Question about Refrigerators
Whirlpool frost free tropical, seems to be defrosting, when the door is opened the internal light flashes with an alarm also with the temp set to max (all three leds on) once the door is opened the temp leds returm to med setting
  • 1 more comment
  • stellamariaf Aug 31, 2008
    I have the same problem. When the door is opened for too long, it beeps. We have to press the button under the flashing red light to stop it. But sometimes for no reason the beeping happens and we have to get up out of bed to go press the button to make the noise stop. What is it trying to alert us to?
  • tonys2579 Mar 01, 2009
    I have the same problem with my "whirlpool", which I thought was to do with defrosting or not freezing , but nothing seems to happen except flashing lights etc. This doesn't happen every time the door is opened.
    A suggested solution was to look at the sensor, but what do you do then, as there are no controls on the sensor
    Tony2579.
  • Sri Rama Apr 28, 2013
    i have the same problem this sucks can anyone help?
Check the sensor in the refridgerator... on the right,,
Posted on Sep 22, 2008
Defy 350lt upright freezer red alarm light flashing the light start flashing and the food started defrosting
Check for proper door closure or internal light function first
Next, check temp. control settings. If all checks ok, call a tech. to fix it
Sep 21, 2017 | Freezers
Electrolux door alarm Won't stop. We open door to turn off alarm. Temp seems right but slight condensation at the very top of the fridge. Need to at least disable alarm until I can get a repair.
Check the back wall of the freezer, I would suspect the beginnings of or a full-on defrost failure... If there is frost on the back wall of the freezer it means the evaporator is blocked, disallowing airflow to the fridge compartment... Electrolux Refrigerator Defrost Thermostat 216731001 . If there is no blockage, but temps are still not cold enough, your Frigidaire may be leaking refrigerant...
Jul 03, 2016 | Electrolux ICON Professional E32AR75JPS...
Why is Zanussi frost free freezer alarm always flashing
Because it does not achieve the correct temperature (for example: -18 degrees centigrade).
For a more precise answer I need more information.
A lot of things may be incorrect:
- Doesn't work defrosting cycle
- The cooling fan is not working
- Too much ice on the evaporator battery
- Faulty thermostat or NTC sensor
- Faulty cooling system (gas leak)
- Compressor
- Electronic
Dado
Aug 26, 2014 | Zanussi Freezers
My whirlpool frost free fridge freezer's alarm keeps going off, ice-cream doesn't freeze?
Check condenser is clean, fans working, thermostat set correctly, try to check internal temp with digital thermometer
May 17, 2012 | Refrigerators
The temp alarm keeps beeping, although the temperature seems fine
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Jun 04, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
FFM90
hi The limit switch is found only on frost-free refrigerators and freezers. Its function is to keep the defrost heating element from exceeding certain set temperatures. If a refrigerator has lots of frost in the freezer compartment, the problem may be the limit switch. However, other components -- the evaporator fan, the defrost timer, and the defrost heater -- can cause the same problem. Check these for malfunctions, as detailed below. If these parts are in working condition, the problem is most likely in the limit switch. Don't try to fix the limit switch yourself; call a professional service person for replacement.
Sep 14, 2008 | Hotpoint FFM90 Bottom Freezer Refrigerator
Freezer frosting up
I need more information. If this is a frost free freezer with an internal fan I need to know what the freezer temp is. If a manuel defrost it is supposed to frost up. You defrost it 2 - 3 times a year when the frost builds up over 3/4 inch. If it frosts up faster than this check to see if the door is sealing all the way around. There should be no gaps or cracks in the gasket.
Jul 10, 2008 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted
whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted. the temp display on freezer shows - - flashing
May 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Frost Free 460 door open alarm
http://www.repairclinic.com check how to repace it with the schematic diagrams you'll see how
Dec 30, 2007 | Whirlpool GS6NBEXR Side by Side...
Temp alarm going off
What is the temp in the freezer, sounds like temp is to low..no water should be coming out of freezer, sounds like may be defrosting Need to check the temp to make sure its cold enough.. thats what that alarm is for
Aug 10, 2007 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Refrigerators Logo
2,045 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
