Question about Kitchen Ranges
GE COOKTOP (gas) model gejgp975sekss g6
Can you tell me what the btu input rating for this unit
Ray
  • 19,396 Answers
It features 18000/11000/ 9500/ 2 X 5000 Btu
Here is specs:
GE Profile JGP975
Posted on Aug 29, 2008
    Master:
  • 848 Answers
Just ensure whether the model number is correct ......
    Genius:
  • 1,847 Answers
42 000 BTU per-hour
Do you know the BTUs for the five burners on this cooktop?
WEIGHTS & DIMENSIONS Approximate Shipping Weight 38 lb Cabinet Width 36 in Cutout Dimensions (Width x Depth) (In.) 33-7/8 x 19-1/16 Net Weight 33 lb Overall Depth 21 in Overall Height 3 1/16 in Overall Width 36 in Space Required Below Cooktop 0 7/16 in
  • POWER / RATINGS POWER / RATINGS Burner BTU Ratings (000's/BTU) - LP Gas (1) 9.4; (2) 7.0; (2) 4.0 Burner BTU Ratings (000's/BTU) - Natural Gas (1) 12.0; (2) 9.5; (2) 5.0 Volts/Hertz/Amps 120V; 60Hz; 5A
  • ACCESSORIES ACCESSORIES LP Conversion Kit Included
  • WARRANTY WARRANTY Parts Warranty Limited 1-year entire appliance Labor Warranty Limited 1-year entire appliance
  • GE 36 Built In Gas Cooktop JGP636WEDWW GE Appliances
    Oct 27, 2015 | GE Profile JGP636 Gas Cooktop
    I need to know the btu input for a ge cooktop (gas) model gejgp975sekss
    I see if I can find a diagram, ensure you posted right model number here.
    Aug 29, 2008 | GE Kitchen Ranges
    The flame is too high on my GE Profile gas cooktop
    I had the same issue on my jgp975 and sadly I had to purchase a different unit. I use simmer frequently and I made the assumption that low was simmer. Wrong. I believe a true simmer is 450 btu and my unit did not go that low. I had to check the fine print/specs page and on some units the manufacturer had to be called. I did replace with another ge profile that did have the low setting.
    Apr 06, 2010 | GE 36 in.JGP970 Gas Cooktop
    Low Heat from GE XL44 gas range
    you can increase the sides of the flames by opening the orifices, if not differences. make the orifices holes a bit bigger, you can have as big of a flame as you want. those orifices are at the connection of the burner with the valve that supplies gas to the burners.
    Dec 08, 2008 | GE Spectra JGBP35 Gas Kitchen Range
    How can you tell which fuel a gas cooktop is set up for?
    the gas regulator has a round "plug" in the middle of the top and one side is marked nat an one is marked lp you can tell which fuel the regulator is setup for by inspecting this plug. the orifices for the surface burners are marked with thier sizes (.073) for instance which I believe is thousandthsof an inch. also the orifice "spuds" as they are called will often have a drop of colored paint on them to further identify them for installation in the correct burner. checkyour carburation too. if the flame is noisy and trying to shoot up of the burner you could be getting too much air. close the air off a bit till you make a pretty flame two tone blue no yellow.
    Aug 09, 2008 | Cooktops
    Ge Monogram Gas Cooktop - won't boil water - burners seem like they are starved for gas
    Bret, lets give this a try. 1st look at the regulator. There is an arrow on it that has to point towards the cooktop. Put is on backwards and very little gas flow. I always advise this first as I have seen people tell me it is correct and when I got out there it was reversed. 2nd was this used as a live demo unit on Propane? If you are on natural gas, this will also happen. The 3rd thing I also check for in something in the gas line on the cooktop side. I had a unit that got some packing in the line and at 5 wc for natural gas, it doesn't take much to restrict. Hope this helps.
    Aug 09, 2008 | GE Cooktops
    GE 36" Monogram Gas Cooktop - low flame
    I would have someone come out. Perhaps a gas plumber first. Gas is not something you want to fool around with yourself.
    Aug 01, 2008 | GE 36 in. JGP628 Gas Cooktop
    My GE gas cooktop not working. Model#JGP336BEV1B8
    Are the other 2 burners lighting with the spark? If so the other 2 are either shorting before the burners or the sparkers are faulty.
    To service, the cooktop needs to be completely removed from the bench and disconnected from the gas as the access is from the bottom.
    I could step you through it while watching, but to do it this way is not a good idea. It's probably worth ringing a serviceman.
    Dec 26, 2007 | GE 30 in. JGP336 Gas Cooktop
    Jenn-Air JGD8130
    The problem is the pot(s) is too far from the heat. Jenn-air needs to make a burner cover that is closer to the burner for boiling water...
    Nov 08, 2007 | Jenn-Air JGD8130 Gas Cooktop
    Circuit Braker Jump Off Easily on GE JP350 Cooktop
    The ciruit breaker might not be of sufficient rating. Tell us what is the number written on the breaker?
    Oct 27, 2007 | Cooktops
    Kitchen Ranges Logo
    109 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
