Speaker hookup which plug in to use,red,blue,or green?
  • Anonymous Jan 08, 2009
    the acer computer came with no real user manual. ther are no instructions where to plug the cords into. michaelès suggestion the green one is completely unhelpful as there are at least 3 gree plug ins plus the speaker also have a flat plug in (where does it go).
  • 37 Answers
Green would be the plug you would need to use.
Posted on Aug 29, 2008
2006 dodge dacota radio wiring harness
2006 Dodge Dakota Car Stereo Wiring Guide
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Dark Green/Brown
Right Front Speaker Positive Wire (+): Gray
Right Front Speaker Negative Wire (-): Gray/Brown
Left Rear Speaker Positive Wire (+): Dark Green/Dark Blue
Left Rear Speaker Negative Wire (-): Dark Green/Orange
Right Rear Speaker Positive Wire (+): Gray/Dark Blue
Right Rear Speaker Negative Wire (-): Gray/Orange
Dec 03, 2016 | 2006 Dodge Dakota
A wiring hookup for sony am/fm/mp3/xm CDX-R5515X
Yellow is memory so it hook to the battery, RED is ignition, BLACK is ground. Blue is power antenna, if you have one. Left Rear GREEN is speaker positive, GREEN/BLK is Speaker Negative. Right Rear PURPLE is speaker positive, PURPLE/BLK is Speaker Negative. Front Left WHITE is speaker positive, WHITE/BLK is Speaker Negative. Front Right GREY is speaker positive, GREY/BLK is Speaker Negative. ORANGE is night illumination.
Oct 03, 2014 | Computers & Internet
I would like to play my Nintendo Gamecube. I have a Vizio HDTV. I also have a pdp cable the will connect to my Gamecube and TV. The cable has a blue plug, a green plug, a white plug, a yellow plug, and...
What you are trying to do is run your GameCube into the component hookups into the TV. What I would do first is lay out the five plugs on the end of the cord without them crossing over eachother. There should be a red plug directly next to the white one. The red one and the white one are both your audio hookups, plug them into the audio connections on the TV (that is the L and R ones and they are color-coded). The other three (green, blue, and the other red one) are the ones that are used to display the picture. Green goes into Y, Blue goes into Pb/Cb and Red goes into PrCr (again, the connections and the inputs on the TV are color-coded to make it easier). With that you should be able to play the system. If that doesn't work, make sure the red ones are in the correct place. Good luck!
Jun 29, 2011 | Nintendo GameCube Console
Radio was removed from my 91 Seville and replaced with aftermarket CD player radio. I would like to use this radio in my shop. I have 12 DC supply and speakers and antenna. Note: There is no place to plug...
This should be the wire combination for your car: nstant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Trigger Pink Antenna Right Front Speakers
Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Speakers continued
Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue
Apr 13, 2011 | Car Audio & Video
HAVE A P05091506AE STEREO WANT TO CHANGE TO A JVC KD-R900 NEED TO KNOW WHAT THE WIRING ON MY 2005 DODGE RAM 1500 PIN CONNECTOR IS. 22 PIN CONNECTOR. COLORS ARE NOT MATCHING ANYTHING I CAN FIND ON...
This is the wiring codes
2005 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: Dark Green/Red
Car Stereo Amplifier Location: Located behind the glove box.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Dec 25, 2010 | JVC Car Audio & Video
No sound on tv and black & white
The red, blue, and green are the component cable hookups. What you have w/ red, white, and yellow is called composite or on most TV's (AV) See if the TV has a side port for like a camcorder, etc. It will not work by hooking into the red/blue/green as they are different signals.
It is possible that your yellow jack may be separate from the red/white audio left/right jacks.
May 04, 2010 | Sony PlayStation 2 (PS2) Console
I need to know what the speaker hookup wire colors on a Pioneer DEH-345 Car Radio CD player
Yellow: battery power
Red: switched power
Black: ground
White: left front speaker
Gray: right front speaker
Green: left rear speaker
Violet: right rear speaker
orange :dimmer
blue:amp remote on
blue/stripe:power antena
should be somthing like this, if you get an adapter from walmart or sonicelectronix it should just be a color code matchup for your vehicle.
Feb 08, 2010 | Pioneer Car Audio & Video
I need a wiring diagram to hookup a Delphi X250 MP3 to a Massey swather
not sure about yours but most common colours are as follows
red -Acc power
yellow -12 memory power
black -ground
blue -amplifier remote
blue/white -power antenna
SPEAKERS
white left front +
white/black left front -
grey right front +
grey/black right front -
green left rear +
green/black left rear
purple right rear +
purple/black right rear -
Aug 30, 2009 | Car Audio & Video
Speaker wire colors
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Aug 10, 2009 | 1991 Ford Tempo 4 Door
Wiring a new radio in 1991 ford explorer
Right Front:
Right Rear:
Left Front:
Left Rear:
Right Front:
Right Rear:
Left Front:
Left Rear:
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
Feb 08, 2008 | JVC KD-G230 CD Player
117 people viewed this question
 Grubhead
Grubhead
