Question about Nintendo Wii Console
All sound but no video
My tv died so I hooked up an old one. the TV has only a scart input so I used a scart multiway box which I have used before. The problem is this new (old TV)gives me sound but no picture unless I have the DVD player on as well and wiggle the scart so that the connection isn't very good. I then get video but it scrolls and loses colour. If I plug the Wii straight into the TV scart input I get nothing at all, just snow.
Is there anything I can do?
  • 3 Answers
It is normaly a defalt of the wii so send it back for a new one
Posted on Aug 31, 2008
What weight is this TV? I'm wanting to get a TV wall bracket so I can put this on to the wall. As this is an old TV and has no Freeview is there a way of connecting/getting Freeview to work
Yes there is a way buy a freeview box with a legacy scart plug connect to TV with a scart lead and use the freeview box remote to change the channel on the decoder and have the av input for the decoder on the TV and use the TV as a monitor only
as to the weight and how to mount the TV type and model would be helpful
Jan 22, 2017 | Televison & Video
I have lost the av channel and cant get it back
Not sure why you would need the AV channel. As long as the tv is switched on before the set-top box it should automatically show the video content as soon as the scart receives input.
I have not used the AV channel on any of my tv's since the digital switchover.
I am still using vhs tapes, a dvd player and a dvr top-box and use a multiway scart switch to select which to input to the tv scart.
Feb 20, 2015 | Televison & Video
How do you connect to a direct tv box
1st, what kind of Tv Box ? with SCART Connector? or RCA Connector?
2nd, the recoder has a Scart connector or Females Rca connectors.
check for Video IN and L/R input Rca Connector
then use a Scart/RCA cable to connect DVD to TV Box.
Nov 07, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Can't receive pic and sound with the converter box.
The tv should be on channel 3. Otherwise, you can go to menu on tv, then find "autoprogram" and it will search all available channels. Usually tv should be on channel 3 if hooked up with a coaxil cable and aux or AV or Input if you are using rca jacks.
Jul 08, 2009 | Televison & Video
Cable hook-ups for TV, Satellite Box, DVD, VCR
Use SCART lead from Sat. box to VCR input( so you can record progs.) then another SCART lead from VCR output to TV set AV1 input. Connect DVD (player only I presume) direct to AV2 input of TV set using another SCART lead.
Hope all this works O.K.
Note:- If DVD is also a recorder then you don't need VCR as a recording device and leads will need to be altered accordingly, of course!!
Nov 22, 2008 | Kenwood KR-V7080 Receiver
How do i install my surand sound and cable box to my LG television so the cable is ran through my surround sound and goes to my television? also how do i hook up my surround sound to my television?
If you have a scart cable going to tv from cable box all you have to do is put a phono cable from tv to system input,this could be "aux,sat,tv,input",switch system to input you put phono cables into and set to prologic2,you now should have sound.
hope this helps.
CABLE GUY.
Jun 29, 2008 | Onkyo Audio Players & Recorders
Stereo Sound on new LCD Samsung Series 5 TV
It appears you may be using a cable type which isnt compatible with stereo. The Coaxial output on a lot of the old VCRs dont always support stereo so that may be your problem right there. i suggest you try connecting the cable box directly to your TV using a scart cable. Scart definately supports stereo audio so if this doesnt give you stereo sound the problem lies within the cable box's audio settings which you should be able to access with your remote.
ope this helps you solve your problem :)
Good Luck.
Jun 15, 2008 | Samsung HCJ655W TV
Question regarding audio connections Akai 30" LCD TV
a switch box is needed the s video shares the red/white audio with the yellow rca that is being used already
May 07, 2008 | Televison & Video
Souud delay on tv /amp
Instead of connecting each device (sky&dvd rec.) to the TV separately, I would simply hook up the sky to dvd recorder (connect the sky output and dvd recorder input), and then connect the dvd recorder output (must be called "play out") to one of the available recorder inputs (which could be a dvr, an empty tape input, etc)of your amp. However, you'll still have to establish a feedback between your dvd recorder and your amp. Therefore, if the dvd rec. supports it, you'll have to hook up the rec.out, which is on your amp.,to rec.in on your dvd recorder. After all these audio connections, you will only need to make a video connection among the sky, dvd rec., and tv. Get a video cable to hook up the sky video output to your dvd recorder's video input, then do the same thing between the dvd recorder's tv output and tv.
Apr 12, 2007 | Cambridge Audio Azur 540A Amplifier
No sound
If I remember correctly, this model can only have sound from either the SCART or the standard input. The solution for this set is to have all the devices work through a common A/V switch box.
The best solution is to update the set to one with more active inputs that are adequate for your needs.
Jerry G.
Nov 19, 2006 | Sony KV-32S26 32" TV
Nintendo Wii Console Logo
59 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
