Question about White Sewing 1766 Mechanical Sewing Machine
Bobbin winder for white machine 1766
I have no manual for this machine. I need to know the proper size bobbin. the one I have which I assumed came with the machine does no wind on the bobbin winder. Also are there any problems with this model's bobbin winder that I should be aware of? I don't know for sure what is causing the problem the boobin or the machine?
    Genius:
  • 1,847 Answers
    Master:
  • 521 Answers
Wat size boobbin r u trying with at present
Posted on Aug 29, 2008
  • tech expert12 Aug 29, 2008
    complete details for the size of the bobiin and all the queries for ur sewing machine are mentioned on the link below to guide u completely step by step.
    http://sewvacdoctor.com/cate.asp?categor...
    pls do rate the solution
    thanks.
    regards.
    fixya expert team
    the details on the link i provided are absolutely free n precise.it will help u solve ur problem 4 sure.
  • 19,396 Answers
Here is a part sellertry vontacting them to see if you can find parts.
tandtrepair.com
Thanks
My 1130 bobbin threader turns, but will not wind thread.
Check that the bobbin winder is snapped all the way over.
Sorry, unable to provide more help, but a standalone bobbin winder may be helpful. You can find one brand (called "Sidewinder") at sewing stores like JoAnn's or online for ~ $30. Just verify that your bobbins will work (some Singer bobbins do not), but I assume your machine is a Bernina. Even if your bobbin winder is repaired, this standalone bobbin winder will save wear and tear on your machine--also, makes it so-o-o-o much easier to wind a bobbin without first removing the thread from your machine.
Oct 10, 2016 | Sewing Machines
How to thread bobbin 451 Pfaff
Having difficulty even locating a photo of the 451. Assuming this is an older model, perhaps this manual will help. It says its also for the 551, so perhaps the model is close enough that it will help you with your machine:
Pfaff 551 Manual pages 1 viewing
If you are unable to figure out the bobbin winder, you may be able to use a standalone bobbin winder (one brand is called Sidewinder) from the fabric store. They run ~$25-30. Just be sure to bring a bobbin with you to check the fit.
vintage sewing machine bobbin winding Google Search
How to Wind Bobbin and Thread Bobbin Case for Vintage Singer Featherweight...
Jul 14, 2016 | PfaFF Sewing Machines
My bobbin will not work
is machine set to darning setting , happens to a lot of them , the button is usually right next to bobbin and its easy to hit by accident this disengages the bobbin drive link so no it wont move
most units have a visual indicator for this function (but not all), but if draw toes under needle foot retract into platen base then yep it's in darning mode , you'll need to find switch and disengage this before it allows you to continue with normal sewing
Jun 24, 2015 | Sewing Machines
I need replacement "bobbin winder complete" for the one I broke on my Thompson Mini-Walker PW 201. Does anyone know of a source for it? Also I need a manual for this machine.
If you are unable to replace the bobbin winder for your machine, you might check the local fabric stores for a stand-alone bobbin winder. Last time I checked, they cost around $20-25. They are nice to have because it saves wear and tear on your machine.
Simplicity SideWinder Portable Bobbin Winder
Apr 13, 2015 | Sewing Machines
Machine will not go forward when pressing the foot pedal. Manual says something about checking bobbin winder indent. What is a "Bobbin winder indent."
bobbin winder is the little spindle on top usually right side above the flywheel. you need to move it left away from the stop as this engages the bobbin winder and disengages the needle movement. your manual should show this under Winding a bobbin. these machines dont have a clutch on the flywheel, just moving the bobbin spindle declutches
Sep 18, 2011 | Singer 6038 Mechanical Sewing Machine
The bobbin winder does not spin. it does turn manually, but not when I step on the presser foot. I took the top piece off and see no bobbin winder "tire" - should there be a "tire"
You should have a bobbin winder rubber it has probably come off and fallen in the bottom of the mahine, they are a standard size and an be bought from any sewing machine shop
Aug 27, 2011 | White Sewing 935 Mechanical Sewing Machine
I have been given a singer 4613 sewing machine. It seems to work very well. I cannot wind the bobbin because it appears the bobbin winder is missing. The manual show a winder on top, but there isn't one...
HI Vera,
I just picked up a 4613 and had the same confusion. The answer is...the bobbin winder is built in!! What you do is leave the machine threaded as normal and simply slide open the bobbin cover about an inch. You will see an arrow on the cover which you line up with an arrow on the machine bed. In this position, push the presser foot and run the machine and the bobbin will wind itself. It's actually really nice as you don't ever need to unthread the machine.
Apr 13, 2011 | Sewing Machines
Need to know how to thread bobbin
manuals can be purchased @ janome. com. your machine should have a bobbin winder. Set empty bobbin on the bobbin winder pin. Thread spool of thread though guide(or tension wheel on the top of the machine;NOT the stitching tension.) wrap thread around bobbin to start, and push bobbin toward the flywheel. slowly press foot pedal and bobbin should begin to turn. apply more pressure to foot pedal to increase speed.When full, bobbin winder should kick back to stop.
May 29, 2010 | Janome 2049LX Mechanical Sewing Machine
Bobbin winder shaft won't spin. LCD says bobbin winding.
Mine stopped working too. Gave up and wound bobbins by hand for a while until I broke down and took the machine apart -- an ordeal to figure out. I found that a pliable ring on the winder was completely disintegrated (gummy plastic-like stuff). An online search found this -- a bobbin "tire" which I THINK is the part I need: http://www.sewingpartsonline.com/bobbin-winder-tire-brother-x55238051.aspx. Hope this helps. --Also cleaned all the lint out when I had the machine opened up. They don't make it EASY!
Jun 16, 2009 | Brother CS-8150 Computerized Sewing...
White Sewing 1766 Mechanical Sewing Machine Logo
187 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
