Question about Vacuums
Vacuum cleaner doesn't ****
My vacuum cleaner stopped sucking
  • Jay Harel
    Jay Harel Aug 29, 2008
    thanks
  • Anonymous Mar 18, 2014
    Sounds like system is sucking in air and turbo head not spinning seems to be blocked
    Brigadier General:
  • Vacuums Master
  • 3,614 Answers
Please provide the model please, and kindly discuss more info regardding on your problem
Posted on Aug 29, 2008
  • Vacuums Master
  • 19,396 Answers
Check that the bag is not full, check also that the vacuum hose is not obstructed.
Provide model for more help.
    President:
  • 1,263 Answers
Have you checked to make sure the motor is not clogged?
  • 1 more comment
  • Ronald Mueller
    Ronald Mueller Aug 29, 2008
    most times the reason it stops working is because the intake side of vaccum is stopped up with debree. another reason is that the brush is not spinning which is a cause of broken rubber belt
  • Ronald Mueller
    all vaccums operate on the same principle most often times if the bag is not full and the hose has not blockage and the brush is working, the problem is the impellor inside the vaccum no longer is pulling in air. the fins on the impellor are broken and can't force the air through like it should.
  • meg_pig79 Aug 24, 2010
    ho can I fix it myself. I have a bissell easyvac and it does not ****. brushes move. it spits dirt out.
  • 790 Answers
Hello!!
May i know the model please
It keeps losing suctionm and the ball comes up and it stops sucking. Why?
sounds wilk a wet /dry vacuum cleaner
if that is the case the ball comes up to stop water / froth from being sucked through the motor
if that happening put more anti suds mix in the water or empty the receiver tib more often
Jul 26, 2016 | Vacuums
Why won't it suck
Hey there! It's possible that you may still have a clog in your vacuum somewhere. The filters can also cause the vacuum to lose suction. Try these steps to restore suction to your cleaner.
1. Remove the dirt cup canister from the vacuum. Remove the dirt cup lid.
2. Remove the primary foam filter. Rinse the filter under running water until it runs clear. Allow 24 hours to air dry outside of the vacuum.
3. Slide the Hepa filter out. Tap the filter against the trash can until dirt stops falling. Replace the Hepa filter. (Do not wash) Filters should be replaced once a year.
4. Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
5. Remove the bottom plate and brushroll. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose.
6. Check that the brushes are still spinning. If not, replace the belt.
Hope this helps!
Jun 20, 2014 | Hoover UH70120 WindTunnel TSeries Rewind...
What could make the vacuum cleaner suction stop sucking
Usually that happens when the sweeper is plugged up inside. Dog hair, cat hair and the vacuum fresh will build up in there over time and kill your suction. hope this helps
Nov 08, 2013 | Vacuums
Was vacuuming and it just stopped.
Take the vacuum apart. There probably is something stuck in the tubes
Dec 06, 2012 | Dyson DC25 The Ball All Floors Yellow...
Doesn't seem to be sucking up dirt well
Bagless vacuum cleaners leave the bulk dirt in a receiver, but they still rely on a paper air filter to trap fine particles of dust. All the air that the vacuum moves passes through that paper filter. When the filter plugs up, it has to be cleaned or replaced. The bagless "primary filters" are much more expensive than vacuum cleaner bags, but if you can afford to replace it whenever the machine's suction is impeded, its the tidyest solution. You can remove the filter and tap it inside a waste can to dislodge some of the dirt that's plugging it. You can use another vacuum cleaner to clean it somewhat better than just tapping it. (It doesn't have to be *your* other vacuum cleaner, it could be borrowed, at the car wash, etc.) You can use compressed air to almost all of of the dirt plugging it, but you'll want to do it outside somewhere that making a clod of dust is acceptable or at least unnoticed. After a dozen or more cleanings the pores of the paper filter will become too plugged to clean well even with compressed air and it will have to be replaced.
Pet hair, sand and large particulate are least likely to plug these filters. Kitty littler, which is pressed pellets of fine clay, clogs these filters very rapidly. The clay pellets break up into very fine dust as they pass through the vacuum and whirl in the dirt cannister. Avoid vacuuming kitty litter, or any other fine clay into a bagless machine as much as possible.
Jul 28, 2012 | Hoover S3765-040 WindTunnel Bagless...
Our Bissell ProHeat 2XModel 9200T stopped sucking up the water. We haven't had it for long. Maybe a year.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
rtjuk
Sep 03, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
My vacuum cleaner is not sucking. It's overheated and stopped
In this case it is motor problem, you can sort out only by calling the technician. Call the customer care and check out the cost for repair, if it is very high you can go for a new one and be in peace of mind.
Thank you.
May 08, 2010 | Sanyo Performax SC-U126 Vacuum
My bissell vacuum cleaner has stopped sucking things up as well as it was when I first purchased it two months ago. It also seems to be pushing more air out than it is sucking up.
with most vacuum cleaners the problem stems from carpet fuzz (especially in new carpet instalations) to build up of pet hair I have repaired several vacuum cleaners & my solution has use a shop vac if possible 15 amps or more clean the hose, check the belt(s) or if is not bagless make sure you have the proper fitting bag happy repair
Aug 23, 2009 | Vacuums
Vacuums Logo
302 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
