Question about Hotpoint Ultima WF860 Front Load Washer
How do I replace the door seal on a Hotpoint WF860
My machine leaks on every wash at the rinse cycle, I have checked the inner door seal and it has holes in it where something has burnt the rubber. How do I replace the seal when a new one arrives please.
Abby
    Genius:
  • 1,028 Answers
Unless you are really bored don't try it ..front side not bad but inside where it mounts onto outer tub can be a big black bear ..little space to work and rear band even tougher
Posted on Aug 30, 2008
Leak on rinse cycle aotpoint aquarius wmf 540
Check the door seal.could have small rip/ tear around Hinge or door lock position....
Nov 06, 2013 | Hotpoint Washing Machines
Water leaks on spin cycle
Water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Replacing Door seal: http://www.espares.co.uk/advice/washing-machines/a/7/1464/how-to-replace-the-door-seal-on-a-washing-mac.html
Feb 01, 2013 | Hotpoint Aquarius WD63 Front Load...
Water comeing from drower
Check for water leak with drawer open while washer is operating from beginning of cycle. Your problem could be attributed to one of the following:
* water valve
* water inlet hose
* rubber door seal
Contact an appliance service company.
Feb 17, 2010 | Hotpoint Ultima WF860 Front Load Washer
How do i release band round hotpoint washing machine door seal
The band around the door should have a spring a the bottom, use a needle nose plyers at she spring area and strech the spring to get it off.
The inner band has a bolt head or philip head to loosen it.
Jan 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
Needs a new door seal the seal now on the washing machine is leaking
Hi.
You need Hotpoint part number: 1605550.
if having problems obtaining one please call me on 01733 307019
aardvark repairs
Nov 24, 2009 | Hotpoint Ultima WF860 Front Load Washer
My Hotpoint Ultima WT960 is in the middle of a program and on the rinse cycle and on the screen is flashing H2O the door is locked with my wool wash inside. What do I do.
Check the program that you have it set on for the wool cycle. Some washers have where you can "add water" in the rinse cycle. If yours has this feature, I would try that also.
Jan 11, 2009 | Hotpoint Ultima WF860 Front Load Washer
How to replace door seal of Hotpoint WF860 washing machine
Hi, This is a very simple and straight forward job. First turn off the washing machine and remove the plug from the wall and earth the plug on the cabinet of the machine to remove any residule current in the machine. Remove the top of the machine with the screws at the rear of the machine. You can now look in the top? Open the door and take off outer door seal clip ( look and you will see how ) If it is a plastic clip it will have a small cut out in the side for a small screwdriver to be put in a pushed open. It could even be a small spring that is laying in side the small lip of the door seal. You could now attempt the removal of the door seal if you can see the inner clamp to get a long screwdriver onto the screw! If not now remove the soap drawer. Remove screws from around the soap drawer and slide the facia to the right and it should all be off.. Then you can remove the three screws that hold the front on along the top and the same along the bottom edge of the front panel. This then will allow you to take off the front panel and have better access to the door seal. Then once you have replaced the door seal you just need to replace as you took off..
Good luck................
Dec 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
Door seal has two holes in it and leaking
Hi.
You need to remove the front console panel and then the front panel to change the door seal.
Pull the dispenser drawer out and remove the screws.
Slide the console panel to the right and support it while you remove the rfont panel.
Change the seal, and reassemble in reverse order.
Good luck.
Nov 20, 2008 | Hotpoint Ultima WF860 Front Load Washer
How do i change the door seal on hotpoint ultima wf860
hi this is a ten minute job take your lid off your machine and then take you soap drawer out there are 2 screws in the behind the soap drawer undo these unclip the top board as you look in side the machine and put the fasia in a safe place now you will have two screws on the top of machine from where you just took the facia off and 2 underneath the bottom by removing the plastic kicker plate undo these and open the door to the right you will see 2 screws that hold the interlock in remove these and then remove the band around the door seal normally metal with spring now lift the front of the machine upwards and that will be the front off now unclip the door seal from inside and check for holes if ok soak in bleach over night and rinse in the morning try some descaler to remove and limescale when you use machine again total 10 screws to undo really easy goodluck and please leave feedback
Sep 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
277 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
