FixYa.com
Tags:
Compaq iPAQ H3850 Pocket PC
Color problem.
posted by adib - usenet poster on Sep 11, 2005
my pda colours are just blue/purple/white on
screen etc ,
please can someone help,
done lots of soft and hard resets etc to no av..... .
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 26, 2007
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
DO NOT tamper with your pda if it stil in warranty. The following solution is for out of warranty pda'S ONLY. Sounds like your LCD cable is loose. You need to reseat the cable. It is only slightly tricky but can be easily done by a novice. You will need a Tortion screwdriver with a T7 socket to unscrew the back plastics (only 4 screws). Once done look on the circuit board and notice the horisontal brown plastic socket running down the side of the circuit board. You should also see a brownish cable running to the front (to the LCD). This is your LCD cable. Reseat it very gently. Do not use any force here.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these PDAs problems?
compaq ipaq wireless 3765
how do i configure the wireless... Answer This...
how to connect, setup... Answer This...
Compaq iPAQ 3765
When I try to sync my iPAQ,... Answer This...
The unit will not charge from...
Th orange charging light does... Answer This...
Secure Digital Card for iPAQ...
Is there a limit to the size of... Answer This...
Repair Service
Find PDA Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
