Question about Saeco Vienna De Luxe Espresso Machine
Water leak from bottom and get a half cup of coffee one time and a full next time Vienna digital
  • 515 Answers
How old are your machine?
Do you descale your machine regulary?
/Mirran
Posted on Aug 29, 2008
I have Saeco Vienna digital coffee machine already for 7 years. It was working fine but now I have problems. Only small amount of water/coffee goes to the cup and rest (clear water) goes to the tray and...
Hi
You boiler is leaking. You need to replace the boiler. sorry. Your water hardness might be set to low if you have been descaling when it tells you to. Boilers usually last 7 to 10 years, but need to be replaced. If you need one let me know. I have some new and rebuilt boilers for that machine.
Mar 08, 2010 | Saeco Vienna Digital Coffee Maker,...
Saeco vienna leaks CLEAR water from under the machine. A tiny amount of coffee makes it through to the cup
The leaking is from the water pipe coming from the boiler thought the solenoid valve to coffee group. Their are many points that this leak can be so the only way to find it is to run the machine completly open without the plastic sides. The most posible postion is the plastic hose conected on the coffee group and some times you will have to place it back in position very easy.
Good luck.
Remeber to vote for this answer.
Feb 24, 2010 | Saeco Vienna De Luxe Espresso Machine
Vanishing water
Is this problem happening by chance after you have used the maker? If so the heat from the previous use may be causing the water to steam from being so hot and thus causing the pot to be only half full. the hotter the maker the more water evaporates. You might need to let it cool down in between pots.
Joe
May 19, 2009 | Bunn 10 Cup Home Coffee Brewer
I have a Saeco Vienna Deluxe Model. We have been experiencing water leaking from the machine. It leaks under the tank and floods the counter or leaks into the spent coffee disposal bin. I removed and...
If it leaks under the water tank then you have to replace the gasket in the machine where the water tank inlet are.
If you have a leek inside the door, make sure the hole behind the brewing unit (in the chassis) are clean.
That you get a half cup of coffee one time and a full next time can be the electric board in the machine but can also be the flow meter.
Hope this can help you.
Best regards
/Mirran
Aug 25, 2008 | Saeco Vienna De Luxe Espresso Machine
I have a Saeco Vienna Super Automatic and for some reason it is no longer making steam. It starts to and then it stops.
If you open the steam knob, can you make a full cup of water or just a half?
How often have you decalcify the machine?
If it is long time then do a descale to make sure there not is calcium in your system.
Jul 14, 2008 | Saeco Vienna De Luxe Espresso Machine
Fill water tank problem
Do you have a magnet in the left corner in water tank? if you had it, make sure it float up when you fill the tank with water.
If you not have a magnet, try to open the steam knob and see if you can get a full cup of water, if it stops with half cup then the "water turbin" has to be replaced.
Jun 24, 2008 | Saeco Vienna Digital Coffee Maker,...
Saeco coffe maker doesn't work
Thank you for your concern! I drove it over to place nearby that fixes these machines in Los Angeles. That way, I can avoid costly shipping charges!
May 24, 2008 | Saeco Vienna Digital Coffee Maker,...
Problem getting a Full Cup of Coffee
besides descaling you need to lube the brew group, especially the bit that accepts the group nozzle. You might have a leaking boiler too, 6 years is pretty good for a vienna.
Remove the brew group and look for the two red o-rings on teh brass bit, smear some lube on it, they might need replacing by now, but luckily they aren't too expensive and readily available albeit a bit tricky to install, a good light and some patience is very important.
Dec 14, 2007 | Saeco Vienna De Luxe Espresso Machine
Water leak
A good chance - and easy repair lis just that the plastic hose has wiggles loose at one of hte various conenctions as water routes through teh machine. hopefully if is not a crack in the boiler, assuming it isn't
Oct 02, 2007 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna De Luxe Espresso Machine Logo
73 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
