Question about HP iPAQ hw6515 Pocket PC
ActiveSync Problems Hi all Has anyone had any problems with ActiveSync just ceasing to work on this iPAQ - out of the blue? One minute it was completely fine, the other it just refuses to work. I have done all sorts in order to try and resolve this, including: 1. Soft reset. 2. Hard reset. 3. Uninstall/reboot/re-install activesync. 4. Install on a completely different PC. Nothing has got it working again. Any ideas would be most appreciated, since without ActiveSync this thing is just a glorified and very expensive phone! Thanks.
    Master:
  • 450 Answers
If you tried it on two different desktops and you tried it after a hard reset, I would say that you have narrowed it down to a hardware problem. When you tried it on the two PCs did you use the same cable to connect it? If yes you might want to try a different cable or if possible you can you try a bluetooth sync? If a different cable or bluetooth doesn't work you probably need to have the device repaired.
Posted on Sep 11, 2005
HP Pocket 2003. Need to restore information but not recognising profile. Where do I find the files on PC to copy mobile devise. Using XP student edition
Syncronation profile? you should make a new active sync profile.
or do you mean something else? please be more spesific.
if your device was hard reset and you need to restore something.
tell me what exactly.
Mar 28, 2008 | Computers & Internet
Activesync connection problems
this due to usb you just download hotfixes form microsoft updates and also download win xp service pack 3 which is available in windows site
Feb 15, 2008 | HP iPAQ rx1950 Pocket PC
Activesync problems with IPAQ 1940
 connect the cable with pc , open the active sync on ipaq then connect the cable with ipaq..if not still soft reset ur Pocket PC and reconnect.
Sep 17, 2007 | O2 Xda IIs Pocket PC
IPAQ H5500 USB CONNECTION TO PC NOT WORKING
open active sync on ipaq and connect the cable with pc and ipaq. if not recognised perform a soft reset on ipaq. also check in  active  sync on pc >file> connection settings> allow usb connections is checked
Jul 20, 2007 | HP iPAQ H5555 Pocket PC
How to get a CD-ROM program to run?
You're probably going to have to set up an ActiveSync connection between your PC and your 2415, then run the program installer on your PC while you're connected to the iPaq.
Sep 11, 2005 | HP iPAQ HX2415 Pocket PC
Data erased from iPAQ hx4700
If an ipaq loses power , then all data in RAM is lost. It's important to keep it charged. It's also important to do regular backups..... so there are two backup options - one is thru Activesync which will backup to your PC and one is the IPAQ's own backup program which will backup to the IPAQ FILE STORE (area in ROM) or a SD card. I do the Activesync backup every time I sync and then the IPAQ backup about once a week or immediately before a system change. Activesync backup ------------------------ Here is a guide which best explains it http://www.cewindows.net/faqs/activesync/backup.htm this guide suggests doing a full backup, but it's fine to do an incremental backup each sync - this means that only changes will be added to your backup and makes the whole process much quicker. IPAQ Backup ----------------- So under Programs is a program called IPAQ Backup. The default location is IPAQ FILE STORE which is an area in ROM and is not lost thru a power failure nor hard reset. You may also choos to backup to a SD card - a full backup will need roughly 20MB. So in this backup procedure, if you click on 'Browse' you can choose a SD card. A restore can then be performed from the IPAQ FILE STORE or SD card (depending on which location you chose) and so if you are away from your PC, this will be no problem. A restore this way , rather than thru Activesync is also much quicker, so if you have a choice go this route.
Sep 11, 2005 | HP iPAQ HX4700 Pocket PC
Pop up window "can not connect"
Almost surely you've got a "check e-mail every x minutes/hours" set, either in ActiveSync or on the iPaq (in Inbox or Messaging). You'll have to poke around to find it, but when you turn it off, those popups should cease.
Sync problems
Try to uninstall and reinstall Activesync.
Sep 11, 2005 | HP iPAQ H1910 Pocket PC
Activesync via bluetooth
I have bluetooth Activesync working on my hw6515 connected to a Dell x300. Followed the instructions in the User Guide Chapter 9. Need to take note of the com port assigned to bluetooth serial port on the PC. Connection must be initiated each time from the IPAQ ie go to buetooth manager and connect the activesync shortcut.
Sep 08, 2005 | HP iPAQ hw6500 Pocket PC
IPAQ 4150 - Sync Problems
It might be a hardware problem - if you get it both with the cradle and a sync cable, then it might be the connector at bottom of Ipaq. But I don't know for sure. If it's intermittent like this then it doesn't seem like a software problem.
Sep 07, 2005 | HP iPAQ H4150 Pocket PC
HP iPAQ hw6515 Pocket PC Logo
115 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
