Question about Philips Senseo HD-7810 Coffee Maker
Top pops open and water spits out all over
About every 4th or 5th time I use it, the top pops open and water starts spewing out all over. I've tried holding the top down while brewing but this hasn't solved the problem. I've cleaned the machine out from top to bottom, to no avail. Is this a defective machine?
  • ssourgirl Oct 02, 2008
    I have the same problem and its really annoying!! Now its gotten even worse and its almost every time I use it.
  • gtitus Nov 08, 2008
    I had the same problem with my 7810 Senseo. It was about 1 year old. The latch had become worn and couldn't hold the pressure. The latch is plastic (both the hooks and the recesses that they slide into to hold the lid shut) and the hooks and recesses edges were rounded off and would pop open under the pressure. If I held the lid shut with my palm, then it was fine. I called Senseo and since it was still within the 2 year warranty, they replaced it with a new one. I have now used the replacement for over a year (5 or 6 cups a day!!!) with no more problems. Senseo customer service was very good. they sent me a prepaid shipping label so I could return the defective unit; they then sent me a new one. Once your machine starts doing this, it will only get worse. Call Senseo to have it replaced.
    Gary T
Use only senso pods
Posted on Oct 16, 2008
Mini keurig stops brewing and blows tops off k-cups
It may be time to descale. Most models will give you a message when it's time to have the mineral deposits cleaned.
HERES HOW TO DO THAT...
Empty water resevoir. Disable auto off. Pour approx 48 oz of undiluted white vinegar into resevoir. PLace large mug on drip plate, run brew cycle, dump contents of mug in sink. DO NOT USE A K-CUP.
Repeat this process until the add water light is indicated.
Let brewer stand for at least 4 hours while still on.
Discard any residual vinegar in the resevoir and rinse thorughly.
AFTER approx 4 hours...fill resevoir with water.
RINSE:
PLace a large mug on the drip plate and water brew cycle. Pour the contents of the mug into the sink.
REPEAT this brew process until the add water light is indicated.
YOU MAY NEED TO REPEAT THIS "RINSE" PROCESS if you notice any residual taste.
Jan 01, 2013 | Keurig Mini B31 Plus Black Coffee Maker
My kcup brewer leaks water around kcup area no matter how little or full I fill withy coffee how do I stop this Also tried different grinds still spittting water all over !!
I had the same problem I bought a 1/2" rubber washer and duct taped it to the top of the reusable unit and it has been working great for about a month, the indent in the reusable filter is too far away from the brew section of the machine
Dec 10, 2010 | Keurig 5048 My K-Cup Reuseable Coffee...
Why would water spew out while using My kcup in the keurig?
The top gasket is not sealing on the endention of the my k cup. Open the handle look inside around the top needle and there will be a black gasket around it. Pull it down just a little so that it makes better contact with the My K Cup.
Mar 21, 2010 | Keurig Elite B40 Coffee Maker
Too much water in espresso, Steam spits water
Hi
Yes it is possible to raise the temperature but it requires taking the top off. Most people are not into removing the top. email me if interested
Apr 17, 2009 | Saeco Vienna SuperAutomatica Coffee...
Betty crocker mod.bpl 825u
That slot is no accident; don't attempt to plug it. If it is where you describe it being, it would stop hot water from spitting out elsewhere in case the nozzle is blocked.
If it is where they are normally found, at the back of the water reservoir, it was provided to prevent water from finding its way into the lower section and possibly creating a path for dangerous voltages present and not well protected in the base of the unit.
Even if there is no possible way for water to migrate down to the bottom, it could then run out through the front of the unit, making even a bigger mess.
Most coffee-makers have this overflow opening in the back.
Jan 23, 2009 | Betty Crocker BPL-825U 12-Cup Coffee Maker
Fill Water tank - Ventilate
Hi Mike,
Make sure the magnet flow up, if it flow up and you still get fill water tank then you have to replace the magnet.
If you get ventilate all time, try to remove the filter and try again.
/Mirran
Aug 23, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Vienna superautomatica Machine
if you open the steamer, does it work correctly? and if u request hot water does it come out?
if not, then its the pump..
Nov 02, 2007 | Saeco Vienna Espresso Machine
Philips Senseo HD-7810 Coffee Maker Logo
182 people viewed this question
Top Philips Coffee Makers & Espresso Machines Experts
Kolbrun...
kenneth njonjo
Tom Chichester
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
