Question about Toshiba e740 Pocket PC
Toshiba 740E handheld PC problems with hard reset & battery
The unit had problems that could not be revolved despite being sent back 3 times (a 4th time if you include the recall). Toshiba could not fix the problem and refused to offer further support. Problems: - The unit intermittently hard resets for no apparent reason. It has done this at least 35 times). - The battery completely discharges in <12 hours after being fully charged, even though it is turned off. There is no warning that the battery is low. Opinions?
    Master:
  • 903 Answers
It's best kept in its charger whenever possible. One of the issues with it is that the buttons tend to get "hit" and it wakes up and discharges quickly. Even on a full charge, it can drain the battery in just a few hours. The issue is worsened by the supplied case. People have noted that using another case or even gluing felt pads in just the right spots of the holder helps immensely.
Posted on Sep 11, 2005
The calculator writes 8 all over
During operation of the TI-Nspire handheld it may be necessary to reset the device. Circumstances which may require a reset include; keys not responding, device will not turn on or a garbled display. To reset the device:
• Remove the keypad (for TI-Nspire with ClickPad, TI-Nspire with TouchPad, and TI-Nspire CAS with Touchpad) or the battery door (for TI-Nspire CAS with ClickPad) and remove at least one battery from each column of batteries. After 2-5 seconds, reinsert the batteries but do not turn the handheld on.
For the TI-Nspire and TI-Nspire CAS handheld units with ClickPad:
• Hold down [home] [enter] [P].
• While holding these keys press [on].
For the TI-Nspire and TI-Nspire CAS handheld units with TouchPad and the TI-Nspire CX and TI-Nspire CX CAS:
• Hold down [doc] [enter] [EE].
Please Note: For TI-Nspire Family handheld units that contain rechargeable batteries you can alternatively hold the above keys while pressing the [reset] button on the back of the handheld rather than removing the battery for 2-5 seconds.
• The device will boot up as in the previous reset, but will display a menu with the following options. Please try options 2, 3, and 4 in that order.
• 1: Cancel - The most non-intrusive reset option; no changes are made, the unit restarts.
• 2: Delete Operating System - The operating system will be deleted without deleting any documents on the system.
• 3: Delete Document Folder Contents - This will delete the user's documents, but will not delete the OS. Selecting this option is the same as using the RESET hole on the back of the unit.
• 4: Complete Format - This will delete the OS and all documents for a total wipe of the handheld.
Please note that the second and fourth option will require that the OS will need to be reinstalled
Mar 12, 2014 | Texas Instruments TI-Nspire Graphic...
My Palm treo...will not dial out, or accept phone calls (with ringtone)! This happened all of a sudden,without me doing anything abnormal to the phone. Please advise! Sincerely, Tim McLinskey
You could try to turn the unit off completely, take the battery out, wait for few minutes and put them back and turn on to see anything better. This action helps to clear the memory of your unit.
If after you doing that problem still, i think you need the hard reset your Palm Treo. To do the hard reset, you need to back up all your data to the computer first, syns all contacts and files to your comp and perform the hard reset.( How to do hard reset could find in your manual)
In my experience, the palm treo is very sensitive handheld, the keys and touch screen easy to create the problem for you when you put your phone in the pocket with car keys or something. Try to avoid this.
Hope this will help.
Feb 07, 2011 | Palm Treo 650 Handheld
I cant turn on my blackberry pearl 8110. Red light just flashes
A hard reset involves physically removing the battery from the smartphone and then reinserting it. To perform a hard reset, complete the following steps:
1) Remove the battery cover from the back of the BlackBerry smartphone.
2) Remove the battery, and then reinsert it after a few seconds.
3) Replace the battery cover.
Still if it is not working kindly remove the Battery of the Handheld and try in some other Handheld.
If the Battery is working fine in the other Handheld then there might be some problem with your Handheld, you need to walk into the service center.
If the Battery is not working in the other Handheld then there might be aproblem in the USB cable for these you need to walk into the service center
Oct 14, 2009 | RIM BlackBerry Pearl 8100
Tungsten t5 : Won't power on, despite change of a rechargeable battery, soft reset, trial of hard reset. Any suggestion ? Shall I throw this device away ?
It might just be that the battery is shot and you need to replace just it, I would try that before you throw it away
May 25, 2009 | Palm Tungsten T5 Handheld
Iwant to hard reset this phone
A reset of a BlackBerry smartphone does not delete any settings or data.There are two options for performing a reset: a hard reset and a soft reset. A hard reset involves physically removing the battery from the smartphone and then reinserting it. To perform a hard reset, complete the following steps:
smartphone.
May 04, 2009 | T-Mobile BlackBerry 7105t Cellular Phone
DV1000 Shut Off For The 4th Time
1.when this situation occurs remove the battery and insert after 1min.
2.now start again
3.if it does not start now again remove the battery and also RAM after 5min insert both again
Feb 17, 2008 | HP Pavilion dv1000 Notebook
Problems with e800bt
I don't know much about italian warranty conditions bt in Germay you can ask to change the PDA after it is repaired three times without success! I think it is the best to contact Toshiba Italy directly and tell them your story and ask what to do! TOSHIBA EUROPE GMBH - Sede Secondaria in Italia CENTRO DIREZIONALE COLLEONI Palazzo Perseo - Via Paracelso, 10 20041 AGRATE BRIANZA (MI) Tel. 00 +39 (0)39 68730.1 Tel. 00 +39 (0)39 68730373 Telefax 00 +39 (0)39 68730369
Sep 08, 2005 | Toshiba e800 Pocket PC
Memory loss
the problem is based on a failure of the backup accu. This can only be fixed by a Toshiba Repair Service. They have to change a Board inside the PDA.
Sep 08, 2005 | Toshiba e740 Pocket PC
Toshiba e740 Pocket PC Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
