Question about Dell UltraSharp 1907FP 19" LCD Monitor
USB outlets My monitor is connected to a Dell E521 and for two years I have never been able to get the four USB ports to work. To my knowledge the proper drivers are installed. Maurice Crosswell
  • 2 more comments
  • Morri Aug 29, 2008
    Yes thanks, all necessary cables are in place
    I,m running XP
  • Morri Aug 30, 2008
    Nothing happens in the "universal Serial Bus Controllers" section but when plugging the cable in,
    "Other devices - USB device" appears in the column above. Likewise when unplugged the "Other devices" disappear
    Unfortunately I've run out of time because I am going away now until the 25th Sept. I hope we can resume then.
    Scholar:
  • 45 Answers
I'm assuming you are speaking of the USB ports on the Monitor?
Do you have the USB cable running from the back of your computer to the back of your monitor? For those ports to work, you need a USB cable that runs from the computer to your monitor. This is a cable in addition to the power cable and the video cable. Verify you have three cables connected.
If you are not speaking about the USB ports on the monitor, please advise...
Posted on Aug 29, 2008
  • 5 more comments
  • Stephen Aug 29, 2008
    Update: There could possiby be FOUR cables connected if you also have sound in your monitor.
    What version of Windows are you running? XP or Vista?
    Sorry, I'm assuming you are running Windows.... :)
    Ok, click on the Start Menu and go up to "My Computer" and "Right" mouse click on it. On the menu that pops up select "Manage". This will bring up the "Computer Management" Screen. From here, select "Device Manager" on the left column.
    On the right window, click the plus "+" sign next to "Universal Serial Bus Controllers". This should list all your USB Ports and some devices.
    At this point, make a mental note of what is there, and if you can, unplug the USB Cable from the back of the monitor to see if any of those items listed dissappear. There should be 1 or more USB Root Hubs that go away. If not, then the hub is not being detected by windows. Plug the cable back in and see if it is detected while you are watching that screen.
    Let me know what you get...
  • Stephen Aug 30, 2008
    Ok, that's helpful. Do they have an icon with them? Like a Question Mark or an Exclamation Mark?
    The fact that they are in "Other Devices" might indicate the drivers are not installed, or did not install properly. What is the Make and Model number of your monitor?
    Sorry, one more question. Is there anything currently plugged into any of the four monitor USB outlets?
  • Stephen Aug 31, 2008
    That should be fine. Let me know when you get back. :)
My Dell Monitor P2210 USB Ports Not working
Do you need a USB cable from one of the USB ports on your computer to a USB port on the monitor?
Feb 04, 2012 | Dell P2210 Monitor
My dell monitor usb ports don't work anyone how to fix it?
Please check if the monitor's usb port is connected to the tower, the monitor only acts like a USB hub / junction. If it is connected then disconnect it from the existing USB port and connect it to a different USB port. Please refer to the monitor manual link given below
http://support.dell.com/support/edocs/monitors/e172fp/QSE172FP.pdf
Thank you for contacting Fixya.
Jan 03, 2011 | Dell E172FP 17" LCD Flat Panel Monitor
Can not instal a Cruzer Blade USB flash Drive onto my Dimension E521
What happens when you connect it?
What error-messages do you get?
Does it work when connected to some other PC?
Does it work when connected to some other USB port on your Dell?
Or, spend $8, and buy a replacement.
Dec 27, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Dell E521 cannot get to bios with usb keyboard.
check the loose connection on mother board try to reconnecting again then after that power on the computer quickly press f2.
Mar 06, 2010 | Computers & Internet
Usb ports on 1703fpt do not work
you have to connect the monitor with a usb cable to your computer, then you can use its usb ports, it's just a hub.
Mar 28, 2009 | Dell 1703FPt 17" TFT LCD Flat Panel...
Cannot connect to internet thru ethernet jack on computer
It could be. Check your Device Manager and make sure the device isn't disabled. Also each adapter has its own TCP/IP settings so make sure yours on your ethernet adapter are set the same as your USB adapter that is working. If it does turn out to be bad you can always add a new ethernet card for cheap.
Jan 05, 2009 | Dell Dimension E521 (D10E16) PC Desktop
Dell 1907fp USB port not working
The big question is do you have the USB uplink cabled from the monitor, connected to a USB port on the system?
http://support.dell.com/support/edocs/systems/1907FP/en/about.htm#Bottom%20View
Item #5 needs to be connected to your system's USB port via a USB cable. The ports on the monitor are just a USB hub.
Jun 09, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
Can't Get Into Bios Setup Dell Dimention E521
Check if your keyboard is connected to USB port which is part of the motherboard and not some frontal or 'additional' USB ports you might have
May 07, 2008 | Computers & Internet
Monitor usb
There should be a USB cable from one of the usb ports on your computer to a small square (upstream) USB port on the back of your monitor. This will activate the four (downstream) usb ports on your monitor.
Good luck...and I hope this is helpful!!
Feb 01, 2008 | Dell 1703FPs 17" TFT LCD Flat Panel...
Dell UltraSharp 1907FP 19" LCD Monitor Logo
184 people viewed this question
Alun Cox
