Question about Palm Z22 Handheld
PALM Z22 THE TOUCHSCREEN OF MY PALM Z22 SUMTIMES STOP RECEIVING ANY INPUT. THE PDA IS ABOUT Iyr OLD AD I'VE USED THE TOUCHSCREEN PROTECTOR TO PROTECT IT. ANY HELP WOULD BE USEFUL. THANKS
  • Ellen Bellantoni Jan 09, 2009
    Hi -
    For no reason, and with no warning, the LCD of my Palm Z22 went black. The Handheld does not respond to touching the screen, or charging.
    Thanks, EllenB
    Scholar:
  • 45 Answers
Your problem might be a simple one. Hopefully so:
Run a business card around the edges of the screen between the screen and the plastic housing to see if there is any trapped dirt or other debri. If there is, it will hold down that point of the screen and prevent any further input. Be sure to remove anything you find.
Also, sometimes the screen protectors themselves will shift just enough to cause the same issue. Be sure it is not wedged tightly between the screen and case.
I hope this is it and helps!
Posted on Aug 29, 2008
Can not get the device to turn on
There should be a pin hole on the back of the PDA. Press the hole using a thin paper click. This will RESET your PDA. Press the power button and it will work OK. All PDA's have a RESET option.
Jun 01, 2015 | Palm z22 32mb handheld pda organizer z22-b
The hotsync function dies not work
Hello there Anymoose:
On my web page:
http://kidbots.com/WEBADD/Z22_PALM_PILOT/Z22_PALM_PILOT.html
are many suggestions and links to help get DATA SYNC's to your computer.
Please search the internet for CompanionLink as well, since I just discovered it now, and have not yet added it to my web page...
As well, I cover aspects such as the battery, the touchscreen, and other quirks that happen as the Palm Z22 gets older and older!
I hope this information solves your problems...
good luck
robin dusty graves
Z22 PALM PILOT hotsync-function-dies-not-work-cdqazwk5fkdpm30unkbxcrm5-1-0.jpg hotsync-function-dies-not-work-cdqazwk5fkdpm30unkbxcrm5-1-1.jpg hotsync-function-dies-not-work-cdqazwk5fkdpm30unkbxcrm5-1-3.jpg hotsync-function-dies-not-work-cdqazwk5fkdpm30unkbxcrm5-1-6.jpg
Oct 28, 2013 | Palm Z22 Handheld
Palm z22 touch screen not responding touchscreen
The Z22 palm PDA is subjected to 3 points of failure. I got a used Z22 and discovered all 3 over the course of a few years. The touchscreen digitizer on the front is a plastic sheet on the top, and a glass screen on the bottom. Invisible layers of conductive paint are facing each other. Simply carrying the Z22 in your pocket, purse, briefcase, or even storing it in a drawer with pencils, staplers, rulers, etc., will, over time, deform the screen, and the damage is cumulative, so that the screen gets worse and worse. It is imperative to have a solid sheet of plastic or hard material over the screen at all times that you are not using it. Leaving the Z22 in direct hot sunlight will heat up and soften the screen, making the problem worse. Carrying the Z22 screen in your pocket on a hot day when you are sweating, will do the same. People report that the Z22 will work in a cool place like North New York, but the screen will quit, when they travel to Florida (hot). I have temporarily fixed the touchscreen by putting it in a ziplock, and sticking it in the freezer to shrink the top layer of plastic. That only worked twice. Then I use a hair dryer to heat the screen VERY hot, to shrink the screen - which worked very well, until I put it in a soft zippered camera case, which gently pushed the screen. Then I took the screen apart completely ( which no one has ever reported doing) and this worked amazingly well, -again- until I put it in a soft case that pushed the screen against the glass backing. I eventually replaced the touchscreen ($10 free shipping from China). All the information is on my tiny website at
The Z22 is incredibly well designed, and after ripping it apart a dozen times, and carrying it around under extreme heat and freezing cold, I would have to give the original design team at PALM, 5 stars. Your data, on the device, even though the screen may be dead, is very safe, and unless you do a HARD RESET, the data is stored on permanent memory. I had problems with a weak and dying battery, which ALL Z22s are now experiencing, since the decades of time, even with a "new" in the box, sealed Z22 will have. Low glitches of power on the battery seem to cause the BlackScreen of Death, where the LOGIC circuits that control the ON/OFF/SLEEP etc. functions get out of sync, and the unit will not charge or turn on until ALL power is removed ( typically, after a few weeks the battery drains to dead ).
All these problems are discussed and solutions posted, with photos on my website. Also are discussions on what to do with the Z22, where to get parts, how to maintain the Z22, and how to get data off the device onto the new 64 bit WINDOWS computers...
Good luck. The Z22 was an amazing device in its day, and people report that there were a few software programs for it that have never been made since - hence, they still use it...
robindustygraves Sept 2014
Z22 PALM PILOT a75f3784-08d5-4a1b-85ae-67e479181e27.jpg b2146887-a4b6-43a4-931b-b0f3438348ac.jpg 12202c43-26c3-47df-a31f-bc94507b7482.jpg fc737f81-6cb4-492d-b006-199c695a4776.jpg
Aug 02, 2013 | Palm Z22 Handheld
Palm z22 touchscreen not responding
The Z22 is incredibly well designed, and after ripping it apart a dozen times, and carrying it around under extreme heat and freezing cold, I would have to give the original design team at PALM, 5 stars. Your data, on the device, even though the screen may be dead, is very safe, and unless you do a HARD RESET, the data is stored on permanent memory. I had problems with a weak and dying battery, which ALL Z22s are now experiencing, since the decades of time, even with a "new" in the box, sealed Z22 will have. Low glitches of power on the battery seem to cause the BlackScreen of *****, where the LOGIC circuits that control the ON/OFF/SLEEP etc. functions get out of sync, and the unit will not charge or turn on until ALL power is removed ( typically, after a few weeks the battery drains to dead ).
( I am posting this answer on a few places on fixya, so that people with Z22's can find it easily ! )
Z22 PALM PILOT
0622ac5f-1a8b-4e47-b2d3-41600350d21e.jpg Z22 PALM PILOT d66589a5-9eed-4439-8a3e-5cc1944e2ab2.jpg 61ca79eb-5d24-47a7-9aea-aab6200c19b8.jpg c90ee8fa-0ef6-4f86-8024-0ebb9f0cb5c1.jpg
Aug 08, 2011 | Palm Z22 Handheld
Z22 palm handheld touchscreen won't respond - i've done soft reset -- several times -- used the 5 way to bring up the touchscreen -- tapped and nothing happened.
Hi, Try doing a hard reset to see if this will correct the problem.
Hold down the power button and at the same time use the tip of your stylus or any other non sharp item and press the inside the reset hole on the back of your palm.
When you see the Palm power logo appear you can let go of the power button and also the one on the back of you unit.
It will display a message asking if you want to do a hard reset and that it will erase all your data. select yes by hitting the up part of your 5 way button on the bottom of your unit. This is the one you use to navigate around your palm screen. After it resets you wil then be prompted to reset the screen by tapping the targets. If it works great. If not then you have something wrong that needs to be looked at. Before you send it in go to:
www.palm.com.
Select pda and then your model. From there go to the support screen and do a live chat. This is free and they may be able to live you some help. Best wishes.
Sep 19, 2009 | Palm Z22 Handheld
Cd doesnt install palm desktop software (palm z22)
You're saying you trying to install an appointment on your PDA. Has evrything worked before?
Dec 30, 2008 | Palm Z22 Handheld
Can I hot sync z22 palm without the touchscreen?
The data on your old Z22 is very likely very secure, and the touch screen problem is very common - there are a few tricks to get the touch screen working long enough to transfer the data.
I have a web page entirely for maintaining, repairing, and interfacing your Z22 at:
You can try these tricks, or just replace the screen for $9 U.S., since the screen only needs you take the unit apart and flip open a connector lock ...
I would strongly advise getting a solid plastic cover over your new Z22, since this is the key to keeping the screen working...
hope the information is of help to you
good luck
robin dusty graves
Z22 PALM PILOT hot-sync-z22-palm-without-touchscreen-ngl0e1lc0ft3j10pmz4xzklk-3-0.jpg hot-sync-z22-palm-without-touchscreen-ngl0e1lc0ft3j10pmz4xzklk-3-1.jpg hot-sync-z22-palm-without-touchscreen-ngl0e1lc0ft3j10pmz4xzklk-3-3.jpg
Nov 06, 2008 | Palm Z22 Handheld
I just bought a palm Z22 PDA. I used the AC charger to charge the Z22 but when I attempted to attach the USB synch cable I noticed that the plug is different from the plug on the AC charger. The USB...
I have concluded that the USB synch cable is not the correct one for my Palm Z22 PDA. There is only one point of attachment on the PDA and it is different from the plug on the USB synch chord. This was the last Palm Z22 PDA in the store so I think that the store clerk rounded up leftover parts and components of previous PDA kits and tried to make a complete set out of it. I am going to return the PDA to the store (Staples) in the next day or two.
Thanks for your offer of help. I will contact you again in the future if I need help.
Oct 15, 2008 | Palm Z22 Handheld
How to download current Zire info to new Palm Z22
My son said to just install the new software and see if it would transfer the data via the sync feature, and it did. The new Z22 software must have written over the existing Zire and incorporated all the data.
Apr 22, 2008 | Palm Z22 Handheld
Palm Z22 Handheld Logo
230 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
