FixYa.com
Tags:
Toshiba Sora PDR-T30 Digital Camera
Focus
posted by Guest on Sep 11, 2005
How can I get a better focus?
Solution #1
posted on Sep 11, 2005
Not Rated (0)
Adig
Adig - usenet poster
Rank:Wiz Wiz
Rating: 82%, 18 votes
There are several factors that can contribute to getting better focus and improved results.
1. Auto Focus / Auto Exposure lock. Press the shutter button down HALF WAY. The camera will attempt to adjust exposure to the current lighting environment for maximum benefit. Then the camera will automatically correct the focus based on objects in the center of the display. This process usually takes about two to three seconds.
2. Be sure not to cover the sensor on the front of the camera with your finger. This will disable the automatic focus and exposure controls.
3. Only us the MACRO MODE for CLOSE-UP photography. Be sure to use MACRO MODE if you are taking pictures of an object at less than six inches away. Be sure not to use Macro Mode for Normal Photography. Using MACRO MODE improperly will result in poor focus (also known as 'fuzzy pictures').
4. Motion can cause a "blur" effect. Either motion of the subject, or motion by the photographer. This phenomenon is just like traditional photography. Moving objects may appear to blur, and this will be even more evident in lower lighting situations as the shutter speed slows down to allow for more light. The shutter will react faster in bright light, and motion will not be as apparent.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Digital Cameras problems?
Digital Cameras
I have olympus digital camera
I have olympus digital camera... Answer This...
Digital Cameras
battery, instruction manual and...
need to know what kind of... Answer This...
Digital Cameras
Panasonic WV3400
I recently bought a used wv3400... Answer This...
Digital Cameras
I have a Panasonic VDR
I have a Panasonic VDR M50 GC... Answer This...
Digital Cameras
I have an old Nikon
I have an old Nikon FG with the... Answer This...
Repair Service
Find Digital Camera Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
