Question about Canon Elura 60 Mini DV Digital Camcorder
Zoom button of canon elura minin dv
It zooms in automatically.wats the sulotion
I had a similar problem. Searching Google for a solution, I came across the old -- "if it doesn't work, smack it" trick:
Remove any tape in the camera.
Remove the battery.
With your hand holding the top of camera, hit it firmly with a book on the bottom. I used about a 200 page paperback.
I suspect it is a electro-mechanical switch that gets stuck in the "On" position, and a little jolt frees it up again.
I have done this twice in the last month, and it works great.
Posted on Jun 15, 2009
Listen, I know it's a couple of years after this post but, try this: Problems with the zoom? Push firmly on zoom button (to un-zoom) try doing this as your tapping it. This is a last ditch effort on an aging camera, it really has been a good one. I've put this poor thing through years of abuse, and it's held up pretty well. Good luck, Jeff
Posted on May 09, 2009
My canon elura 60 when open my video cam it zoom automatically and the zoom lever dont work.
The zoom assembly will need to be replaced. This repair should be done by an experienced technician. Unfortunately, there is no easy fix that you can do yourself.
Hope this helps you.
www.austintelstarservices.com
Jul 21, 2011 | Canon Elura 60 Mini DV Digital Camcorder
Our Canon Elura 65 Camcorder won't focus. The
First off I don't condone or advise hitting an electronic device but, from the advice of another post I did it and it worked. It shouldn't have but it did. I hit the bottom of the camcorder with the palm of my hand and it worked perfectly afterward.
Jun 28, 2010 | Canon Elura 65 Mini DV Digital Camcorder
Canon Elura zoom problem
on mine the ribbon cable from zoom button was pinched where it goes around the door replaced cable
Jul 16, 2008 | Canon Elura 65 Mini DV Digital Camcorder
Zoom button is malfunctioning
tons of people w/ any canon elura series cameras including myself, with a canon elura 80 have the same zoom problem. It does not appear that canon has done anything to try to solve this mass problem with this series of cameras. Oddly enough the only way to solve this problem is to give it a tap and gentle hits near the zoom button to release what would seem to be a jam. Sorry that there's really no straight forward answer, but for now its the best i can give.
May 03, 2008 | Canon Elura 80 Mini DV Digital Camcorder
Canon elura 65
on mine the ribbon cable from the button to the main board was pinched by the door and shorted
Feb 13, 2008 | Canon Elura 65 Mini DV Digital Camcorder
Canon Elura 60 zooms by itself
Listen, I know it's a couple of years after this post but, try this: Remove cassette, push to close, close camera as if to use it, hold firmly in left hand, open hand slap it with your right hand once or twice, (I'm not joking) it worked the two times I had this problem. Problems with the zoom? Almost same process, push firmly on zoom button (to un-zoom) try doing this as your tapping it. These are last ditch efforts on an aging camera, it really has been a good one. I've put this poor thing through years of abuse, and it's held up pretty well. Good luck, Jeff S.
Oct 16, 2007 | Canon Elura 60 Mini DV Digital Camcorder
Zooming problem
I have the same problem. I have no fix in rec mode but if it happens during playback; press menu and select the zoom options. You don't have to pick any but just keep the menu displayed on the screen. I do this while recording the tape to my DVD recorder and it solves the locked zoom problem. The menu display does not get recorded.
This zoom problem is a big pain. We should start a class action suit against Canon. It started within a year of ownership with mine. I bought a Panasonic recently and haven't looked back.
Panasonic doesn't have the slick Canon marketing/packaging but it is a much better machine.
Aug 20, 2007 | Canon Elura 60 Mini DV Digital Camcorder
Canon elura 65
Hi There, Did you get any resolution for this problem? Even I have the same problem with my canon elura 70. Pls. share your thoughts. Thanks... Pradeep
Feb 08, 2007 | Canon Elura 65 Mini DV Digital Camcorder
Canon Elura 60 - Zoom is on maximum and won't restore. I own Canon Elura 60 since last two years and now i'm facing problems with zoom. Zoom button does go to and fro but actual zoom doesn't take...
Hi There, did you find any resolution for this problem? If you could share any info about the problem, it will be really great. Even I have the same issue with my Elura 70. Thanks.. Pradeep
Nov 08, 2006 | Canon Elura 60 Mini DV Digital Camcorder
Canon Elura 60 Mini DV Digital Camcorder Logo
515 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
