Question about LG Goldstar GWHD5000 wall/window Air Conditioner
My air conditioner won't turn on. I can push reset then hold test at the same time. And it will work as long as I hold it.
  • Ryan
    Ryan Jul 13, 2012
    Another hot July, another LG user with the plug breaker problem. Don't know what ultimately fixed my unit, but I was trying the reset+test thing you mentioned in your problem statement when the breaker finally stayed closed. Nice and cool now. Thanks
  • Ryan
    Ryan Jul 13, 2012
    Another hot July, another LG AC user with the plug breaker problem. Don't know what ultimately fixed my unit, but I was trying the reset+test thing you mentioned in your problem statement when the breaker finally stayed closed. Nice and cool now. Thanks
2 Suggested Answers
SOURCE:
  • 4736 Answers
SOURCE: I have a portable air
The easiest way, is to tilt it over slightly when you drain it. But, be very careful doing this, as the unit has caster wheels and you don't want it to get away from you. If you have a helper, so much the better. Remember to always turn the unit OFF & Unplug it, before draining the water from the tank.
I hope this helped you and thanks for choosing FixYa.
Posted on Jul 21, 2011
I tried to turn on my air coditioning today for the first time this year and my Totaline Themostat P474-1050 won't turn on. Worked fine during the winter and last summer.
the thermostat is powered by the unit or batteries if batteries they may be dead if the unit you need to check fuses outside at unit or reset breaker outside depending on age of installation
Jul 10, 2012 | Heating & Cooling
Danby portable air conditioner won't turn on - brand new!
Obviously it is problematic machine from the factory so it will suggest a replacement.
Apr 12, 2012 | Danby DPAC12010H Portable Air Conditioner
Hwr08xc5 won't turn on. Pushed the test button and the reset with no response
TRY UNPLUGGING THE POWER FOR ABOUT 5 MINUTES , IT MAY JUST HAVE A BRAIN FART. THIS WILL REBOOT ITS MASSIVE INTERNAL COMPUTER.. LOL.. HOPE THAT HELPS .. IF SO HIT THE YES BUTTON.. JAY
Jun 23, 2011 | Heating & Cooling
NewAir AC 1400E. No green light on plug. Pushing reset button does nothing. Has been running OK. Outlet is live. Does not need draining. Any ideas?
If the reset button is not doing what it should. Try these solutions listed below::
Remove and replace the water collection bucket. Making sure the float valve (if your has one) inside the top of bucket is not stuck in the UP position. Also, be sure that the bucket fits squarely into the holder from top to bottom. If it doesn't, it won't trigger the buck removal safety switch.
If that didn't work do the following:
Turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet.
Wait 15 minutes, plug the unit in and turn the Master ON/OFF Switch to ON.
Generally, doing the above, allows the unit to reset and revert back to the original factory settings and you can proceed from there. If it still does not work, there may be a problem with the cord & reset switch. The best way to find out is test the continuity of the cord, with a multimeter.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 15, 2011 | NewAir AC-1400E Portable Air Conditioner
Water got into the plug. Unscrewed, drained as much as I could and set down on paper towels for a few days. Plugged back in & worked. Moved the cord while plugged in & the ac blew out and will...
Hello, most likly you will have to replace the whole cord assembly, here is a link to parts for you AC http://www.appliancefactoryparts.com/airconditioners/goldstar/m1003r.html
Jun 08, 2011 | Goldstar M1003R Air Conditioner
My fridgedaire window unit A/C and heat won't come on. I had replaced an outside light fixture a couple of weeks ago and had turned off the circuit breaker that affected this unit too. Now the unit...
Plug a light into the outlet used for the A/C, if the light does not come on when reset then the circuit breaker that provided the power to the outlet need to be reset or replaced.
May 22, 2011 | Frigidaire FAS257S2A WallWindow Air...
The unit worked fine when i last used it in the fall. I plugged it back in today and all the buttons lit up for about 1.5 seconds and then all the buttons went dark again. So I pushed the "on"...
I have had a problem like this in the past you can try taking the electric access panel usually on the side of the equipment. then look inside you will see a wiring harness inside and it literally takes nothing to bump it loose. This happens when people move these units they are pretty fragile and can be tempermental. Make sure the unit is unplugged while you adjust the wiring harness. If that deosnt work your display board is probably bad. Hope that helps
May 10, 2011 | Haier ESA3125 Wall/Window Air Conditioner
LG Goldstar GWHD5000 wall/window Air Conditioner Logo
259 people viewed this question
Top LG Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Steve F
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
