Question about Acer Aspire 3000 Notebook
Squealing sound my acer has a really bad sound when turned on. very high pitched cb radio sound.
    Problem Solver:
  • 18 Answers
Hi dianne... i've had that happent 2 me lots of times. it's quite easy to sort out actually . try this: double click on the speaker or sound icon (bottom right corner next to the time display).tick the block for Mic/Line in to mute the microphone on your laptop. this procedure will sort the squeal out. just remember though that if u use the mic on the laptop u should reverse the procedure.
good luck..
Posted on Aug 29, 2008
Weather radio just gives off high pitch squeal and no weather info.
If you hold the WEATHER/SNOOZE button and the VOLUME UP button, it resets the radio to its deafult factory settings.
Jan 20, 2012 | Midland WR-100 Weather/RDS Radio
I have a uniden grant and i have wired a galaxy power desk mic with rogger beep when ever i key it up it squeals was wondering is there a way to fix that
yeah your mic gain is way too high. You can either turn off talk back if you can, or turn the gain down. Depending on how loud the talk back is, your audio may suffer. If that is the case, you will not be able to run that mic. Get an RK-56 or a Skythumper mic. They are noise canceling. You will get no squeal with that mic, and it will sound awesome.
If you really want a roger beep, take it to a tech and them install one.
Oct 23, 2010 | Galaxy Radios DX-66V Base CB Radio
I have a dx98vhp and it sqeels* when i key up when the talkback is on. I've tried adjusting the power and i can't figure it out. Thanks
the talkback is too loud. there is no way to adjust the talkback volume on this radio. Talkback is really just so you can check how your audio sounds and your echo. Once it set, there is really no need to have it on.
Turning down the gain on your mic will stop the squeal.
the squeal is cause by feed back from audio from the talk back being heard from the mic.
Sep 14, 2010 | Galaxy Radios Microsystems DX98VHP CB...
High pitched squeal when trying to transmit
What mic are you using for this. It won't take just any mic. It has to be wired midland.
Aug 17, 2010 | Midland 1001Z 40-Channels Base CB Radio
Feed back thru external speaker, very bad
Have your antenna checked at a place that knows what they're doing. If your antenna system is bad, ground problem,coax bad mount or maybe just a wrong or bad antenna. Then the sounds not getting out the antenna and its feeding back thur the radio.If your echo board was bad then your radio wouldn't transmitt at all.
If you unplug your external speaker will it squeal? If not do the antenna and if that reads fine just try a better speaker like a uniden 20watt speaker.I own a CB shop and this is easy to fix.
Jul 10, 2010 | Connex 3300 240-Channels Base CB Radio
1991 Ford 350 truck, in dash cassette player high pitch noise
Hi rayc
sounds like the motor that pulls the tape mechanism is probably about to give problems and is getting electronically noisy. The cb may need to hooked up some where else to power so you get away from dirty power as well as maybe move the cb farther away from the tape player. hope this helps.
Ray
Aug 31, 2009 | Maxon MCB-40 40-Channels Handheld CB Radio
I have a Maxon handheld cb - it squeals when keyed can not talk.
sounds like you are getting a feedback squeal.. try taking a wire and attaching to you handheld and grounding it to something.. that might work.. i know i have to have my mic on my cb grounded to my radio or i get a feedback squeal...
Jan 02, 2009 | Maxon HCB-10C CB Radio
Screaming acer!
sometimes if the inverter board (the part that drives the backlight) has a cold solder joint on it, it can actually generate a high pitched resonating sound (aka a screaming squeal sound)
if it's under warranty, have the manufacturer correct the problem.
if not under warranty, retouch the solder points on the inverter board, or have a repair tech fix it for you.
Jun 03, 2008 | Acer AL1916W 19" LCD Monitor
Acer Aspire 3000 Notebook Logo
523 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
