Question about Kenmore Elite 45986 Front Load Washer
Kenmore eleite model number 22062101 washer displays c1 fault code
  • 639 Answers
Peace Friend,
ngfam1 At your service!
With an error code the only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!
Posted on Sep 02, 2008
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    I have a Kenmore front washer model number 41272210 that is flashing an error code CL what does this mean
    fault indicates that there was an instantaneous current spike at the motor windings in the washer. This could be caused by overloading the washer. It can also be caused by problems with the drive motor, thermal protector or the motor controller.
    You should have been able to clear the display by pressing the STOP/CANCEL button
    May 05, 2014 | Washing Machines
    Kenmore elite calupso washer starts and runs for 2 min then stops then starts then stops and C1 flashes
    The CI and CA error codes indicate that current (amp draw) limits for the drive motor were exceeded. Since you indicate that these codes were displayed even though the washer is not overloaded, it is likely that you have a problem with the motor, motor controller or the universal joint. An item stuck underneath the nutate plate or between the spin basket and the outer tube of the washer could also cause this problem.
    Nov 21, 2012 | Kenmore Washing Machines
    My kenmore elite calypso has a flashing code C1. What does this mean. Also, how can i get a manual for this washer, that explains all the codes.
    C1 is not one of the normal codes. It's probably CI (upper i).
    Stands for 'Instantaneous current' limit trip. Happens when there is a spike of 26 Amps intensity at the motor windings.
    The manual states it may be a problem with the drive motor, thermal protector or motor controller.
    check here for your stuff. make sure you put your exact model number in the box at the top. i used my machine (GVW9959KL1). absolutely awesome website and has very competitive prices, if not the best prices for parts. hope this helps.
    -samson39
    Aug 18, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
    Fills with water then won't run flashes C1 error code
    The CL fault indicates that there was an instantaneous current spike of 26 amps at the motor windings in the washer. This could be caused by overloading the washer. It can also be caused by problems with the drive motor, thermal protector or the motor controller.
    You should have been able to clear the display by pressing the STOP/CANCEL button.
    If you try running the washer again and continue to get this fault code even with a small or medium load, I recommend calling a service technician to diagnose and repair the washer.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Aug 15, 2009 | Kenmore Washing Machines
    Calypso with C1 error code.
    Aug 11, 2009 | Kenmore Washing Machines
    Machine won't work it says C1 message. pls advice.
    On Whirlpool Calypso washers that is probably not a "1" but is the letter i. The code "CI" is the fault code that indicates "Instantaneous Current Limit". Instantaneous current trip occurs if there is a spike of 26 amps instantly at the motor windings.
    This may signify problems with the drive motor, thermal protector (fuse), or motor controller. Overloading the washer may cause this condition. Press stop/cancel to clear the display. Hope this helped you.
    Jul 21, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
    Kenmore elite calypso codes a C1 and quite working
    Maybe "CL" From User Manual:
    “CA” or “CL” (Current Limit)
    Is the washer overloaded?
    Press STOP/CANCEL to clear the display.
    Jul 04, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
    Washing machine error c1
    Jan 02, 2009 | Washing Machines
    Kenmore washer model # 110.24086200
    The C1 code indicates the "instantaneous current limit" trip. This signifies problems with the drive motor, thermal protector, motor controller. Overloading the machine will cause high amps and trip the unit. Instantaneous current trip occurs if there is a current spike of 26 amps instantly at the motor windings in which the motor overload trips. check bearings for lubrication - or as stated above overloading the washer.
    Sep 06, 2007 | Kenmore Elite 45986 Front Load Washer
    Kenmore Elite 45986 Front Load Washer Logo
    116 people viewed this question
    Sal De
    fordexpert
    Robert Rankin
