SOURCE: hp photosmart C4280 installed once
HP printers can be very touchy about the way they are installed.
1) Disconnected the printer
2) Uninstall the software
3) Restart your computer
4) DO NOT PLUG IN YOUR PRINTER
5) Install the driver and only connect the printer when the installation tells you to.
The other source of problem is where the printer is connected to the printer, if it is connected to a USB hub (especially an unpowered one) it may cause issues. Try connecting to one of the ports at the rear of your computer.
Check your cable, maybe try another one, it could have become damaged in the move.
SOURCE: HP photosmart all-in-one model D110a
You can download software and manuals here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=4023246&
Select your operating system, then click 'Next' 32 or 64 bit system.
Good luck.
SOURCE: I have a photosmart c4680 printer. Every time I
Right click on the printer and click Resume. Once the printer has been paused it will not auto cycle to normal. Have you tried rebooting the computer?
For any
severe cartridge error related message, on the HP C4600, C4700 or D110a printer
models, I suggest you run the internal Tap 41 diagnostics test which will tell
you the electrical health of the ink cartridge - in many cases the cartridge is
internally electrically damaged and will need to be replaced. In addition, you
can temporarily bypass an 'incompatible cartridge(s) or Missing/Not Detected
error message by performing the Cartridge Error Bypass procedure...refer to two
Youtube videos on how to do this:
HP Photosmart C4600 & C4700 Printers -
Tap 41 Diagnostic Test: http://www.youtube.com/watch?v=ghxjLCn07Jo
HP Photosmart C4600 C4700 D110a Printers -
HP 60 Cartridge Error Bypass: http://www.youtube.com/watch?v=rNVJmKPlLsg
Low Ink Warning and Other (i.e Incompatible
Cartridge) Errors, HP 60 & HP 61 Ink Cartridges:
