 1 . Press <FAX>, then press <Menu>.
2 . Use leftright.gif to select [PRNT REPORT/LIST], then press <OK>.
3. Use leftright.gif to select the desired report, then press <OK>. The report or list is printed.
Mar 24, 2009 | Canon PIXMA MX310 All-In-One Printer
How can i get a fax from memory.
Printing reports and lists The table below shows the reports and lists that can be printed from your machine.
LIST
REPORT
RX (Reception)
REPORT
Says memory full but nothing in memory
Memory full errors can be caused by a couple of things. When you send a fax the machine settings and the amount of installed memory can cause this. Check the resolution you have the fax machine set at, usually it is set on something like "text" or "draft", if it is set on somthing like "fine" or "super fine" you will fill up the memory faster. Also if you are loading the document into memory before it actually connects with the other machine this could happen. Try looking for a switch or setting on your machine that says "direct". If you have a direct send enabled, your machine will not load the image into memory, it will wait for the other machine to answer and start receiving before actually doing any transmitting of the document. These are just general ideas as you did not describe the make or model of your machine. Hope this helps.
Larry
Dec 16, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Computers & Internet Logo
24 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
